How often do you put your truck into 4 wheel drive?
Discussion in 'General Tundra Discussion' started by normagene, Jan 20, 2022.
  1. Feb 12, 2022 at 7:52 PM
    #61
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    It's not that fragile. The 10 miles per month thing is silly. The only time I ever drive 10 miles in a month in 4WD would be in winter when we actually get some snow-covered roads; and I mean slick roads, not just a dusting. Probably doesn't happen more than a few times a year.
    Otherwise, my 4WD use is and has always been brief periods when I need it. I've never had a problem.
    Sumo91 likes this.
  2. Feb 12, 2022 at 8:09 PM
    #62
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    And yet we see guys on here who don't use it for years then have issues with the actuator. I don't see any reason not to exercise it monthly.
    des2mtn and NewImprovedRon like this.
  3. Feb 13, 2022 at 8:44 AM
    #63
    PA452
    PA452 New Member
    If you want to, have at it, but 10 miles per month is overkill.
    People posting here about problems with their actuators after long periods of no use, how often do we see that? I'm kind of on and off on this forum, but I really don't recall seeing that often at all; in fact I'm not sure if I've seen that more than once if that. And I'm not including the people who post because they don't get that sometimes you have to move slightly to get it to engage.
    On the contrary, I feel like about every other time I log in here I see a post saying, "What's wrong with my 4WD? The manual says to drive 10 miles per month to exercise it, so surely it must be ok to use on pavement. But I'm getting this crazy bucking behavior when turning. Did I get a lemon?".
  4. Feb 13, 2022 at 11:35 AM
    #64
    Wallygator
    Once a month for 10 miles since day 1
  5. Feb 13, 2022 at 12:43 PM
    #65
    Canebrake
    Canebrake New Member
    JP
    West Alabama
    ‘17 SR5 4x4
    I also do the 10 or so miles a month in 4WD Hi, and I’ll put it in 4WD Lo for a minute or so after just to work it. I use it as an excuse to find a dirt road or gravel and do a little cruisin’. Sorry honey, I’ve gotta take the scenic route on the way home, have to exercise my 4x4. Sometimes I wish the manual recommend 100 miles a month :mudding:
  6. Feb 13, 2022 at 1:03 PM
    #66
    yandeltx
    yandeltx New Member
    I just traded my 2018 Silverado for a 2WD 2019 Tundra (20k miles). I put 107k miles on the Silverado and I put it in 4wd one time for about 1/4 mile.
  7. Feb 13, 2022 at 1:08 PM
    #67
    Wallygator
  8. Feb 13, 2022 at 5:33 PM
    #68
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    while you're in 4hi, make sure you're not going above 55
  9. Feb 13, 2022 at 7:41 PM
    #69
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Hmm. I thought they specify not to engage or disengage over 55mph.
    I've driven a good couple hours at a sustained 65ish without any sort of strange sounds, smells or vibrations.
    Maybe I should take another read.
  10. Feb 13, 2022 at 8:09 PM
    #70
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That's how I interpreted it as well. Just don't shift from 2Hi to 4Hi above 55 mph.
  11. Feb 13, 2022 at 8:26 PM
    #71
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Has anyone here tried shifting into 4-H over 55 MPH? I would think that Toyota would electronically disable that if they thought it was a problem. :monocle:
    joseph_womack and Wallygator like this.
  12. Feb 13, 2022 at 9:57 PM
    #72
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    The night I brought my '12 home last year, I cycled in and out of 2hi,4hi,4lo a few times. The first few cycles were slow and noisy. Ever since then, it's been fast and smooth. I don't think the original owner followed the 10 mile guidance and with the low mileage, it did lots of sitting in his garage.
    I try to remember to lock it in for the quarter mile leaving my house on occasion. I've never run 10 miles in 4x4... I really don't have a place that I can do that.
  13. Feb 13, 2022 at 10:28 PM
    #73
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    I used 4x4 in the snow we had last month. Just in and out of the driveway. Last time maybe up a logging road when it was new?
    I’d better exercise it more often.
    I used own and a 78? Chev with Warn hubs. Hated locking up just for lube purposes.
    Wallygator likes this.
  14. Feb 14, 2022 at 7:34 AM
    #74
    Wallygator
    I usually wait until it rains then find a fairly straight road and drive in 4wd. Come to a sharp turn and switch it back to 2wd. Then put it in 4 lo in a random parking lot or even the driveway. Could even do this on dry pavement but better on wet. It's easy to get the 10 miles in.
    NewImprovedRon likes this.
  15. Feb 14, 2022 at 8:12 AM
    #75
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I just go to 4Hi whenever I get onto a dirt or gravel road, even if 4x4 is not needed. That ends up being a couple of times a month, and I don't go anywhere near 10 miles. Maybe 3-4 most of the time. I go into 4Lo only once every few months just to run it there for a little bit. I've never been in a situation where I needed 4Lo, 4Hi has gotten me through just fine.
    ATV25 and joseph_womack like this.
  16. Feb 14, 2022 at 10:37 AM
    #76
    joseph_womack
    Joe
    Louisiana
    Ohhhh that would make since, I probably read the card wrong
  17. Feb 17, 2022 at 7:43 PM
    #77
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    No way I'm doing the once a month gig. That is overkill. A handful of times a year should be adequate. If the actuators need that much use to work, then Toyota isn't as good at engineering as I thought.
  18. Feb 19, 2022 at 2:27 PM
    #78
    Wallygator
    Everyone has thoughts
    ATV25 likes this.
  19. Feb 19, 2022 at 2:53 PM
    #79
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Use it or you loose it. Has nothing to do with Toyota. If you don't use a 4x4 why you get one?
    ATV25 and Shadowfax1 like this.
  20. Feb 19, 2022 at 2:58 PM
    #80
    Oregon 1 Toyo
    Oregon 1 Toyo New Member
    2014 Tundra sr5 double cab 4x4
    If you do engage the 4x4 don’t do it on dry pavement only gravel, dirt, snow, sand ect. It can mess it up. But, it is good practice to turn it to 4 hi now and again so all the gears get lubricated.
  21. Feb 19, 2022 at 5:53 PM
    #81
    SwitchThrottle
    Did I say that I didn't use 4wd? Pretty sure I actually said I just used it...which...ironically is why I bought one.
  22. Feb 19, 2022 at 6:36 PM
    #82
    GatorBodine
    GatorBodine New Member
    Yep, my wife's 05' 4Runner won't engage into 4wd from lack of use/exercise. Probably the actuator.
