How to lower icon coilovers
Discussion in 'Suspension' started by Payaso 9394, Jun 13, 2017.
  1. Jun 15, 2017 at 9:54 PM
    comai8981
    comai8981 The payment is the cheap part!
    Joe
    Murrieta, CA
    2016 TRD PRO Crewmax
    Coach Builder .5" shim w/ +3 shackles K&N intake/filter
    Are you running shackles and the AAL?
  2. Jun 15, 2017 at 9:56 PM
    Payaso 9394
    Payaso 9394 [OP] New Member
    Ricky
    La Puente CA
    16' Tundra 2wd CrewMax 5.7l
    Tint, 33x12.5r18
    Yeah touted shackles
  3. Jun 15, 2017 at 9:56 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
  4. Jun 15, 2017 at 10:16 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
  5. Jun 15, 2017 at 10:17 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    And I called icon and they said to remove the overload leaf I'm just crazy confused ha
  6. Jun 15, 2017 at 10:38 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    That is what I thought. Just remove the overload leaf and attach the icon pack. I could be wrong.
  7. Jun 15, 2017 at 10:43 PM
    csuviper
    Broomfield, CO
    "Unlike traditional "add-a-leafs" that obtain lift height at the cost of stiffening spring rate and sacrificing ride quality. This new approach, full length Toyota Tundra leaf spring expansion pack, replaces all the factory secondary leafs while retaining the factory main and overload springs. This allows us to modify the spring rate to increase ride comfort, obtain lift height, maintain load and towing capacities, and increase wheel travel. By retaining the factory main leaf installation is a snap."
  8. Jun 15, 2017 at 10:49 PM
    csuviper
    Broomfield, CO
  9. Jun 15, 2017 at 10:50 PM
    csuviper
    Broomfield, CO
    The add a leaf has a di erent length front to rear of the centering pin. The longer side is to be placed towards the REAR of the vehicle.
  10. Jun 15, 2017 at 10:56 PM
    csuviper
    Broomfield, CO
    I'm trying to understand your front setup. Your 2WD so you don't have to worry about cv angles, just steering angles. The spindles add the necessary added length from the hub to UCA. The lift comes from the coilover however. If you got the standard Coilovers they are most likely set around 2.5" of lift. Do you have a top spacer installed on here as well that matches the spindle added height?
    What am I missing here?
  11. Jun 16, 2017 at 12:16 AM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Front is maxtrac spindles with icon 2.5 coilover with icon ucas I lowered my coilover to half a inch of thread showing so it could hopefully level with the back
  12. Jun 16, 2017 at 12:17 AM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
  13. Jun 16, 2017 at 12:19 AM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    But from what I get it's ones choice to remove the overload spring which is the one at the end right I hope the shop know what there doing it's Atlas Springs they are pretty popular but kinda rude but I'm just dealing with a whole bunch of crap right now so I just hope I could get my truck back on the road to ease my mind a bit
  14. Jun 16, 2017 at 12:26 AM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    What's the normal mid hub to fender measurement for a 4 inch lift
  15. Jun 16, 2017 at 7:43 AM
    comai8981
    Joe
    Murrieta, CA
    I installed the icon AAL on my taco. The install was pretty straight forward. Could have left the overload in but decided to remove it to get the desired lift.
  16. Jun 16, 2017 at 7:25 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Got my leaf pack looks clean going to try to install today but have one more issue now my front seat bar don't fit it hits my tie rods how could I fix it and would a trd rear sway bar work in the back if I lifted it
  17. Jun 16, 2017 at 7:31 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yep
    Payaso 9394[OP] likes this.
  18. Jun 16, 2017 at 7:34 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Even if its lifted my front seat bar don't fit no more but would want it to just can't find extended tie rods or big enough drop brackets for the sway bar
  19. Jun 16, 2017 at 8:22 PM
    #49
    comai8981
    Joe
    Murrieta, CA
    How much are you lifting? You shouldn't have any issues less tha 3"s I don't think...
  20. Jun 16, 2017 at 9:26 PM
    #50
    cheehab
    cheehab Fan Boy
    Southern Maine
    2015 TRD Pro CrewMax
    :popcorn:
    This thread is stressing me out...
    Tundra_361 and Payaso 9394[OP] like this.
  21. Jun 17, 2017 at 12:18 AM
    #51
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    It's 4 inch lift but might be a lil taller cuz I haven't leveled it with the back but it doesn't fit good it hits the tie rods..... the back is almost done just need longer u bolts now haha fml
  22. Jun 23, 2017 at 9:57 PM
    #52
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
