How to Reset Oil Change Reminder / Maint Req'd Light
Discussion in '2nd Gen Tundras (2007-2013)' started by Nor7, Feb 23, 2016.
  1. Feb 23, 2016 at 7:25 PM
    Nor7
    Nor7 [OP] Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    So I changed my own oil a few months ago and my 'Maint Req'd' Light has come on. I looked into it and found out how to reset it. It's the most elaborate compared to any vehicle I've ever owned. I did a search here and didn't find it so hopefully this helps someone out and I apologize if it was already posted.
    1: Turn key on and change odometer to Trip A
    2: Turn key back off
    3: Hold down odometer button
    4: With button still held down, turn key to 'on' but don't start the truck
    5: You will see a count down in place of Trip A that has some dashes '-----' and they will tick down to nothing. Keep holding until Trip A is back on the LCD.
    6: Done
    Pat, TheBeast, Les7311 and 2 others like this.
  2. Feb 24, 2016 at 12:33 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    That is kind of a ridiculous series just for something as simple as resetting an idiot light. I've had all of my services done at the dealer so far. A couple services back, they forgot to reset it so I stopped back in on my next trip to town. This would've been handy to know then so I wouldn't have had to make the stop. Thanks for the info! :thumbsup:
  3. Feb 24, 2016 at 5:37 AM
    My Tacoma was the same way for the maintenance light. The Tacoma also had a similar sequence so you could shut off the seat belt chimes which you can't do on the Tundra. I keep a copy of the maintenance light routine in my glove box.
  4. Feb 24, 2016 at 5:42 AM
    Delmarva
    Delmarva Former Mayor
    Tucson, AZ
    12 TRD RW
    Has to be on Trip A? Tacoma would do it from any display on the mileage readout... at least on my 06 and 09 Tacoma.
  5. Feb 24, 2016 at 6:07 AM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Yes has to be in trip a.
  6. Feb 24, 2016 at 6:13 AM
    Delmarva
    Tucson, AZ
    12 TRD RW
    @Virgils12
    Virgilus11 perhaps? I sold your old Tacoma and bought a Tundra... 100k miles on her and fairly rock sold... well after the new third member went in and 3 wheel bearings... :)
  7. Feb 24, 2016 at 6:14 AM
    Virgils12
    Nope sorry not me.
  8. Feb 24, 2016 at 6:16 AM
    Delmarva
    Tucson, AZ
    12 TRD RW
    Ahh bummer... figured it was you - c'est la vie :)
  9. Feb 24, 2016 at 4:56 PM
    Don't remember exact sequence for my 09. I was able to google it at the time. Even though this is the best Tundra forum, Tundra HQ is a good source for most of that type of info. Tundra HQ is not really a competitor to any Tundra forum. It's mostly an info site.
  10. Feb 25, 2016 at 4:16 AM
    vulcanguy
    vulcanguy New Member
    2011 Black Limited Luccese TRD
    To Come
    Perfect Timing ! Mine came on 2 days ago .
  11. Jun 25, 2016 at 12:40 PM
    glewis25
    glewis25 New Member
    Watch this video on how to reset the maintenance require light on a 2007 Tundra; pretty sure others are similar.
    https://youtu.be/EsTNcp1hsYc
    Yotalover88 likes this.
  12. Nov 27, 2017 at 5:12 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Thank for the post and in time for my changing
  13. Nov 27, 2017 at 5:21 PM
    Anyone put the fumoto valve on ther Tundy?
  14. Nov 27, 2017 at 5:24 PM
    Les7311
    What’s zat?
    TheBeast likes this.
  15. Nov 27, 2017 at 5:31 PM
    It's a on off valve you put in place of your drain plug...and you can buy a tube as well less mess on oil change...Fumoto Valve ...look it up
  16. Nov 27, 2017 at 5:33 PM
    TheBeast and Les7311[QUOTED] like this.
  17. Nov 28, 2017 at 6:10 PM
    Les7311
    So short of removing the drain plug at the middle of the oil filter, which I couldn’t remove, I did a one time turn of the filter cap came loose
    Don’t see the purpose of that oil filter drain plug!!!
  18. Nov 28, 2017 at 7:15 PM
    Les7311 likes this.
  19. Nov 28, 2017 at 7:19 PM
  20. Dec 5, 2017 at 8:18 AM
    GI Joe
    GI Joe New Member
    Joe
    ‘07 CM 4wd TuRD
    I’ve had the Fumoto on previous trucks And currently have one on our Pilot. Very much makes for a clean service! I’m debating puttin one on my TuRd, as I use Amsoil 15k mile interval oil and filter. The valve price just doesn’t work for me right now.
