How to remove a chipmunk nest
Discussion in '1st Gen Tundras (2000-2006)' started by Doug, May 28, 2020.
  1. May 28, 2020 at 7:34 PM
    Doug
    Doug [OP] New Member
    Doug
    2000 Tundra TRD
    Shell
    Some chipmunks have made a nest in my 2000 Tundra. I can't see it, but I have heard them making noise somewhere near the bottom of the passenger-side firewall. Am important clue is that when I tried turning on the vent, no air came out, a small fragment of grass came through the vent, then the fan seemed to get stuck. Is the vent fan on the engine side of the heater core, or on the passenger side? I'm pretty sure the nest is not on the passenger side. Any advice on how to access the nest? Can anyone recommend a link to an exploded parts diagram of the vent system? Thanks!
  2. May 28, 2020 at 7:45 PM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Pull the cowl and inspect that whole area. The clips have tiny little gaskets that dry up over the years and tend to allow water past - sometimes resulting in leak(s) directly atop the flap door that opens the "fresh air" vent. This'll cause a drip down your blower motor onto pass floor. Cheap fix = caulk or custom gasket.
    You'll still be able to see over to the driver side once you pull it. You sure its chipmunks and not mice? Mice can go just about anywhere they want - chipmunks not so much.
  3. May 29, 2020 at 5:09 AM
    Professional Hand Model
    Hand Protectors
    Lay down on the pass side floor and you’ll see a round Blower thingy with 3 bolts. Remove bolts and unplug the Blower motor wire. Watch the critters runnnn!!!
  4. May 29, 2020 at 5:22 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
