HOW TO: Retrofit Install Guide (by EleDobleU)
Discussion in 'Lighting' started by eledobleu, Dec 9, 2016.
  1. Jan 14, 2017 at 12:06 PM
    #91
    stefan702
    stefan702 IG: 702stefan_
    Randy
    Las Vegas
    2015 Tundra TRD Offroad
    IG: 702stefan_
  2. Jan 16, 2017 at 10:30 AM
    #92
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Ok here the video and pictures of my headlights in action :)
    e4f7b9884580733e0bf20cef6b0e8e49_4e5657c7be2946ed0f244d4fb857655dcdbd7ab5.jpg20c8bdc85e3f724dee882d3700c0d98a_5e34a6921788a66c615a36a3b1d05dcf20852423.jpg0e7ab95f175bf59d802b36a39fedc1bc_4e05a0e8595d05bed78504df87387dd5c42f3dcf.jpgb51d3cdc84d1359db1b7b29d7b569762_04a8a9a523ebe1f4d9c876b6dab819eb5a50a26b.jpg8dcd2a5fd2b31b1a1c82543b4af2cbf0_f852bc007d69ef36c4e43d489f2872c28ad8a90e.jpg2e6cf893448b0836126c52dd9d09c350_16e3f694a9ff77f2b023b4a391abea8648e63ff8.jpg
    DRLs OFF (ON/OFF from a dashboard switch in cabin)
    3cb065bf68bc7e1ccc48d1999f76ca39_22a119e121cfcba0170fb5fede0d96da2a98e506.jpgfdaea1b21c4ebc9bfcaa1a09989e6709_c2fe3071a833e95bb0a15a95f0d1ac28d487a122.jpg486f0f630829073aadf477f313f1aa37_f9a866e5cdb1f42c1adaa44c91d175858ccfd4d2.jpge4d5cefd9eb176c5d67500a6714a5fe1_e2b4590d390a7d75fbd98ec0afc73d35eb5b0fe1.jpg
    Just DRLs ON
    Cutoff against a wall (my driveway is inclined that's why is so high from the floor, used this marks just as a reference and have to check later on a level surface)
    Video
    https://vimeo.com/199701863https://vimeo.com/199701993
  3. Jan 16, 2017 at 10:51 AM
    #93
    stefan702
    Randy
    Las Vegas
    IG: 702stefan_
    jtav2002 and iHacker like this.
  4. Jan 16, 2017 at 11:03 AM
    #94
    iHacker
    iHacker SW TRD PRO
    Mario
    I had FX-R 3.0s before in my Tacoma this time went with the Mini D2S 4.0, yours look good a long way better than stock halogens :)
    stefan702[QUOTED] likes this.
  5. Jan 16, 2017 at 11:10 AM
    #95
    stefan702
    Randy
    Las Vegas
    IG: 702stefan_
    I love "yours look good a long way better than stock halogens"
    Of course they do! Look at that output and crisp cutoff!!
    iHacker[QUOTED] likes this.
  6. Jan 16, 2017 at 11:32 AM
    #96
    iHacker
    iHacker SW TRD PRO
    Mario
    Haha, I was trying to resist the impulse, when I get the truck I felt that was driving blind in the dark then I bought Phillips LED bulbs knowing that a retro is the best option but most expensive too, they looked good but still not what I'm used to, finally decided to pull the trigger and now I'm were I wanted since day one no regrets.
  7. Feb 3, 2017 at 9:53 AM
    #97
    RW-3
    RW-3 May the Mods be with you
    Rob
    16 Black TRD CM 4x4
    Lights: 2018 OEM Black Chrome LED’s Morimoto XB Fogs Interior LED upgrade - VLED’s LED reverse / cargo - VLED’s Footwell lights, vanity lights, break lights, rear turn signals, 3rd break light - All VLED’s 30” Rough Country light bar hidden in bumper w/ Rago Fab Brackets Matt Gecko LED bed lights (red & white) and hood lights Exterior: Truxedo Lo Pro QT WeatherTech in-channel window deflectors Interior: Husky X-Act Contour front & rear Front, back and rear windows all tinted 10% Ceramic Heat Film on Windshield 70% OCD console organizer OCD console tray TRD 4x4 inserts on Husky mats by Achuop Tacoma TRD Pro shift knob with TRD leather boot AJT Design vent ring trim - chrome delete Center console wireless charger Drivers side grab handle Performance: Dirty Deeds BA Muffler 12” Budget Standard System TRD Rear Sway Bar AFE Pro Dry S Air Filter Bilstein 6112 1.9” clip Bilstein 5100 - rear Coachbuilder +1’s Nitto Ridge Grapplers 285/70/18 Audio: Infinity dash speakers Tech12Volts custom center dash speaker Hertz Uno door speakers JL Audio RD 900/5 amp 2 JL Audio 10w-0 v3 10” subs in custom Tech12Volts box Protection: McGuard Tailgate Anti theft lock OEM tailgate lock w/ Dynamat TRD Pro skid plate SNS ARB sensor guards Misc: TRD key fob case AJT Designs Rear diff breather mod Fortin remote start with Car Link CL6 TRD battery bracket by Coupe TRD valve stem caps TRD interior handle inserts by abomb60 (Adam)
    How did you wire the LED's to the parking lights without splicing?
