How to remove upper control arm from spindle?
Discussion in '1st Gen Tundras (2000-2006)' started by potoghi, May 27, 2021.
  1. May 28, 2021 at 9:03 PM
    #121
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Here was my setup for pressing the new ball joints into place. This is using the $50 rental O’Reilly set that is free when you return it.
    I seriously hope that everyone knows that tool rentals like this are free. They charge you up front, then when you return it within 48 hrs, it refunds your card. All you need is a debit or cc that will float the amount for a few days. This was lost on me when I first got into this stuff and was always so afraid of wasting money.
    bmf4069, Darkness and potoghi[OP] like this.
  2. May 28, 2021 at 9:10 PM
    #122
    potoghi
    potoghi [OP] Tundra4Life
    Hawaii
    United States
    Dang I should of went to oreilly to get my rental tools. I got some rental tools from autozone but the kits don’t have many options to choose from.
  3. May 28, 2021 at 9:14 PM
    #123
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    O’Reilly was my go to for rental. I did my entire 4wd swap with hand tools and stuff I could rent. Minus an impact here and there for stubborn bolts.
    Advance Auto was cheapest on fluids, O’Reilly had the rentals and I avoided Autozone like Trump avoids taxes.
    MS22, tdrich7, BubbaW and 2 others like this.
  4. May 28, 2021 at 9:16 PM
    #124
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I bought mine from harbor freight. Probably didnt cost more than $50, and i use it on all kinds of stuff i shouldnt.
  5. May 28, 2021 at 9:17 PM
    #125
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You are my kinda people.
    potoghi[OP] and Sirfive[QUOTED] like this.
  6. May 28, 2021 at 9:18 PM
    #126
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    You had me interested till that last lame analogy. You're great, we get it.
  7. May 28, 2021 at 9:18 PM
    #127
    potoghi
    Hawaii
    United States
    I noticed your profile header says SATX. Are you from San Antonio? I moved here about 2 years ago lol
  8. May 28, 2021 at 9:22 PM
    #128
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, between boerne and bulverde. Been here about 4 years. No complaints yet.
    potoghi[OP] likes this.
  9. May 28, 2021 at 9:24 PM
    #129
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    bmf4069 and potoghi[OP] like this.
  10. May 28, 2021 at 9:25 PM
    #130
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Im not saying a balljoint press wont punch a hole through 16 ga steel, but im not not saying that. I did some work for a gasket shop that also rebuilt hydraulic cylinders and made lots of adapters out of shaft off-cuts.
  11. May 28, 2021 at 9:46 PM
    #131
    TILLY
    Massachusetts
    Same lame meme over and over. :facepalm:
  12. May 28, 2021 at 11:52 PM
    #132
    potoghi
    Hawaii
    United States
    we is almost there
    Darkness, Drainbung, bmf4069 and 4 others like this.
  13. May 29, 2021 at 12:13 AM
    #133
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Working late! Keep it up! The next side should be a breeze.
    Did you remember the retaining clip on the OEM ball joint? I remember when I did mine they were covered in dirt, and stuff. I pressed, and pressed, and pressed, and pressed. Didn't budge. I even bent the C-clamp style press....
    Finally I thought to look for a clip. :crazy::facepalm:that was my major malfunction.......
  14. May 29, 2021 at 12:39 AM
    #134
    potoghi
    Hawaii
    United States
    Lmao I spent like a day making sure I had everything I needed and how to do it. But I thought I could jimmy the bal points in without the tools. I was wayyyy wrong lol. Next time I’m gonna make sure I get all the tools I need before starting.
  15. May 29, 2021 at 12:41 AM
    #135
    potoghi
    Hawaii
    United States
    Also here’s how I got the ball point out using the tool. The rental from autozone doesn’t really have the correct parts so it’s a pain to get positioned because it was slipping and falling all over the place. But it works when it’s finally positioned well lol
    edit: I also hammered it down when it was too stiff to twist then I just repeated the process until it popped.
    Darkness, bmf4069 and Tundra2 like this.
  16. May 29, 2021 at 1:02 AM
    #136
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I had to heat the threaded part to get the ball joint "stud" to pop out of the threaded tube.
    I completely removed my spindles/knuckles stuck them in the tailgate seam between the bed, and tailgate to act as a second pair of hands. I work alone typically.
  17. May 29, 2021 at 1:03 AM
    #137
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Looks like you and I had the same kit from autobones.
    potoghi[QUOTED][OP] likes this.
  18. May 29, 2021 at 5:20 AM
    #138
    Professional Hand Model
    Hand Protectors
    :bananadead:
    You are Flying on the edge of Mangle Club here. :rofl:
  19. May 29, 2021 at 5:26 AM
    #139
    Hand Protectors
    I blocked that guy 6 months ago.
    Drainbung and Tundra2 like this.
  20. May 29, 2021 at 9:01 AM
    #140
    tvpierce
    tvpierce Formerly New Member
    Maine
    That's why you keep the nut threaded up to the top of the stud: it distributes the force so the end doesn't mushroom. Works on any taper-fit joint.
    Drainbung, Darkness and potoghi[OP] like this.
  21. May 29, 2021 at 12:39 PM
    #141
    Hand Protectors
  22. May 29, 2021 at 1:28 PM
    #142
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    Gotta love the IGNORE function!
  23. May 29, 2021 at 2:13 PM
    #143
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I’ve got a new hand gig for ya.
    Tundra2 and potoghi[OP] like this.
  24. May 29, 2021 at 2:15 PM
    #144
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  25. May 29, 2021 at 2:22 PM
    #145
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Never understood the blocking/ignoring of folks. We all can be assholes at some point in time but even assholes can share good info from time to time !
    On topic....this thread has been entertaining and knowledgeable that was both a How to and How Not To !
    Kudos to the Hawaiian !
    Barrett50 and potoghi[OP] like this.
  26. May 29, 2021 at 2:34 PM
    #146
    Drainbung
    Bob
    Oasis of NV
    TRD Fleshlight
    Any pics of the finished product? Stop toying with us, damn you!
    Barrett50 likes this.
  27. May 29, 2021 at 2:40 PM
    #147
    Hand Protectors
    It works wonders! I never understood it either until I used it.:thumbsup: The other nice option feature is eliminating signatures which take up valuable reading space.
    Did someone say something?:rofl:
    Drainbung likes this.
  28. May 29, 2021 at 2:46 PM
    #148
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Sigs dont show up until i turn my phone sidewards.
    Tundra2 likes this.
  29. May 29, 2021 at 2:48 PM
    #149
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Did someone bring up something about signatures :rofl:
    :benchpress:
  30. May 29, 2021 at 3:04 PM
    #150
    Hand Protectors
    Yeah. I don’t do phone internet time so when on the main vein when all I see are half page sigs it got old. I saw the function to eliminate sigs and man! my reading time became easier. Eliminates clutter from the screen.
    Tundra2 and Sirfive[QUOTED] like this.
