How to effectively remove the cats from my SC'd Tundra?
Discussion in 'Performance and Tuning' started by HulkSmurf14, Jul 27, 2020.
  1. Jul 27, 2020 at 4:12 PM
    HulkSmurf14
    HulkSmurf14 [OP] ...Weighted Average...
    2014 Tundra Limited
    Tastefully enhanced...
    I've been reading a lot about our v8 engines (5.7) when supercharged and I'm curious if one could effectively remove the cats on both ends of sensors and not need to tune out the error codes? Or, if you must remove the codes, what's the best way? I'd like to remove the cats and unlock more sound and power without completely modifying the entire exhaust...Any suggestions...?
  2. Jul 27, 2020 at 4:14 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Could do resister mods to send the ECU that the 02 sensors are ‘behaving’ normal
  3. Jul 27, 2020 at 4:16 PM
    HulkSmurf14
    2014 Tundra Limited
    Interesting...I never considered that as an option, though, my electrical prowess is holding me back a bit...
    Has anyone done this with success...either the resistor addition or removing the cats on their 'charged 5.7?
  4. Jul 27, 2020 at 4:22 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
  5. Jul 27, 2020 at 4:40 PM
    timsp8
    NY
    I removed the cats on my 2010 sc tundra and used that urd o2 simulator and had nothing but problems. Would give codes a lot especially when it got wet. I eventually had a shop weld some high flow cats in. Didn’t notice any power difference.
    HulkSmurf14[OP] likes this.
  6. Jul 27, 2020 at 8:00 PM
    swank501
    swank501 New Member
    2007 single cab 4x4
    TRD S/C Crewmax window conversion Auburn LSD Custom interior
    I wouldn’t do it man. If you want more sound and power get long tube headers and a tune. Simply removing the cats will likely not give your desired outcome.
  7. Jul 27, 2020 at 8:33 PM
    HulkSmurf14
    2014 Tundra Limited
    Good to know...I know boosted vehicles can gum up the cats over time unless less restrictive versions are used...perhaps if anything, high flows installed...or just leave it...
    Thanks for the info. :drunk:
