How to add LED DRL's to 2014-2017 Tundra with factory amber Drls
Discussion in 'Lighting' started by thomasbus337, Sep 24, 2017.
  1. Oct 13, 2017 at 8:32 PM
    #241
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    Red’s gonna go to red and purple to purple on the headlight harness you build.
  2. Oct 13, 2017 at 8:39 PM
    #242
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    dad12936cbfe18cc3b9f256067992afd_9ad37a4e6a858628f35bff52623f915ee9dd4a5b.jpgddd5bdabe12cd971ed15063694887904_b140addfe8474d8c68b45c395682adc56dd3f13a.jpg
  3. Oct 13, 2017 at 8:43 PM
    #243
    guyp2k
    guyp2k New Member
    These I assume?
    Also, will need to go back and review my notes, on the pigtails I recall you told me to remove the purple lead?
  4. Oct 13, 2017 at 8:43 PM
    #244
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yes sir
  5. Oct 13, 2017 at 8:48 PM
    #245
    guyp2k
    guyp2k New Member
    Thanks Roger! See above again on the pigtails where you told me to remove the purple wire????
  6. Oct 14, 2017 at 6:07 AM
    #246
    guyp2k
    guyp2k New Member
    One last post of relay before I start the install, does this look correct?
    A big Thanks to Roger and Thomas!
    Black to cab to DRL flasher relay J29.
    Purple/fused to battery, will add in-line fuse (10 amp).
    Red and Purple (black connectors) to Thomas's harness.
    Added purple (grey connectors) to Thomas's D and P pigtails.
  7. Oct 14, 2017 at 6:10 AM
    #247
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yes sir you got it
  8. Oct 14, 2017 at 12:41 PM
    #248
    Lanceb83
    Lanceb83 New Member
    Lance
    Valliant, OK
    2014 Tundra Crewmax
    RC leveling kit RC fender flares 305/55/20 Mickey Thompson ATZ P3 Fuel Maverick 20x10 -12 offset Body chop mount modification
    Still waiting on parts so for now I just tied the drl hi to the parking lights :)
  9. Nov 6, 2017 at 3:45 PM
    #249
    GreatAvalon
    GreatAvalon New Member
    2016 Tundra Limited DC
    Has the updated write-up for the setup that only uses 1 relay rather than two been posted yet? @thomasbus337 ?
  10. Dec 21, 2017 at 3:49 PM
    #250
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    well this was the most confusing thing i have read in a while. i just bough a pair of platinum/1794 lights and that will be going in my PRO. all i really want is for the led bottom strip to light up, not concerned if it blinks or dims. is it really that difficult to get the led strip to illuminate full time when the key is on?
  11. Dec 21, 2017 at 7:48 PM
    #251
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    If you don’t care if it stays on bright than you don’t need any of this. But if I were you I would make it dim. It’s oretty bright if they don’t. If you want the easiest method buy the harness from @iHacker
    He will build it all for you.
  12. Dec 21, 2017 at 8:35 PM
    #252
    94slowbra
    john
    new orleans
    2016 TRD pro
    Thanks for the heads up. I sent him a pm
    BlueBottle likes this.
  13. Dec 31, 2017 at 2:33 PM
    #253
    94slowbra
    john
    new orleans
    2016 TRD pro
    Ok so ihacker got back to me and doesn't build that harness and neither does eledoubleu. I tried to pm @inforno_pro_satx and haven't heard anything back. I just need the simplified how to to either build the harness to make the platinum/1794 led day time running work or someone who can build it for me. Thanks
  14. Dec 31, 2017 at 4:26 PM
    #254
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @94slowbra
    You will need to get two do these white connectors with pins (two each) some wire and an add a fuse to tap off an ignition source in your fuse box.
