How to get rid of steering wheel shake on TSS
Discussion in 'Wheels & Tires' started by Cvtech1, Nov 25, 2019.
  1. Nov 25, 2019 at 5:46 PM
    Cvtech1
    Cvtech1 [OP] New Member
    2017 Tundra TSS
    Hello, I just bought a 2017 TSS Crew max with 24k miles and it rides very tough at above 75 mph. The steering wheel shakes like it a balance issue. I've seen several issues on this but no real solutions. I like Toyota's but this is my first Tundra and will trade it if it can't be fixed. Please help..
    Pinay likes this.
  2. Nov 25, 2019 at 5:55 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome from SoCal!
    One moment and I’m sure someone will chime in with possible solutions.
    Cvtech1[OP] likes this.
  3. Nov 29, 2019 at 4:24 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Welcome. Have you took it to a different tire shop? What type of tires you have?
  4. Nov 29, 2019 at 5:13 PM
    Welcome from NY.
    Sounds like tires out of balance. How are the tires, any bubbles or maybe a broken steel belt?
    DM 2018 Tundra likes this.
  5. Nov 29, 2019 at 5:22 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    A tire out of balance. Have all 4 rebalanced. But first inspect all tire treads for stuck rocks and insides of all wheels for stuck dirt clods. It doesn't take much.
    Or.....just trade away the problem. Though I'm curious how you "just bought...." and didn't notice this.
  6. Dec 12, 2019 at 11:20 AM
    Erick918
    Erick918 New Member
    Erick
    Kentucky
    2018 Black Tundra Tss
    I had the same issue with my tundra when I purchased it brand new. My tires had to be road forced balanced. I was running goodyears wranglers with Kevlar it had to do with improper tire mounting. some dude at the dealersgip said something about a plate in between that suppose to be centered. cant recall what iy actually was sorry
  7. Dec 12, 2019 at 11:28 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    I had a tire plugged and it never balanced again. Moved it to the rear and the vibrations went away. I'm going to guess its a tire issue, not a Toyota Tundra issue.
    It doesn't even sound like you have had a balance done yet - talk of trading the truck is a bit extreme. Call me crazy but maybe a better first step is moving the front two tires to the rear.
  8. Dec 12, 2019 at 11:41 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    It's actually both. Toyota trucks and SUV's in general are incredibly sensitive to tire balancing issues and the OE BFG's or GY's that come on the TSS models aren't known to be perfect riding tires.
    So sensitive in fact that just the other day I rotated my front tires side to side and am now getting a vibration I never felt before. But the 2 front tires are older than the back 2 and have a little cupping/ feathering on the inside edges. So, oh well. I'll deal with it.
    I have found that the best thing to do is a road force and ride match balance. The ride match will plot the run out of the tire and wheel and will tell you how to turn the tire on the wheel in order to get the assembly as close to a perfect circle as possible.
    Sephon and MistrRoboto[QUOTED] like this.
  9. Dec 12, 2019 at 11:42 AM
    Erick918
    Erick918 New Member
    Erick
    Kentucky
    Yea my tires went bad in the inside so I had to go through the warranty on the tires to get new ones. Yea I had very BAD cupping on my tires
  10. Dec 12, 2019 at 11:48 AM
    MistrRoboto
    Virginia Beach, VA
    Interesting! I'm sure you are right in all aspects of your post, and just want to highlight the stock tires are exceptionally bad. My local Discount Tire had a much easier time balancing my Nitto Ridge Grapplers than the OEMs that I never really got into balance to begin with.
  11. Dec 12, 2019 at 11:57 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I have the same as you, but no issues like that. Sounds like a bad tire or tires that haven't been rotated before you got it
  12. Dec 12, 2019 at 12:02 PM
    Erick918
    Erick918 New Member
    Erick
    Kentucky
    Yea that’s crazy though because that’s how they came when I bought my truck new I couldn’t believe it.
  13. Dec 12, 2019 at 12:13 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    I think the theme here is "Tires," my current Tundra just got new tires and had to be road force balanced, just an FYI.
    My wife's mini-van had an odd vibration only above 75 MPH. Found out at the tire shop that 2 had started separating. Since they were on the van when we bought it, we bought it used, there was no warranty transition. I ended up having all four replaced even though they were almost new.
  14. Dec 12, 2019 at 12:33 PM
    Erick918
    Erick918 New Member
    Erick
    Kentucky
    Yea for some reason like he said on the top post. It wasn’t noticeable unless I went from70-75. If I went higher it would go away
  15. Dec 12, 2019 at 12:37 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Yep, Nitto's always balance better than BFG's or Goodyears.
    I'm pretty certain I will get the G2's when my BFG's are toast. I wouldn't have picked the BFG's but they were on the truck when I got it. Or, I may go 35x1250x20 Michelin Defenders. :crapstorm:
    Erick918 likes this.
  16. Dec 12, 2019 at 6:19 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    If your rims are not center of the hub it can make it happen also. That is what the aliment shop told me.
