How often to you engage 4WD?
Discussion in '3rd Gen Tundras (2022+)' started by JayDee, Nov 7, 2024.
  1. Nov 8, 2024 at 6:36 AM
    BlackNBlu
    BlackNBlu Cranks Nickelback in Target order pickup lane
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    I totally forgot about the locker! Yep, use it or lose it I suppose.
    PNW Tundra Mike likes this.
  2. Nov 8, 2024 at 2:23 PM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    On a related topic, using 4WD in snow, mud, sand, whatever. An old guy told me one time... "Don't use 4WD until you're stuck in 2WD then use 4WD to get out, if you use 4WD until stuck... Then you're screwed!" LOL I got a chuckle out of that as historically I may have broken that rule a time or two LOL
    PS, front tow hooks would be nice......
  3. Nov 8, 2024 at 9:17 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    This is interesting, as I usually give it some gas and it fully disengages (when it’s kind of blinking and is like a kid or dog who wants to stay outside even though their mother told them to get in)
  4. Nov 9, 2024 at 6:40 AM
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    I use mine all the time in the winter, first season it was giving me a ton of trouble disengaging. The transfer case would move back to 2wd and light would go off but the front would stay locked (could feel the tires scrubbing). Multiple times on the side of the road reversing and turning to get it to unlock.
    Use the actuator a lot, A LOT, and change front diff and transfer case oil. Going into my 3rd winter and it is now buttery smooth on the fly.
    I did redline in the front diff and Toyota WS ATF in the transfer case.
  5. Nov 9, 2024 at 10:39 AM
    Jrktms5
    Jrktms5 New Member
    Mark
    2024 platuim TRD
    T cover, side steps, cat & skid plate
    I do mine weekly for a distance of about 2 miles , just to exercise mechanics
  6. Nov 9, 2024 at 10:49 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    if you strive for weekly, you can obtain monthly.
    Tundrastruck91 likes this.
  7. Nov 9, 2024 at 12:39 PM
    22whatwedo
    The Open Road
    When you changed your fluid, did it feel like the transfer case was under a good bit of pressure? Mine was, and so was my rear dif. Interesting release of air.
    If anyone is doing this service BTW, I would recommend getting a 10mm square drain socket. I dont have one. I just used a 3/8” extension, which worked (it’s about a half mil shy), but I already ordered the right tool off Amazon for next time. Weird, I couldn’t find one at the local auto parts stores, and Harbor Freight doesn’t carry them anymore either.
  8. Nov 9, 2024 at 3:41 PM
    FoopaKing
    FoopaKing New Member
    2024 SR5
    Probably every month and a half. There’s a decent number of seasonal dirt roads around me. So every once in awhile it’s fun to drive there to blow off some steam and slip around on some mud. Nothing deep or crazy. But enough to run the 4WD and feel like I actually need it.
    In winter, weekly.
