How to clean cloth seats?
Discussion in 'Detailing' started by Gustavo, Sep 13, 2020.
  1. Sep 13, 2020 at 9:36 PM
    Gustavo
    Gustavo [OP] New Member
    Gustavo
    2015 Tundra SR5
    3” Lift. Bilstein shocks, SPC upper control arm, VLAND headlights
    New member. Been following here for a long time. Don’t know why it took me so long. Need some advice on how to clean the cloth seats. They seam to get easily stained. Any advise is greatly appreciated. Thanks
    TNTundra16 and YardBird like this.
  2. Sep 13, 2020 at 9:39 PM
  3. Sep 13, 2020 at 9:47 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The Pacific South West.
    619Tundra likes this.
  4. Sep 13, 2020 at 9:59 PM
  5. Sep 13, 2020 at 10:58 PM
    ttime4four
    ttime4four New Member
    West Linn, OR
    '20 Tundra Limited DC TRD Offroad
    Welcome.
    I've had good luck with a regular household carpet cleaner with a hand wand attachment. It sprays in hot/soapy water and vacuums it up. Because the hand wand is clear, you can see the dirt being picked up.
    I suspect if you are seeing dirt quickly -- it's probably deep dirt coming back to the surface. The carpet cleaners can clean deep.
    On warm days - the seats dry quickly.
    YardBird and 65SNAKE like this.
  6. Sep 14, 2020 at 12:43 AM
    Gustavo
    Gustavo
    2015 Tundra SR5
    Thank you ttime4four. Will try it out. And thanks all for the welcome
  7. Sep 14, 2020 at 3:50 AM
    CincYOTA
    CincYOTA New Number
    2012 Tundra SR5 DC 5.7 4x4
    I used the upholstery head from my household carpet cleaner too since previous owner was a smoker. The water it extracted was black. I've cleaned it two more times since then including carpets and headliner and smell is almost completely gone now.
  8. Sep 14, 2020 at 3:50 AM
    War Machine
    War Machine SSEM # 5 3MW
  9. Sep 14, 2020 at 4:24 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
  10. Sep 14, 2020 at 5:02 AM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Welcome. Checkout that thread that was posted above. If you have anymore questions, just PM me I can help!
    War Machine, GODZILLA and ToyoMafia like this.
  11. Sep 14, 2020 at 5:22 AM
    65SNAKE
    65SNAKE New Member
    RON
    2020 TRD PRO
    If you know a detailer that has an "ozone" machine...maybe he'll let you borrow it...You let your truck running with the air/heat on inside and the ozonater will help kill most of the smell.
    War Machine likes this.
  12. Sep 14, 2020 at 5:35 AM
    ToyoMafia
    Magic carpet.
    Be real careful with a ozone generator. It can be very bad for your health. I would run it for a bit then roll down all windows and park outside for awhile
  13. Sep 14, 2020 at 7:29 AM
    Cthulhu
  14. Sep 14, 2020 at 8:07 AM
    Ckatz53
    Ckatz53 Newish
    MD
    Never heard of this stuff, will have to check it out. General APC works great for upholstery and headliners. I use 50:1 diluted.
  15. Sep 14, 2020 at 8:19 AM
    Handbanana
    Handbanana New Member
    2018 TSS CM 4x4
    Trd sway front Trd sway rear Trd shift knob Nitto ridge grapplers OEM LED FOGS
    Bissell Multi-Purpose Portable Carpet and Upholstery Cleaner, 1400B, Green https://www.amazon.com/dp/B0016HF5GK/ref=cm_sw_r_cp_api_i_6K4xFbJAFTJ9S
    I have this. It’s amazing and cleans super well. I usually do the whole truck in about a hour and let it air dry with windows down. Do you have to let it air dry otherwise you will get a wet smell inside the truck but you would be surprised how dark the water is after you clean your truck even if you think it’s not dirty. This thing is so easy to use we usually pop it out every six months or before and after a long road trip. Makes the interior look new
  16. Sep 14, 2020 at 8:31 AM
    Cthulhu
    Had some nasty smudge marks in the headliner when Safelite replaced my windshield. Sprayed some on a MF cloth, dabbed the smudges, came right out.
    Ckatz53[QUOTED] likes this.
  17. Sep 14, 2020 at 8:42 AM
    Ckatz53
    Ckatz53 Newish
    MD
    Those bitches.
  18. Jan 10, 2021 at 12:45 PM
    34ford
    34ford New Member
    2018 sky silver DC 5300 miles
    none yet
    Folex carpet cleaner and warm H20. Blend out to edges to eliminate water "ring". 34ford