  8. Feb 3, 2017 at 10:05 AM
    #98
    RW-3
    Rob
    16 Black TRD CM 4x4
    @iHacker do you have a write up on how you wired your lights? Looks like you have full use of the stock ambers as DRL's and turn signals but you can also run the LED strip any way you like (I.e. With the stock ambers or without,switchback works and they aren't dependent on the headlights being on). I'm about to install my retros and I've been trying to conceptualize this. If you do the DRL delete mod the stock ambers will only work as turn signals or flashers correct? Then you wire the LED strip into the stock amber wire. Do the stock ambers then function as DRL's again because it's tapped into the LED wire harness? Or will the stock ambers still only function as turn signals and flashers? Also if anyone has accomplished the switchback install without cutting factory wires, can you please share? Thanks!
  9. Feb 3, 2017 at 12:48 PM
    #99
    iHacker
    iHacker SW TRD PRO
    Mario
    Sorry I didn't took pictures of the install or have a write up, but the install is very simple, first thing to do is the Amber DRL disable mod, the bulb still work as parking lights and of curse as turn signal and flashers, if you want to use the LED strip as switchbacks just connect the orange wire coming from the led strip to the red wire on driver side and to the pink wire in driver side. If don't do the Amber DRL mod the led strip will be always Amber. I enlarged the supplied harness to reach the cabin and just T-Tapped to a circuit running only with acc i used a test light and used the oem ground point in the cabin for black wire you can add a switch like I did if you want too.
    I ended up disconnecting my orange wire to keep my led strip white all the time i think they look dimmed in daylight in contrast to the Amber OEMs
    I didn't had to cut any factory wires just used t-taps like the ones in the pictures f425dbb9e65d94cb6bf7ab1302ea1846_509e609fdd6653958c85a2fc0e95c39178662148.jpg47e4c4e2b34e519c140bd71c0538c0dc_6653b88db17292d27f20202f02791fc15a41ad94.jpg579b8d9873b9d73721aecb9db8607bd6_79fca6b597cde883c333f3d6a160c0024542a4fe.jpg
    RW-3[QUOTED] likes this.
  10. Feb 3, 2017 at 1:32 PM
    #100
    RW-3
    Rob
    16 Black TRD CM 4x4
    Awesome! Thanks for the info sir.
    iHacker likes this.
  11. Feb 8, 2017 at 10:13 AM
    #101
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    What wire gauge is the one I need to buy if you remember? Is there several sizes or only one size?
    I will have LED strip light switchback and also halos switchback so I was wondering if someone did tap wires to turn signal and disable factory DRL. I will need connect both LED strip light and halos as DRL but would like to disable factory DRL. It will be white/amber light (halos/LED strip). Any suggestions or pictures how did you finish it? Please advise because I am new to this and never done such a thing before in my life. I just would like to do it right on first place. I have Tundra 2016 and any help ifs welcome. I have eledobleU doing my lights now and should have them back on Friday. Is there necessary supplies I should get before I get the lights back such wire T-Taps, split wire loom tubing , dielectric grease etc.
    Thanks in advance!
    Bob likes this.
  12. Feb 8, 2017 at 12:06 PM
    #102
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Would be really great if someone can make video about connecting new LED DRL along with del mod. It would be very helpful to all of us amateurs ☺️
    I know time if big factor but would be great if someone who is knowledgeable to do it and post on here and YouTube
    Send from gym Galaxy 7E
  13. Feb 8, 2017 at 2:20 PM
    #103
    iHacker
    iHacker SW TRD PRO
    Mario
    16-18 gauge wire t-tap worked great for my installation,
    LKSR5-14 likes this.
  14. Feb 8, 2017 at 2:22 PM
    #104
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Thanks a lot. I'm actually just at auto zone store. Great timing ☺️
  15. Feb 8, 2017 at 2:23 PM
    #105
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Can you please post some pictures how you run the wires?
  16. Feb 8, 2017 at 2:49 PM
    #106
    iHacker
    iHacker SW TRD PRO
    Mario
    I'll try to get some pictures for the places to tap the wires in the harness tomorrow, right now I'm not at home to do it
  17. Feb 8, 2017 at 2:51 PM
    #107
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Great. Thanks a lot for that help. I would like to disable OEM DRL and connect halos/LED strip light as a DRL.
