How to learn how to weld
Discussion in 'Off-Topic Discussion' started by Ps3udonymous, Apr 7, 2020.
  1. Jul 9, 2020 at 11:18 AM
    #121
    ZPMAN
    Minnesota
    My best advice for learning how to weld would be to start out with a mig with gas but do a little research on YouTube first. At my work I get alot new grasshoppers wanting to learn how to weld and usually standby with them for an hr or two to learn the basics of the mig itself and then set it up for 1/8 steel and let them go at it. Most wielders come with a guide on the inside cover like this. 20200709_130818.jpg
    Good luck.
    saybng, AgitatedGopher, chugs and 2 others like this.
  2. Jul 9, 2020 at 12:14 PM
    #122
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Rule of thumb is when you increase your volts (heat) you increase your wire speed. This also applies to lowering your voltage, you decrease your wire speed. For mig process it's not a problem, but you should always wire brush your welds. When your stick welding the flux is protecting the weld. Once your done and it cools you just knock slag off. When you get your amperage, rod angle, and travel speed perfect , the slag will roll up behind you. When this happens you are dialed in.
    As far as it burning back to tip, it could be just a dirty tip. The main causes of burn back is a dirty liner, which your wire runs through. Blow it out with compressed air from time to time. Use the anti- spatter, it will help you save on tips. Always clean weld area good, at least 1" away from anticipated weld toes.
    Don't hesitate to ask any questions my fellow welder, I love it and will try to guide you with any problems or questions :thumbsup:
    MotoTundra and AgitatedGopher like this.
  3. Jul 9, 2020 at 12:52 PM
    #123
    kevine0001
    kevine0001 New Member
    Kevin
    I tend to run my wire slower and up my setting just a bit to get better penetration through heat and going slow. I've tried upping wire speed...and my welds look like shit. slow/medium speed works for me. whatever gets you going
    AgitatedGopher and rons23 like this.
  4. Jul 10, 2020 at 2:33 AM
    #124
    rons23
    Ron
    Kill Devil Hills
    Yes Kevin, mig is all about setup. You can dial it in to your liking, but there's a line where your volts and wire speed are not gonna work . You will either lack penetration or loose control of weld puddle.
    Please post pics of your welds. :thumbsup:
  5. Jul 10, 2020 at 4:15 AM
    #125
    ZPMAN
    Minnesota
    My last project was base legs for a work bench.
  6. Jul 10, 2020 at 10:07 AM
    #126
    kevine0001
    Kevin
    I know, surface prep could have been better. This is the side gusset to the mounting bracket on my bolt on sliders. The round weld in the middle is a plug weld into the square tube going from the slider to the mounting plate (bolted to frame). The edges got a nice seam weld, all the way around wherever it touched another piece of steel. This is before I brushed up the weld, or cleaned up the other edges before finishing the welding. Not pretty, but I have yet to have anything break on me while off-roading.
    BashFab and YardBird like this.
  7. Jul 10, 2020 at 10:28 AM
    #127
    ZPMAN
    Minnesota
    Looks good to me, are you pushing or pulling, I used to pull till an old timer got me to start pushing. When pushing you get bettor penetration into the base steel and believe it might look bettor if done correctly.
  8. Jul 10, 2020 at 11:20 AM
    #128
    kevine0001
    Kevin
    on that weld, i believe i was pulling. i'm better at pulling, but depending on the location of the weld and the position i'm in, i can push also. i learned by pulling and just stuck with me a bit. i also tend to hold my gun a little more vertical when i pull, which allows IMO for better penetration. That and the hotter setting on the welder which creates a better pool for my wire speed.
    ZPMAN[QUOTED] likes this.
  9. Jul 12, 2020 at 10:08 PM
    #129
    Ps3udonymous
    Ps3udonymous [OP] Who is the smart ass that changed the title?
    Well got to working on my first project. Couple of issues...
    First, I burned through some of the metal on different spots. Voltage was too high as I was dialing it it. And the other times I went to slow.
    Second, I am pretty terrible at running straight consistent beads. But I've gotten better.
    Third, and worst of all. My last weld (in the picture) of course, the one that is hidden that no one will ever see was the best bead I've done so far.
  10. Jul 13, 2020 at 6:30 AM
    #130
    ZPMAN
    Minnesota
    Looks good!
    First, if possible practice on a piece of same material B4 the starting the main project.
    Second, Beer will help straighten out any weld.
    Third, do the hidden welds first if possible and clean/grind area to be welded.
  11. Jul 31, 2020 at 4:44 PM
    #131
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Any of you welders heard of this brand? If so how what do you guys think?
