How To: Blinker Fluid Drain and Fill Instructions w/Pics
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ponderosa_Pine, Jan 9, 2025.
  1. Jan 10, 2025 at 11:53 AM
    SD Surfer
    Bruce
    So Cal
    I've programmed my HU/Maestsro with the PID's to monitor the BF temps, and determined temps to be well within spec.
    Do I still need to drain/fill?
  2. Jan 10, 2025 at 12:04 PM
    Retired...finally
    Are you aware of the Gen III recall? regardless of how many blinker fluid changes you make, the viscosity of the fluid or the signatures on the bottle, some will just lock up. Sad situation. Especially for the hybrid owners. They get the lock ups but are not included in the recall.:crapstorm:
  3. Jan 10, 2025 at 5:49 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :eek:
    I don't think that means what you think it means... :monocle:
    grant.ducckk likes this.
  4. Jan 10, 2025 at 5:51 PM
    Tripleconpanna
    :eek:
    Black Wolf, OldGuy03 and GODZILLA like this.
  5. Jan 10, 2025 at 6:19 PM
    AZTundra
    Paul
    Phoenix, AZ
    Great Info!
    **Tech Tip #04 - I would also note that before you follow the steps you'll also need to obtain the correct blinker fluid plugs to match the size drill bit you use to drain. Without having the plug on hand you cannot refill the fluid without it too draining onto the ground. This renders you unable to drive to the autoparts store since your blinkers will not correctly function. Make sure you get the plugs before you start the process. My neighbor was forced to take an Uber to Autozone because he forgot to pick them up in advance.
    Black Wolf, bflooks, OldGuy03 and 4 others like this.
  6. Jan 10, 2025 at 6:25 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    Or maybe not… IIRC amsoil blinker fluid is only toxic (or might be) in California.
  7. Jan 10, 2025 at 6:36 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I am surprised it took people so long to notice it =)
  8. Jan 10, 2025 at 6:38 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    This critical information needs to be stickied in the Electrical forum.
    Black Wolf and GODZILLA like this.
  9. Jan 10, 2025 at 7:41 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    This is only true if regular Kanuter valve maintenance has not been done.
    As we know, the Kanuter valve is critical to proper Blinker Fluid injection.
    Service your Kanuters people!
  10. Jan 10, 2025 at 7:43 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    This gets my vote for the post of the year award.
    What the hell do you mean we don’t have a post of the year award!?
  11. Jan 10, 2025 at 7:51 PM
    Tripleconpanna
    We can't have those; it would mean that one person outperformed everyone else over the course of a given year and it would be detrimental to the development of an entire generation (or two):rofl:
  12. Jan 10, 2025 at 8:00 PM
    blenton
    blenton New Member
  13. Jan 10, 2025 at 8:30 PM
    seydou
    seydou Distinguished Member
    How does this relate to the potentially critical need to simultaneously replace the wire harness smoke? And will this meet or exceed the OEM requirements?
    panicman, RainMan_PNW, vtl and 6 others like this.
  14. Jan 10, 2025 at 8:32 PM
    Tundra family
    Tundra family New Member
    Mine seems to be self replenishing. :rofl:
    ZappBrannigan and Tripleconpanna like this.
  15. Jan 11, 2025 at 3:54 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Great point!
    Does anyone have the fumoto part number?
  16. Jan 11, 2025 at 4:10 AM
    389 24/7
    389 24/7 125k on the gen3
    Oregona
    2022 TRD OR
    Nada
    The easy way to do this is by putting your tundra on an auto rotisserie, flip it, use the fill hole to drain it, there by avoiding drilling a new hole....it's in the manual, trust me
    The manual also recommends turning your motor on while the truck is flipped over so oil can lube the top portion of the motor real good. I find this service is best performed at 3am pst
    Good luck folks
  17. Jan 11, 2025 at 4:32 AM
    I use only made in USA wire harness smoke. Avoid the Brit crap.
  18. Jan 11, 2025 at 4:59 AM
    Retired...finally
    I tried to service mine last night but my assistant had a headache.
  19. Jan 11, 2025 at 5:02 AM
    #49
    bflooks
    bflooks New Member
    Metrowest MA
    Threaten to compete the position. :)
  20. Jan 11, 2025 at 5:26 AM
    #50
    Tundra family
    Does this apply to people in AZ? We either don't use them or we drive with them on and have no intention of turning.
  21. Jan 11, 2025 at 7:14 AM
    #51
    CMikeB
    CMikeB New Member
    The additional use of blinker fluid must be why most "drivers" us a turn signal, instead of HAZARD FLASHERS!o_O
  22. Jan 11, 2025 at 9:08 AM
    #52
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    hard to vote on a post of the year this soon but it's got a chance.
    let them suffer. They can create whatever developmental problems for themselves they want to. And then big pharmacy will benefit from it somehow.
  23. Jan 11, 2025 at 9:34 AM
    #53
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    :nuclear:
    :rofl::rofl:
  24. Jan 11, 2025 at 9:37 AM
    #54
    RainMan_PNW
    Casey
    Clark County, WA
    You must use TechStream to properly engage the blinker fluid recalibration procedure so that the canbus sensors are correctly calibrated. That's why they say you have to have the dealer perform the service on the Gen 3's
  25. Jan 11, 2025 at 9:40 AM
    #55
    RainMan_PNW
    Casey
    Clark County, WA
    Thank god for Door Dash...
  26. Jan 11, 2025 at 9:50 AM
    #56
    BlackNBlu
    Rich
    MN
    I feel your pain brother.
