How to add LED DRL's to 2014-2017 Tundra with factory amber Drls
Discussion in 'Lighting' started by thomasbus337, Sep 24, 2017.
  1. Sep 26, 2017 at 5:29 PM
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    Yea both fused underhood, nothing is ignition control since the 85 does it all.
    I just run 1 wire inside and the rest is done underhood
    texbambam likes this.
  2. Sep 26, 2017 at 6:23 PM
    thomasbus337
    thomasbus337 [OP] New Member
    2020 TRD Sport DC
    This info definitely helps to simplfy the wiring. If I didn't already have mine set up with a AOB dash switch to control them I would go this route instead.
    inferno_pro_satx likes this.
  3. Sep 26, 2017 at 6:31 PM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Cool!!
    I do electrical diagnostic daily at work so I have access to all diagrams and understand it.
    sano502 likes this.
  4. Sep 26, 2017 at 7:12 PM
    jdm ctr '00
    jdm ctr '00 New Member
    los Angeles, CA
    2016 Tundra TRD PRO
    Thank you
  5. Sep 26, 2017 at 7:21 PM
    PROTX
    PROTX New Member
    Edgar
    2017 TRD PRO Barcelona Red Metalic
    Can you elaborate where the orange wire is coming from? Also just want to clarify if 30 is 12v fused from the battery, where is a good place for 86? Just tap into any 12v source??
  6. Sep 26, 2017 at 7:28 PM
    TuffTundra
    TuffTundra New Member
    Missouri
    2016 MGM SR5
    4" Rough Country Lift - Fuel Assault 20x10 - Nitto Ridge Grapplers 33x12.5x20 - 2018 LED Headlights - LED Lights all around - No Chrome - Tinted Windows & Tail Lights
    So I will not need these?
    (2) Toyota 4 pin female plug 90980-10869 OR (CONN 75928)
    (2) Toyota 4 Pin Male plug 90980-10868 or CONN-75929 (USE ONLY IF ADDING DRLS to NON DRL TRUCK)
  7. Sep 26, 2017 at 8:32 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Hello @thomasbus337 hey do you have the part number for the pigtail in the flasher relay I already have my gray wire unpinned and would like to try this new DRL wiring you and @inferno_pro_satx are talking about to get power from to activate the led drl relay I need that pigtail to make it a clean install I think is a 14 or 16 plug connector, I think if this work I prefer this way to make it work as factory
  8. Sep 27, 2017 at 9:27 AM
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    I'm looking forward to his diagram.:benchpress::thumbsup:
  9. Sep 27, 2017 at 9:38 AM
    sano502
    sano502 New Member
    17 Tundra TRD Pro Cement
    @inferno_pro_satx do you have a list of all the parts/supplies needed for this? Thank you
  10. Sep 27, 2017 at 11:09 AM
    sano502
    sano502 New Member
    Please do it would be of great help
  11. Sep 27, 2017 at 11:43 AM
    texbambam
    texbambam New Member
    Tundra TRD PRO sand
    This sounds perfect....thanks
  12. Sep 27, 2017 at 4:29 PM
    sano502
    sano502 New Member
    @thomasbus337 since your convo with @inferno_pro_satx has the wiring for the LED DRL changed from your original instructions? Any more or less parts? Sorry I got confused just need updated instructions if you can thank you
  13. Sep 27, 2017 at 7:30 PM
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    @inferno_pro_satx said he would be drawing up a diagram. It has less parts and easier to wire up.:thumbsup:
    JonChambers likes this.
  14. Sep 27, 2017 at 9:36 PM
    sano502
    sano502 New Member
    I can’t wait for it
  15. Sep 29, 2017 at 6:39 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    So this need a 4 pin relay right? I'll try this next week and I think this can be done under dash and just the Bright DRL signal coming from relay in cabin to 8 pin connector DRL HI/Pin and attach the Purple wire/parking to the 8 pin connector DRL LOW/pin, in the 8 pin connector the ground is shared for all lightning sources LOW/HI DRL, in theory this will be the perfect install like factory LED DRLs should work but not sure, Im still waiting for my headlights so no way to try this until next monday or tuesday
    Is this right for you guys?
