How stout is the tailgate?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jernik, Oct 3, 2021.
  1. Oct 3, 2021 at 2:50 PM
    Jernik
    Jernik [OP] New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Will be looking to get a gun safe in the near future, and wondering how sturdy our tailgates are? The ones I'm looking at are approx. 550-600 lbs. Can our tailgates handle this? Figuring to lean cabinet against tailgate, tip over and slide in on its back (with cardboard underneath). Reverse procedure to get it back out. Will the tailgate take this kind of weight, or am I better off renting a uhaul trailer to get it home?
  2. Oct 3, 2021 at 2:52 PM
    WhyW8
    WhyW8 “It’s ALWAYS Loaded”
    HB
    Sunny AZ
    2017 Super White SR5 CM
    Level Kit, DiamonBack Tonneau, Step Boards, Alpine Amp, Cerwin Vega powered Sub
    NewImprovedRon and Jernik[OP] like this.
  3. Oct 3, 2021 at 2:58 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Can’t speak for a gun safe, but years ago a friend of mine got a flat tire on his HD Roadking and rode it off a retaining wall into the bed of my Tundra via the tailgate and then back out of the bed on another retaining wall near his house. The bike weighed probably every bit of 700lbs and my buddy probably is close to 290lbs.
    Did no damage.
    Jernik[OP] likes this.
  4. Oct 3, 2021 at 4:15 PM
    racer01
    racer01 New Member
    Geoff
    Aiken South Carolina
    23' TRD Pro
    295/70-18 Nitto Recon Grappler, RB 20 running boards
    not sure what the weight limit is, but if two or three stout dudes sitting on the tailgate having a beer caused it to break it would be on every 3rd post on here. The new ones don't have a transmission cooler and it doesn't cause the transmission to fail and its on like every page :)
    I am sure you'd be fine....lots load 4wheelers and heavy bikes into the bed.
    NomadicFrog and Jernik[OP] like this.
  5. Oct 3, 2021 at 4:18 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Definitely not stout enough to lean a 600lb safe up against. The tailgate is completely hollow with little to no structural support inside of it. It would bend like a wet noodle
    Black Wolf and Jernik[OP] like this.
  6. Oct 3, 2021 at 4:50 PM
    Coal Dragger
    Kung Fu Dick
    Agreed, the tailgate is a lot stouter than you might suspect.
  7. Oct 3, 2021 at 6:22 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I would add a piece of plywood to spread the weight out over more surface area, but I would feel comfortable doing it with that.
    Mr_Ed, Geezer, WFD473 and 1 other person like this.
  8. Oct 3, 2021 at 6:23 PM
    Tileguy
    Tileguy New Member
    Birmingham, Alabama
    2011 Toyota Tundra
    Agree, I am in the tile installation business. We regularly stack 8 to 10 boxes of heavy tile on my tailgate when we unload by hand plus the weight of one man, probably 700 to 800 pounds total. Done this for years and I have never damaged a tailgate.
    WFD473, Jernik[OP] and 2mchfun like this.
  9. Oct 3, 2021 at 6:23 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I moved heavy stuff by taking the tailgate off and pushing things directly onto the bed floor
  10. Oct 3, 2021 at 6:40 PM
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    Yes, do this. Get a trailer with a ramp, roll it to the front of the trailer, tie down securely, roll off at destination. VERY VERY worth the time and cost for a rental.
    Oh and the appliance hand trucks are way harder to use than a standard heavy-duty hand truck with large rubber tires. Just make sure the tires are aired up, use a ratchet strap or two to strap the safe to it, and away you go. If it’s a large safe, use furniture dollies and still do the strap thing. I did the above with a refrigerator by myself and I’ll never move an appliance any other way if I can help it.
    Use a packing blanket or two, to keep the safe from rubbing on anything to include the strap if you want to make sure the finish isn’t damaged.
    KNABORES and Jernik[OP] like this.
  11. Oct 3, 2021 at 7:23 PM
    2mchfun
    Plenty stout, like said above a sheet of 3/4 plywood would be good insurance. I have had 800lbs of redi mix on mine spread out over the area.
    WFD473 and Jernik[OP] like this.
  12. Oct 3, 2021 at 7:30 PM
    Even if my tailgate is strong enough, I'd still have a heavy ass safe delivered, dropped off, brought inside, put exactly where I want it, tip the delivery folks , and be done with it....o_O
  13. Oct 3, 2021 at 7:37 PM
    2mchfun
    /\/\/\ This. One bad back injury and life is never the same!
  14. Oct 3, 2021 at 8:07 PM
    Coal Dragger
    Kung Fu Dick
    Correct. The delivery and installation fee is money well spent, and wisely spent.
  15. Oct 3, 2021 at 8:28 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Furniture mover over a hand truck for sure
    Jernik[OP] and Black Wolf like this.
  16. Oct 3, 2021 at 10:10 PM
    IgotSR5onit
    IgotSR5onit New Member
    Itll work. I moved a Liberty 32 last week that weighed in at over 600 pounds. Safe of this size arent hard to move. I moved it out and down stairs by myself and a set of hand trucks. Me and my brother moved it into his house.
  17. Oct 3, 2021 at 11:08 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I loaded a 650lb steel workbench in the same way as you're describing. Leaned it against the tailgate, lifted the rear and slid it forward.