    You can get the plug/pins from www.BMotorsports.com
    (2) Toyota 4 Pin Male plug 90980-10868or CONN-75929 (USE ONLY IF ADDING DRLS to NON DRL TRUCK)
  15. Dec 31, 2017 at 4:38 PM
    #255
    thomasbus337
    thomasbus337 [OP] New Member
    2020 TRD Sport DC
    @94slowbra , if you aren't picky about the bottom DRL strip blinking with the directionals and being on with the stock amber DRL bulb, then check out eBay for item 132437959062
  16. Dec 31, 2017 at 4:44 PM
    #256
    94slowbra
    john
    new orleans
    2016 TRD pro
    Thanks bluebottle, I'll get the connectors and add a fuse. I have a wide assortment of wire.
    Thomasbus337: I don't need the led drl strip to do anything but be bright during the day and dim when the lights are on. No need for blinking or changing colors or anything like that. I'm going to leave the factory amber as a turn signal only
    Thanks guys
  17. Dec 31, 2017 at 4:48 PM
    #257
    94slowbra
    john
    new orleans
    2016 TRD pro
    Thomasbus337, how many of those harnesses do I need?
  18. Dec 31, 2017 at 4:53 PM
    #258
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Wow didn’t know those existed. Get those instead. You will need two.
  19. Dec 31, 2017 at 5:00 PM
    #259
    thomasbus337
    2020 TRD Sport DC
    They are sold as a pair, so just one
  20. Dec 31, 2017 at 5:07 PM
    #260
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Here is the diagram is you wanna wire them up like factory, sorry ever since Tapatalk stopped iPhone support I don’t see the pm’s. If you want a plug & play harness pm me.
  21. Dec 31, 2017 at 5:09 PM
    #261
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    If you get the eBay harness they will be dim all the time. I just helped another guy on the forums with this issue with the eBay harness
  22. Dec 31, 2017 at 11:26 PM
    #262
    94slowbra
    john
    new orleans
    2016 TRD pro
    Curious, why will they be dim full time?
    $30 for both harnesses would be sweet.
    Inferno_pro_stax, Thanks for the diagram. That simplifies the last 9 pages greatly
  23. Jan 24, 2018 at 5:51 PM
    #263
    Anakin16
    Anakin16 New Member
    2016 Black Tundra TSS 4x4
    7” BDS lift 20” fuel wheels on 35’s
    I’ve already installed my 2018 lights. Headlights work fine and signal light blinks normal until I turn on my parking lights or my headlights. The blinker starts flashing fast. Can’t figure out why, Hans told me to check my ground. Just waiting for some daylight to check.
  24. Jan 25, 2018 at 5:02 PM
    #264
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Did you repin the purple & white wires at the turn signal connectors on both sides ?
  25. Jan 25, 2018 at 5:25 PM
    #265
    Anakin16
    Anakin16 New Member
    I did repinn both sides. The shop that did it for me jacked it all up. I wasn’t confident that I could tackle it myself so I took it to get it done. Big mistake, never again.
  26. Jan 27, 2018 at 3:18 PM
    #266
    Anakin16
    Anakin16 New Member
    Well everything was redone and it worked great for about 2 days. Now my headlights and DRL’s don’t work. Very frustrating.
  27. Jan 27, 2018 at 6:56 PM
    #267
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    can you send pictures of your install?
    That would I be really helpful trying to find the issue what kind of harness did you used
  28. Jan 28, 2018 at 6:28 AM
    #268
    Anakin16
    Anakin16 New Member
    A4AB66E5-C592-47E5-8EF9-FB3D71DD082A.jpg I used the Ballenger Motorsports harness along with the Morimoto relay H4/9003 Bi-Xenon.
  29. Jan 28, 2018 at 6:31 AM
    #269
    Anakin16
    Anakin16 New Member
    I will take some pics today. My regret is I had a shop install them because they were doing a grill on my truck so I figured since they are there might as well do the lights.
  30. Jan 28, 2018 at 6:32 AM
    #270
    Anakin16
    Anakin16 New Member