  18. Feb 8, 2017 at 3:05 PM
    #108
    iHacker
    iHacker SW TRD PRO
    Mario
    Do you have the retrofitted headlights already?
    I'm petty sure Leo wire everything together for LED strip and halos in a single wire he did on mine
    LKSR5-14[QUOTED] likes this.
  19. Feb 8, 2017 at 3:30 PM
    #109
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    I will get them on Friday morning.
  20. Feb 8, 2017 at 3:32 PM
    #110
    RW-3
    Rob
    16 Black TRD CM 4x4
    Here is a pic I took real quick of where I tapped into the existing drl wire. Not a great pic but I pulled the pink wire out of the sheath and used a tap splice to connect it to the switchback wire on the headlight. I actually added some additional wire to the switchback wire coming from the headlight so I had plenty to work with.
    Like @iHacker said the led wires from the headlight already have a plug on them and you just connect that to the led harness. It plugs into your fuse box for power and you have to ground it.
    For the drl delete follow the instructions that @iHacker posted earlier on this thread. You can push it out of the harness with a thumb tack. Watch the video he posed up about popping the pins out of the plug. It's helpful. It did take some work, but the wire will pop right out.
    Hope this helps, I just installed mine last weekend. Feel free to ask questions.
    iHacker and LKSR5-14[QUOTED] like this.
  21. Feb 8, 2017 at 3:34 PM
    #111
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Thanks a lot guys.
    iHacker likes this.
  22. Feb 8, 2017 at 4:11 PM
    #112
    iHacker
    iHacker SW TRD PRO
    Mario
    Here you go @LKSR5-14
    DRL DELETE MOD
    1. Remove dash panel (in cab). It's the panel where the mirror controls, door light switches and leveler knob is.
    2. Locate Flasher Relay
    3. Locate the SMALL GRAY WIRE (not the big wire). Its two vertical rows, it will be on the first row of wires.
    4. Cut small gray wire.
    Done.
    In this process I just popped out the gray wire pigtail I don't need to cut the wire just in case I decide to go back to stock to sell or trade in my truck, if this is the case just pop in the pigtail again and simple as that
    c81a23fb79c898524574ab9c2049238f_7ab2f39f294d697261c747e1c825f9408136faef.jpg1198b4ba9b672d6e37649fa5aba171b0_f78dba77d4c7c0b8f38f24ba237bd14b3eea70f1.jpga60f4e9db85d63499d08aef0a1d7c3fa_5749e7258ca06b7f0d7139e9a7cc76f50f74d114.jpg
    I used a thumbtack like this one to take the pigtail out of the connector c15b3c4a2e0b8b3409dfdbd27af17589_c6e49e381e08439ae871996ae1f1d842abe29a6c.jpg
    And sorry didn't took pictures or a video on how to do it step by step but I found this video, our conector is almost the same kind
    Just release the latch that prevents the pigtails from loosening or taking out, insert the push pin and pop out the pigtail from the conector
    In the video go forward to 8:30 where he starts doing what I'm talking about, I hope this help out because I know there's a lot of people like me that hate cutting factory wires
    https://youtu.be/CFM-6ovP_-k
  23. Feb 8, 2017 at 4:41 PM
    #113
    iHacker
    iHacker SW TRD PRO
    Mario
    This is the perfect picture to show you were to tap the orange wire coming from the LED strip to make the switchbacks work thanks @RW-3 the passenger side wire is pink like the one in the picture and for driver side the wire will be Red of curse this is coming from the DRL/Blinker OEM conectorbbe11e57c164a6dae2034f7e1cb498f2_c596f4debbad8b48315b089ed052d383bbf869f3.jpg
    RW-3 and LKSR5-14[QUOTED] like this.
  24. Feb 8, 2017 at 4:42 PM
    #114
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Great explanation, thanks to both of you guys
    iHacker[QUOTED] and RW-3 like this.
  25. Feb 10, 2017 at 9:57 AM
    #115
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    How do you adjust level, not sure of location for adjusting with philips screwdriver?
  26. Feb 10, 2017 at 9:58 AM
    #116
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    I got my headlights and planing to do install in few hours.
  27. Feb 10, 2017 at 10:13 AM
    #117
    iHacker
    iHacker SW TRD PRO
    Mario
    Adjust Vertical Beam
    Is kind of a vertical channel in the back of each headlight
  28. Feb 10, 2017 at 10:14 AM
    #118
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Hmmmmmm I could not see it and that philips lol
  29. Feb 10, 2017 at 10:15 AM
    #119
    iHacker
    iHacker SW TRD PRO
    Mario
    Goes straight down to the leveling motors
  30. Feb 10, 2017 at 10:15 AM
    #120
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    So you adjusting it before you put front grill correct