    Reverse method getting it out. It kinda trashed the carpet padding I have on the inside of the tailgate, but otherwise no issues with the tailgate itself.
  18. Oct 4, 2021 at 6:30 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I just remembered, our local safe vendor offers relocation service (moving a safe) for $100. I plan to use that service when I move. You might want to check to see if that kind of service is available in your area.
    Jernik[OP], jewsNbrews and Black Wolf like this.
  19. Oct 4, 2021 at 6:47 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    DO NOT LOAD THAT SAFE ON THAT FLIMSY TAILGAGE!!!!! Search my name on this forum I have pics of what inside tailgate which is nothing, no support beams nothing just a hollow tin metal frame with huge opening on the inside. Mine got bent loading a Honda Foreman ATV which weighs 680lbs with big fat tires. Tundra tailgate is the worst on market.
    BUGEATER and Jernik[OP] like this.
  20. Oct 4, 2021 at 12:27 PM
    Jernik
    Jeremy
    Trust issues keep me from paying for delivery of this item. A friend of my brother did that and miraculously his home was broken into less than 2 weeks after delivery. Only thing targeted was that gun safe, nothing else in the house was touched.
    Leaning toward the Uhaul option as that sounds much safer/easier on my back.
  21. Oct 6, 2021 at 4:56 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    borrow a utility trailer with a ramp
  22. Oct 6, 2021 at 5:00 PM
    Coal Dragger
    Kung Fu Dick
    In that case the suggestion to rent a trailer with a ramp is the best solution. Tailgate strength notwithstanding, the ease of loading and unloading a 600-700lb steel box will be much higher on a lower flatbed trailer with a ramp.
  23. Jan 19, 2022 at 12:14 PM
    SILBERTUNNY
    SILBERTUNNY New Member
    Henry
    2014 platinum
    All Terrain tires
    per my experience, i sometimes haul golf carts on my bed, which is 5.5ft so one pair of tires have to sit on my tailgate. We're talking about 1000lbs overall, so maybe 600-700lbs on the tailgate but only distributed at the tire contact spots. After about 3-4 years, tailgate has indentions from the weight, not heavily damaged, but not exactly straight anymore either! Always good to tow or evenly distribute the weight across the bed and the tailgate if possible. I looked into the stronger steel rods that hold the tailgate up as opposed to relying on the OEM cables, but have been told that they dont make it for Tundras because the tailgates are weak. haha
  24. Jan 19, 2022 at 4:40 PM
    The trailer is good advice. They also make a safe specific hand truck that makes them
    Easy to transport.
  25. Jan 19, 2022 at 5:55 PM
    Deacon Blues
    Deacon Blues New Member
    2018 Tundra TRD Off Road
    I've moved my double wide Centurion safe a few times, lots of bikes, and my entire home gym once.....from the bed of a Tacoma.
    Tundra will be fine especially since it's just an occasional thing, not a daily use issue.
    Oh and definitely get a good appliance dolly.
  26. Jan 19, 2022 at 6:11 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    You gotta love the range of responses in this thread.
    I personally vote pay someone else to do it or rent a trailer. Last time I helped move a large gun safe, we borrowed a tilt deck trailer and that was by far the best decision we made that day.
  27. Jan 19, 2022 at 6:28 PM
    2mchfun
    It's all about how said weight is distributed. I actually had a good sized stack of OSB in my truck a few weeks ago hanging out the back. I was going up a small hill and my straps broke. The entire stack of 46 sheets slid back and amazingly landed still stacked in the roadway. Still can't believe it didn't spread all over. Anyway, my point is the tailgate had a significant load on it momentarily and I think the cables may have actually stretched a little, but nothing else sustained any damage except for the end of the bottom sheet of OSB that took the blow from the road. Fun times!
  28. Jan 19, 2022 at 6:45 PM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    Go with the delivery suggestions. The saved gas and reduced wear on your cooler-less tranny will pay for it…
    :anonymous:
    Retired...finally likes this.
  29. Jan 20, 2022 at 9:21 AM
    normagene
    normagene New Member
    Normagene
    New England
    2021 Cement DC Limited Texas Edition
    Texas Edition
    I got a new gun safe back in July and it weighed right around 500 pounds.
    Didn’t have my Tundra yet I had my 2017 Tacoma. So I’d think the Tundra tailgate would be as strong if not stronger than the Tacoma’s tailgate.
    Anyway I had 3 guys help cart it out and we tipped it onto the tailgate so like a foot of the huge box was on the tailgate and we all easily lifted it level with the tailgate/bed and slid it in at the same time.
    Once I got home it was just me. So I backed up to the garage and slid it out enough to where it just started to tip and it gently slid to the ground. It was probably at a 45 degree angle and I lifted it up then rocked it back and forth from side to side until it was all the way in the garage.
    I was surprised on how easily it was to muscle around and slowly but surely move! Then later with a helper and handcart it was placed in its proper final placed.
    So if the tailgate on my Tacoma held up I’d think a Tundra would do even better.
  30. Jan 20, 2022 at 10:29 AM
    bwh
    bwh New Member
    Thirded. Some companies have some very fancy dollies that make moving them down stairs an easy and effortless process.
    And if you're worried someone will break in, just spend the whole time the delivery guys are there talking about how you'll use it to store your favorite POGs
    NewImprovedRon likes this.
