How to add LED DRL's to 2014-2017 Tundra with factory amber Drls
Discussion in 'Lighting' started by thomasbus337, Sep 24, 2017.
  1. Sep 30, 2017 at 7:46 AM
    #61
    thomasbus337
    thomasbus337 [OP] New Member
    2020 TRD Sport DC
    We already know the pin outs for the 2018 headlights. The SR, SR5,Limited and PRO crowd is interested in how to supply the power to the red and purple wires
  2. Sep 30, 2017 at 7:50 AM
    #62
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    Relay as we talked about earlier for the red wire and purple to cbulb purple and the crowd will have functioning headlights and be done...
  3. Sep 30, 2017 at 9:03 AM
    #63
    jdm ctr '00
    jdm ctr '00 New Member
    los Angeles, CA
    2016 Tundra TRD PRO
    So what would the diagram look like for us SR, SR5 and Pro people? :)
  4. Sep 30, 2017 at 9:05 AM
    #64
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    It's on the second page towards the end.
  5. Sep 30, 2017 at 10:39 AM
    #65
    guyp2k
    guyp2k New Member
    Let me ask a question for clarification, I purchased the harness, additional pigtails from Thomas for 2016 Limited CM, and received my 2018 HLs yesterday. My question, in order to make these work like factory I will need to make an additional pigtail, from this thread in addition to what I purchased from Thomas? Sorry for the question, but I am not clear on what I need to do/fabricate moving forward. I was hoping what I purchased from Thomas would be all I need....
    Thanks
  6. Sep 30, 2017 at 10:40 AM
    #66
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    Looking at that diagram, it would only plug into one side of the headlight?
  7. Sep 30, 2017 at 10:43 AM
    #67
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    I don't know how Thomas harness works, this original thread was for first gen drl's on sr5/limited/pro's
  8. Sep 30, 2017 at 10:43 AM
    #68
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    #68
  9. Sep 30, 2017 at 10:44 AM
    #69
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Any before and after pics for the 2014-2017 ???
  10. Sep 30, 2017 at 10:46 AM
    #70
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Both red from the drl harness on the headlights go to 87 on the relay, both orange on the drl harness go to purple at the c bulb harness and black ground.
  11. Sep 30, 2017 at 10:47 AM
    #71
    guyp2k
    guyp2k New Member
    I think what I purchased from Thomas is all I need, the harness and the pigtails for a 3rd Gen, just would like confirmation as I'm not sharpest tool in the shed...
  12. Sep 30, 2017 at 11:06 AM
    #72
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Just reread how @thomasbus337 harness works, its up to him if he wants you reconfigure it to the newest diagram with 1 relay instead of 2
    . It will not be hard.
  13. Sep 30, 2017 at 11:31 AM
    #73
    thomasbus337
    2020 TRD Sport DC
    The harnesses I put together were designed to be PnP with the Platinum/1794 models with the factory matching female 4 pin DRL plug to interface with the 4-pin male plug already on the truck. SR, SR5, Limited and Pro models need to provide their own relay, 4 pin male mating plugs (CONN-75929) and wiring to add the LED DRL’s.
    I had put together an adapter harness for the 3-pin directional/park light and the driver’s side adapter has a 24” lead purple wire which was originally intended to be a park signal input for the 2-relay setup.
    If you have one of my adapter kits that came with the purple wire lead only on one side you can either use the 2-relay setup mentioned at the beginning of this thread or switch to the single relay setup. To do this, you’ll only need to add in a purple wire into the passenger side adapter using an extra wire seal and terminal from the CONN-75929 kit to replicate the driver’s side adapter. Then attach a 4-pin male plug (CONN-75929) to your red wires from the relay setup and purple wires from the signal adapters on each side to interface with the 4-pin female plug on my PnP headlight harness.
    iHacker, inferno_pro_satx and Jsena like this.
  14. Sep 30, 2017 at 2:54 PM
    #74
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    Does this sound/Look right?
    Parts:
    2- CONN-75929 male plug
    4- CONN-100550 cavity plug
    1- Extra wire seal & terminal(conn-75929)
    1- H41410081 relay
    1- H84708001 relay plug
    1- waterproof in-line fuse holder
    Misc. plastic wire loom/16 wag wire/heat shrink/butt connectors.
    This is my diagram, can you confirm if it’s correct?
  15. Sep 30, 2017 at 2:58 PM
    #75
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Looks correct as long as his purple wire goes to the orange on the drl Headlights.
  16. Sep 30, 2017 at 3:50 PM
    #76
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    Orange on the DRL Headlight = DRL low?
  17. Sep 30, 2017 at 3:52 PM
    #77
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yes
  18. Sep 30, 2017 at 3:59 PM
    #78
    thomasbus337
    2020 TRD Sport DC
    That looks correct to me, and thank you for putting together the diagram.
  19. Sep 30, 2017 at 4:00 PM
    #79
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    According to the plug pin out on his harness it says:
    Pin 6 is the DRL LO/Parking Lights for the headlight plug and the DRL(4pin) Plug Pin 2 is the Purple. The Purple DRL(Pin2) LO is going to Pin 6 DRL LO on the headlight plug.
  20. Sep 30, 2017 at 4:01 PM
    #80
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    :thumbsup:
  21. Sep 30, 2017 at 4:01 PM
    #81
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Can't wait till this gets spread all over the fourms now lol
  22. Sep 30, 2017 at 4:03 PM
    #82
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    lol
  23. Sep 30, 2017 at 4:04 PM
    #83
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    I've kept that gray wire a secret for a good while lol.
  24. Sep 30, 2017 at 4:07 PM
    #84
    thomasbus337
    2020 TRD Sport DC
    I was trying to clear up this confusion earlier, but on the back of the 14-17, Platinum/1794 headlights the LED DRL wiring was visible coming out of a grommet on the headlight. That is where the reference for the "orange" DRL wire is coming from. On the actual truck wiring, the DRL low wiring is Purple/ Violet.
  25. Sep 30, 2017 at 4:10 PM
    #85
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yea I realized that, I was under the impression we we're just doing the first gen headlights then the 18 got thrown in.
  26. Sep 30, 2017 at 4:12 PM
    #86
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    lol
  27. Sep 30, 2017 at 10:25 PM
    #87
    sano502
    sano502 New Member
    17 Tundra TRD Pro Cement
    @jdm ctr '00 make me a LED DRL Relay please. I’ll play you for the parts and labor
  28. Sep 30, 2017 at 10:29 PM
    #88
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    I haven’t even tried to make mine yet lol follow the diagram I bet you can make it. :benchpress:
    sano502[QUOTED] likes this.
  29. Sep 30, 2017 at 10:42 PM
    #89
    sano502
    sano502 New Member
    @jdm ctr '00 on your parts list are the first and third items in the same? I can’t find the third part
  30. Oct 1, 2017 at 6:04 AM
    #90
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    The 3rd part listed is the left over parts from the 2 male plugs(75929). You will only be using 2 pins. When you order those plugs they come as a kit: you get 5-pins & 5-seals.
