How to get constant power to accessory ports?
Discussion in '2.5 Gen Tundras (2014-2021)' started by AleutianTaco, Jun 2, 2023.
  1. Jun 2, 2023 at 2:03 PM
    AleutianTaco
    AleutianTaco [OP] New Member
    Is there a simple way to get constant power supplied to my 12v USB or lighter port(s)?? So annoying when they turn off after the truck shuts down.
    On newer ford trucks you just need to jumper a fuse in the engine bay, super easy. Just not sure on Tundras. Its a 2021 SR5 crewmax.
    Thanks!!
  2. Apr 16, 2025 at 4:45 AM
    JetMac
    JetMac New Member
    2021 Tundra CM
    LED bulb upgrades, Tuffy center console lock box, console drop in top tray, illuminated auto up/down power window switches, fit cam X dash cam, TRD pro LED headlights, LED fog lights
    Really surprised no one’s commented on this, if I knew I’d share but I’m genuinely curious too cause it sure would be nice to be able to use the ports to charge while your in a store or away from the truck.
  3. Apr 16, 2025 at 4:53 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    You could cut the wires to them and attach them to a constant 12v source.
  4. Apr 16, 2025 at 6:45 AM
    sonofdad
    sonofdad New Member
    steamboat springs, co
    2017 Tundra SR5
  5. Apr 16, 2025 at 7:29 AM
    atc250r
    atc250r New Member
    Something to keep in mind is that even when nothing is plugged into the USB charger it is drawing power and will draw down the battery.
    Saltyhero13 and jclem65 like this.
