How to fight water spots from rain water?
Discussion in 'Detailing' started by Henry2019, Sep 30, 2021.
  1. Sep 30, 2021 at 10:18 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    How does one protect their exterior from water spots due to rainfall? TIA!
  2. Sep 30, 2021 at 10:23 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Wash your truck Henry...:eek2::thumbsup:
    Patch999, Tundra234 and nobodyintexas like this.
  3. Oct 1, 2021 at 7:04 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Keep it waxed/sealed/protected. I have a black truck, keep it waxed and it stays dark and clean, even after rain. If you use a good product and handwash vs auto car wash, a wax/seal can last 3+ months.
    nobodyintexas likes this.
  4. Oct 6, 2021 at 11:42 PM
    Freeezen
    Freeezen New Member
    Wax/sealant/ceramic coatings that sheet water more than they bead water can help prevent bad water spots. Everyone likes the pictures of water beading on the paint, but if there is a light coat of dust on your truck, those beads turn into water spots. If most of the water sheets off, then in theory there should be less water spots. You gotta do some google searching to find out for some sheeting products like Apex Surface Protection Rehydra-Sheet.
  5. Oct 7, 2021 at 1:52 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Big fan of Groits products... Need to do a deep strip of old wax first, then prep surfaces, and final ceramic coating... Does well on my slate blue tundy. Good luck
  6. Oct 7, 2021 at 4:46 AM
    Sarcastic Zword
    Sarcastic Zword What’s old is new again.
    Al
    U.S.A.
    2015 Tundra 5.7
    The issue has to do with Environmental Contamination. So what is being washed out of the air by the rain? That depends on location and other factors…wildfires, Industrial, airport proximity, etc…
    Coatings and LSP’s will only do so much for you if the fallout is allowed to sit and dry on the surface.
    LSP’s “may” prevent it when freshly applied but as the protection begins to degrade, that will/may change.
    It may come down to safely removing the rain water before it has a chance to bake in the sun or dry.
  7. Oct 7, 2021 at 6:44 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Yeah my question is what is softer than rain water?
    If it's spotting there must be crap on the truck already.
    In that case, do what the team tells you above, then cover the truck with an all season car cover.
    Bingo!, problem solved and you've added years to the paint job.
