HOW TO: Retrofit Install Guide (by EleDobleU)
Discussion in 'Lighting' started by eledobleu, Dec 9, 2016.
  1. Feb 10, 2017 at 10:17 AM
    #121
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    I will take a look again. Now trying to find same size of orange wire to extend 6 to 10 inches and have hard time to find the tap 26-18 gauge
    Send from gym Galaxy 7E
  2. Feb 10, 2017 at 10:19 AM
    #122
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Going to O'Reilly store
  3. Feb 10, 2017 at 10:22 AM
    #123
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Yeah I know that Orange wire is too short to work with it I had to extend it about 12-15 inches to reach the blinker harnesses I just used a soldering iron and heatshrink tubes to make it look more a professional and clean install, but as I mentioned before just used the switchback LED for a week and then disconnected the thing I prefer my LED strip as DRL only (white)
    LKSR5-14[QUOTED] likes this.
  4. Feb 10, 2017 at 10:41 AM
    #124
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    What wire gauge you use to extend orange wire?
  5. Feb 10, 2017 at 10:43 AM
    #125
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    This is only they have it weatherproof quick splices 18 - 14 gauge
  6. Feb 10, 2017 at 11:03 AM
    #126
    iHacker
    iHacker SW TRD PRO
    Mario
    I used 18 gauge wire pink and red (to match the colors in the oem harness) , the orange was no visible I left it inside the bulb gasket, 14-18 t taps should work for you
  7. Feb 10, 2017 at 11:09 AM
    #127
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Thanks
  8. Feb 10, 2017 at 1:53 PM
    #128
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Can you guys please tell me where did you run harness at front or back fan
  9. Feb 10, 2017 at 2:00 PM
    #129
    iHacker
    iHacker SW TRD PRO
    Mario
    Best way to go is hiding the wires in the front bumper metal frame I zip tied both harnesses in mine through that metal piece, I couldn't get a good picture with the grill on but this is an idea 1a2589d05cd45f2ae661fda1dd79df07_ecf1042ef8fd5a468363481c64078c76ce0d0e70.jpg574ebe213388dbcc9942ab4276285d3c_6a52e3cfe83a1110d86945c1a5d739ae5a527982.jpg
    Removed that nut and run the harness bellow 82c9a8b6ab91ed224cd5e01f3293d302_1093e0e4039f3d8718058b699f96712b42cc4cdd.jpge1a2b1a492f25102436f6fec531bc304_8ba713d536e418ada75e8cbd8b0044b135314a3a.jpg
  10. Feb 10, 2017 at 2:03 PM
    #130
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    It's look like short harness, maybe I'm doing incorrectly. Thank you for advice. Are you mount relay on the front or back of the battery bracket
  11. Feb 10, 2017 at 2:05 PM
    #131
    iHacker
    iHacker SW TRD PRO
    Mario
    But I'm not sure how the others did because doing it by my way an extension was needed because the HID harness is kinda short for the passenger side so I had to buy some 9006 extensions that was a week wait for me
  12. Feb 10, 2017 at 2:06 PM
    #132
    iHacker
    iHacker SW TRD PRO
    Mario
    I mounted mine in the front of the battery
  13. Feb 10, 2017 at 2:10 PM
    #133
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Lol don't tell me that now that I need buy something else lol
    iHacker[QUOTED] likes this.