  16. Sep 29, 2017 at 10:06 PM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    The orange wire on the drl Headlights is the low beam drl's, the drl strip dims when the parking lights are turned on. You can put 30 & 86 together fused at the battery.
    PROTX[QUOTED] likes this.
  17. Sep 29, 2017 at 10:09 PM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yes if you wire it like as I said it will be completely factory function.
    The gray wire just sends a ground for the hi drl relay
    The purple c bulb wire can go to the low beam drl's and they don't need a relay cause the LED's draw very low current.
    iHacker[QUOTED] likes this.
  18. Sep 29, 2017 at 10:21 PM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    If you already have the thin gray wire depinned just run a wire to the enginebay connected to that wire. You don't need a pig tail going into the drl control unit.
  19. Sep 30, 2017 at 12:41 AM
    #49
    iHacker
    iHacker SW TRD PRO
    Mario
    Thanks @inferno_pro_satx
    #49
  20. Sep 30, 2017 at 5:59 AM
    #50
    iHacker
    iHacker SW TRD PRO
    Mario
  21. Sep 30, 2017 at 6:05 AM
    #51
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Here's the diagram,sorry been really busy this week and I'm not getting notifications.
    sano502, iHacker and PROTX like this.
  22. Sep 30, 2017 at 6:09 AM
    #52
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Just seen you posted, they don't have to be acc ignition, 86 & 30 can be ran directly to the battery fused with a 5 amp. They won't have any draw because the relay isn't energized.
  23. Sep 30, 2017 at 6:41 AM
    #53
    thomasbus337
    2020 TRD Sport DC
    Looks good to me. I just want to clarify something to hopefully save some confusion later. The orange wire, inferno_pro_satx is referring to in the relay drawing is not the orange wire that is shown in iHacker’s 8 pin harness photo above.
    The wiring color info inferno_pro_satx is sharing relates to female 4 pin plug that would be present on a 14-17 Platinum/1794 LED DRL headlight.
    If you are using this “how-to” to add the LED DRL function to the 2018 LED headlights there will be no orange wire to interface with. The purple parking light wire will be pin 6 on the 8pin connector and the pin 87 red wire output from the relays will go to pin 5. The 2018 LED headlight shares its single ground input wire so no additional ground wire will be needed.
    PROTX and iHacker like this.
  24. Sep 30, 2017 at 6:47 AM
    #54
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    No the orange wire is on the headlight/ drl strip, that's for the low beam drl that goes to the purple wire at the c bulb harness.
  25. Sep 30, 2017 at 6:52 AM
    #55
    thomasbus337
    2020 TRD Sport DC
    This is still true for the 14-17 LED DRL headlights, but the 2018 full LED headlights only have a single 8 pin shared plug for the entire LED portion of the headlight with no visible wire colors when looking at the plug itself
    The DRL wires on this plug are Red for HI LED DRL and Purple for Low LED DRL
  26. Sep 30, 2017 at 6:56 AM
    #56
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    I couldn't answer that, haven't messed wit 18's yet or visually seen the connector just wire diagrams
    Then that plug the purple wire should go to the c bulb factory purple and red to the relay.
    iHacker likes this.
  27. Sep 30, 2017 at 7:19 AM
    #57
    thomasbus337
    2020 TRD Sport DC
    Yes that is correct. I guess the point I was trying to make was that if you look at this headlight
    Your red wire/orange wire/black wire info is correct, but if you were looking at the back of the new headlight,
    there wouldn't be a visible orange wire to connect to, as everything LED related is connected to the 8 pin plug
  28. Sep 30, 2017 at 7:26 AM
    #58
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yea Toyota sucks for doing that.
    You couldn't trace back the wires from behind the connector? If it was me I'd use my power probe and start powering up pins and see what each wire does after I know for sure what my ground wire was and go from tere.
  29. Sep 30, 2017 at 7:27 AM
    #59
    iHacker
    iHacker SW TRD PRO
    Mario
    I think he have a orange wire because he have Diode dynamics switchbacks in his DRL strip that's why I that orange wire in my retros too but is for the switchbacks not for the DRL function
  30. Sep 30, 2017 at 7:32 AM
    #60
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    The orange wire is factory on all platinum headlights, the drl harness has 3 wire red/orange/ blk
    The drl harness is under the c bulb,this is 14-18 with lower drl strips