  12. Jul 31, 2020 at 5:12 PM
    #132
    Azblue
    The Dirty T ( ^_^)_且
    I have heard of the brand only because I bought a cheap auto darkening helmet on eBay from that brand. The helmet works fine, but the head straps are thin and floppy. So, yes the helmet works fine but is cheaply made. I have never tried their actual welders.
    saybng[QUOTED] likes this.
  13. Jul 31, 2020 at 5:24 PM
    #133
    saybng
    Gary
    Ventura CA
    I was just looking around for affordable welders and saw that brand..although I already have Lincoln and hardly used it and want to learn. After looking up my welder I didn't realize that I can actually convert it to use gas..lol.
    Azblue[QUOTED] likes this.
  14. Jul 31, 2020 at 6:05 PM
    #134
    AgitatedGopher
    AgitatedGopher Deer destroyer
    Dallas, TX
    2013 White Tundra and 2006 Green-ish Tundra 4x4
    I bought their hoods for my guys in the shop. They absolutely love them more than the hoods I've been getting from Northern Tool. We have also used their replacement leads on our 240 Millers. No issues.
    So far, it seems to be a solid brand. No experience with their welders though.
  15. Jul 31, 2020 at 6:20 PM
    #135
    kevine0001
    Kevin
    stick with your lincoln
    saybng likes this.
  16. Jul 31, 2020 at 6:28 PM
    #136
    AgitatedGopher
    Dallas, TX
    Our little Lincolns are great for portability and reliability. And parts are a dime a dozen. Bonus factor, they weigh way less than our baby Millers. I can hoist them into the truck by myself. :muscleflexing:
    kevine0001[QUOTED] likes this.
  17. Jul 31, 2020 at 7:26 PM
    #137
    saybng
    Gary
    Ventura CA
    Sticking with the Lincoln for sure..:thumbsup:
  18. Jul 31, 2020 at 10:44 PM
    #138
    ZPMAN
    Minnesota
    I just pick up a Tig welder, boys keep breaking levers on the bikes.
    Tonight a little more practice then fix the clutch lever.20200801_000439.jpg
    snivilous, YardBird and saybng like this.
  19. Jul 31, 2020 at 11:35 PM
    #139
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    which TIG machine did you get? I am in the market for one.
  20. Aug 1, 2020 at 6:41 AM
    #140
    ZPMAN
    Minnesota
    BashFab likes this.
  21. Aug 21, 2020 at 11:36 AM
    #141
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    Solid choice! I have been using mine for everything.. I'm finding it unappealing to even hook my Vulcan 215 up anymore other than shear speed of getting things done. The primeeweld is has been fnatastic
  22. Jul 1, 2022 at 9:07 PM
    #142
    MotoTundra
    MotoTundra The Ocho
    Don
    Reviving an old thread here. Where do you get cheap metal to practice on? Any specific best shaped pieces to learn on?
    Long story short. I broke a bolt while working on my GX470. I am going to have to weld a nut onto the bolt to get it out so I bought a Titanium Flux 125, auto dim hood, gloves, sleeves, and a welding blanket to cover parts of the vehicle. Tomorrow I will be picking up some tip gel and anti spatter spray.
    I watched a few videos and want to start practicing tomorrow.
    Any other tips are appreciated!!
    Thanks.
    ColoradoTJ likes this.
  23. Jul 1, 2022 at 9:16 PM
    #143
    Azblue
    Easy, just wait until the wife isn't looking and then walk around the house. Plenty of stuff around, bed frames, bar stools, lamp posts, shelf brackets, etc.
  24. Jul 1, 2022 at 9:17 PM
    #144
    Outbound
    Aaron
    Northern Alberta
    For cheap metal I'd start by bringing some coffee and donuts to a local fab shop, tell them you're learning to weld then ask if you can root through their scrap bin. Straight pieces you can make basic lap and tee joints with will be the best to start with.
    Before you weld on a vehicle, disconnect the battery. It can help prevent frying electronics.
  25. Jul 1, 2022 at 9:40 PM
    #145
    I would either go to a scrap yard or to a metal supplier/fab shop. They usually have a fair amount of scrap piles and sell it for cheap (scrap going rate).
  26. Jul 1, 2022 at 9:51 PM
    #146
    MotoTundra
    MotoTundra The Ocho
    Don
    haha good call. I’m sure I have some scrap laying around the garage somewhere.
    Good call. I was wondering if any precautions needed to be taken being that I was welding on a vehicle, where to attach ground cable, etc. Didn’t get that far yet though, tomorrow is just practice off the car.
    Good call, will do thanks! I may also practice on some junk nuts and bolts since that is what I will be doing.