  14. Feb 10, 2017 at 5:03 PM
    #134
    RW-3
    RW-3 May the Mods be with you
    Rob
    16 Black TRD CM 4x4
    Lights: 2018 OEM Black Chrome LED’s Morimoto XB Fogs Interior LED upgrade - VLED’s LED reverse / cargo - VLED’s Footwell lights, vanity lights, break lights, rear turn signals, 3rd break light - All VLED’s 30” Rough Country light bar hidden in bumper w/ Rago Fab Brackets Matt Gecko LED bed lights (red & white) and hood lights Exterior: Truxedo Lo Pro QT WeatherTech in-channel window deflectors Interior: Husky X-Act Contour front & rear Front, back and rear windows all tinted 10% Ceramic Heat Film on Windshield 70% OCD console organizer OCD console tray TRD 4x4 inserts on Husky mats by Achuop Tacoma TRD Pro shift knob with TRD leather boot AJT Design vent ring trim - chrome delete Center console wireless charger Drivers side grab handle Performance: Dirty Deeds BA Muffler 12” Budget Standard System TRD Rear Sway Bar AFE Pro Dry S Air Filter Bilstein 6112 1.9” clip Bilstein 5100 - rear Coachbuilder +1’s Nitto Ridge Grapplers 285/70/18 Audio: Infinity dash speakers Tech12Volts custom center dash speaker Hertz Uno door speakers JL Audio RD 900/5 amp 2 JL Audio 10w-0 v3 10” subs in custom Tech12Volts box Protection: McGuard Tailgate Anti theft lock OEM tailgate lock w/ Dynamat TRD Pro skid plate SNS ARB sensor guards Misc: TRD key fob case AJT Designs Rear diff breather mod Fortin remote start with Car Link CL6 TRD battery bracket by Coupe TRD valve stem caps TRD interior handle inserts by abomb60 (Adam)
    I ran both harnesseson top right in front of the radiator where the foam piece is. I had an hid kit installed before these headlights and ran that harness in the same location for almost a year without issue. The harness is short but it will reach without extensions.
    As for the adjustment I preferred using an 8mm socket and turning the white nut on the back of the headlight. The Phillips felt like it may mess up the metal piece it turns. You can reach that piece at any time (I.e. Grill on or off). I will suggest checking all functionality before putting the grill back on. I stupidly made that mistake.
    Also like @iHacker I used 18 gauge wire to extend the switchback. Soldered and finished with liquid electrical tape and heat shrink so no moisture can reach the connection.
    Finally the relay, I didn't like how it sat on the battery post so I zip tied it to the frame right in front of the battery. It hangs nice and upright there.
    LKSR5-14[QUOTED] and iHacker like this.
  15. Feb 10, 2017 at 5:15 PM
    #135
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Thank you so much. Well I learned few more things now. I run into the dark and had to stop for tonight. Also it's crazy cold here in Chicago to be outside for long period.
    I still need to figure out where to attach computer (ballast) for each side and try to easiest way locate pink and red wires on each side to tap on it.
    Definitely would like to have switchback functionality on halos/LED strip.
    Where did you attach black ground wire from LED strip?
  16. Feb 10, 2017 at 5:23 PM
    #136
    RW-3
    Rob
    16 Black TRD CM 4x4
    For the computer ballasts, on the drivers side I zip tied it to a piece of the frame below the outside edge of the headlight. Hard to describe but if you look through the fender in the wheel well (where you removed the 2screws to take the panel off below the light) I mounted it to the piece of the frame that you see there but on the side closest to the bumper.
    On the passenger side I zip tied it to the vertical piece of frame on the outside of the radiator. I zip ties just the top so the bottom could extend out to make all the wires connect.
    For the ground wire on the led strip I used the nut that is recommended by @eledobleu in the set up picture at the beginning of this thread.
  17. Feb 10, 2017 at 5:43 PM
    #137
    iHacker
    iHacker SW TRD PRO
    Mario
    To mount the ballasts I used Velcro patches and attached them to the headlights but with connectors facing down 6f6fdf558f15852ce39305e719ff812a_918093105ba60bc01763f65b7e19fd516e31a779.jpg
    HUTCHJ, RW-3 and LKSR5-14[QUOTED] like this.
  18. Feb 11, 2017 at 2:07 PM
    #138
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Finally done with installation and very happy with results but still haven't tested level of headlights.
    c326714005d2ffd8b07883b1632ca18d_cb83f47a9a09076679fd1c8c16b2b5fc3d59d5c8.jpgd3bb963a53cf57352fbf915839013480_ea7cc0ff3827a7afdac74f15f928e6d35068d6fc.jpgad5e4d369142ade3141a9e2cfc37ffc9_ad56609af7a6848135f54232f43324949dceaf34.jpgdfcfd0145c93b9e0bd1739637d82228c_2b55e7bdadb39f201170e54eb7a7b95726f8aa25.jpg5e1b4793f8ed32323d8620f3699f346f_ef71c1cc083b154acf932a237b30b2ffa838a724.jpg035a3c9c38fedf1fd3e197125dc803c0_a061c81822dcaa007e0d0b02b836132b76c05db5.jpg603754638a77a9c578e7365e226ef873_e633c03f1b695d73514dec1e680912b1383c9f09.jpg319dbaed9373750624598cb0ac14e7ad_2653608af1dd6004435db1aa98de2166e1b7d0b4.jpg83176d758e8e41ce5018257d636b6d0c_1f212b3d629267da2f5dc7f1b086c7ab2d8ad361.jpg
  19. Feb 11, 2017 at 2:12 PM
    #139
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Under dashboard toward center console next to tire pressure reset sensor notice one plug just in air. Do any of you notice this wire and do you know what it is for? I'm not sure if I unplug it while removing cover or it was already loose. I was removed panel to unplug small gray wire to disable factory drl.
    Any help would be appreciated.
    1f0aa2f7c218e5c324d204fa56f4c1d5_540cddfddf53cc95b101afefcdd151df8cef09ca.jpga78f6bfa114eb0d07f1e2d8f4f5b7666_8344694a2a98ab46514c82f138520e507684fa78.jpg8682171b6199194ab5234a6807033d0a_da892e74658b2caa767ebef02ebfecdcc544e8a2.jpg659a34d4842cd7bb9ecfe61a3658731c_6d146358a144978df9951601a9f0c741b3c0fe35.jpg
    iHacker likes this.
  20. Feb 11, 2017 at 7:30 PM
    #140
    iHacker
    iHacker SW TRD PRO
    Mario
    Wow nice setup your headlights look cool :thumbsup:
  21. Feb 11, 2017 at 7:35 PM
    #141
    iHacker
    iHacker SW TRD PRO
    Mario
    The plug have a place there close to the big connector in your pic but isn't in use I'm not sure what's the use for that plug but in my truck is only inserted in. Maybe for an add on in the higher trims not present in ours (Parking sensors, lane departure warning, etc)
  22. Feb 11, 2017 at 8:17 PM
    #142
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Probably that's the case. Thanks
  23. Feb 11, 2017 at 8:20 PM
    #143
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Thank you and thanks for all your help. Still need to adjust levels. Also I recently notice little shaking or flickering on left side but after minute disappeared. Not sure what could be.
  24. Feb 11, 2017 at 8:22 PM
    #144
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    I have put it in that place since I could not figure what is for. Probably it's front sensors.
  25. Feb 11, 2017 at 8:26 PM
    #145
    iHacker
    iHacker SW TRD PRO
    Mario
    What kind of projectors did you go for your retrofit?
  26. Feb 11, 2017 at 8:28 PM
    #146
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    RX350
  27. Feb 11, 2017 at 8:32 PM
    #147
    iHacker
    iHacker SW TRD PRO
    Mario
    Mine had a flicker too, check for your ground points to be doing a perfect contact and if they are ok check the pigtails in each 9006 connectors that was my case one of the pigtails in the driver side was loose and not making a good contact so my bulb goes off after a few seconds.
  28. Feb 11, 2017 at 8:41 PM
    #148
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    I tight it well ground wire, not sure what else
  29. Feb 11, 2017 at 8:49 PM
    #149
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Just hour ago from Chicago Auto Show
    d123f7cce40ee8b20b40f750d069dae3_a4574f5d7ad7c36234dfc2fbe6fba1a06eae08b3.jpg23cb144c6484f7c0f27474c62bfe379c_f0ec8d9fb2cc90a45572ba8588842f5c1ee43a51.jpg734884471b75560fa7a65186af3a117e_2c03ff2599e4209ebbe7ae2d9c7fab9caf8afdc8.jpg
  30. Feb 18, 2017 at 6:19 PM
    #150
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    There is a lot of very useful information in this thread. Thanks to all.
    LKSR5-14 and iHacker like this.
