How often do you have your furnace inspected?
Discussion in 'Home Improvement' started by BTBAKER, Nov 29, 2019.
  1. Nov 29, 2019 at 9:33 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Just curious. I’m going on five years on both my furnaces without inspection. In my last house I did it once in 10 years. I do change filters monthly but that’s about it.
    Most manufacturers say an annual inspection in warranted but that seems like overkill.
    What’s everyone doing?
    Sas likes this.
  2. Nov 29, 2019 at 10:04 PM
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
    Gas or oil ?
    Geezer likes this.
  3. Nov 29, 2019 at 10:48 PM
    Once every year. Yearly inspections don't cost much at all. Not overkill at all.
    ColoradoTJ and BTBAKER[OP] like this.
  4. Nov 29, 2019 at 11:24 PM
    Grumpy Uncle
    Pat
    CO
    I do every year or two. Every 3 years I have the ducting cleaned. You wouldn't believe the stuff that come out of there.
  5. Nov 30, 2019 at 4:39 AM
    grannynancy
    grannynancy New Member
    Nancy
    Upstate SC
    2007 DC TRD 4WD
    Every year. I do a contract with my HVAC company to check and balance our systems (we have two) twice a year. My furnace is gas and I don't want to mess around with potential leaks etc. They also replace the big filter on our main system.
    Black Wolf, BTBAKER[OP] and Netmonkey like this.
  6. Nov 30, 2019 at 4:50 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    same here. they come out right before the summer and right before the winter. i think its $180 for both visits and it is worth the piece of mind. i would hate for the units to go out in the middle of the 100 degree summers or the 20 degree winters.
  7. Nov 30, 2019 at 5:29 AM
    Mike Tread lightly.
    south carolina
    I do mine in fall and in spring... I normally do visual inspection of the units .. open them up make sure everything is in order.. the check the duct work for leaks repair if need and I'm good.
    Only thing I can't do I freon tho I know how to do it..
    BTBAKER[OP] and FrenchToasty like this.
  8. Nov 30, 2019 at 5:43 AM
    Jim LE 1301 Camaro Lover, SSEM # 11
    Every year.
    BTBAKER[OP] likes this.
  9. Nov 30, 2019 at 6:24 AM
    Woodguy65
    Woodguy65 New Member
    Yearly
  10. Nov 30, 2019 at 7:42 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Gas.
  11. Nov 30, 2019 at 7:44 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Annual seems to be the norm. Maybe I need to rethink my approach.
    BravoDeltaRomeo likes this.
  12. Nov 30, 2019 at 7:49 AM
    19TundraPlatinum
    Maryland
    My professional opinion is gas is pretty maintenance free. Most service techs coming out to do a “annual check up” are doing nothing more then a filter change, visual inspection inside cabinet for obvious things and then sticking the temp probe in the plenum and checking heat rise that’s specified on the door. Unless the furnace is up there in age I wouldn’t stress over it. Now if it was oil I’d definitely say def get a tune up and inspections annually. Just my .02
  13. Nov 30, 2019 at 7:49 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Gas furnaces have safety features that should be checked annually. 1st 3-5 yrs maybe every other year.
    The exchanger should also be inspected for flaws, if faulty you are at risk to Carbon monoxide exposure.
  14. Nov 30, 2019 at 7:58 AM
    Mr Badwrench
    Mr Badwrench New Member
    '01 SR5 4X4 V8
    She'll go 300 hectares on a single tank of kerosene
    I haven't run my furnace in 7 years, and for that reason, I should probably get it inspected soon.
  15. Nov 30, 2019 at 8:01 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Thanks for the reminder to do this.
  16. Nov 30, 2019 at 8:03 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    ^^^ X2.
  17. Nov 30, 2019 at 9:57 AM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    A good inspection will also check the indoor and outdoor fan amps and balancing to make sure the motors are running good, use a combustion analyzer, clean the flame sensor, check the filter, clean the burners if needed, go thru the humidifier, check for operation, do a CO check, tighten all wires / connections; check, tighten and clean thermostat, and out of safety I check the water heater.
    I agree with @19TundraPlatinum that this can seem like a waste of money, but sometimes we can avoid a breakdown with preventative maintenance. Most of the time Murphy's Law applies but at least I can say I worked and noted the specs on each and every client's furnace that I check.
    Black Wolf likes this.
  18. Nov 30, 2019 at 8:52 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    That sounds thorough. I’d be curious if every HVAC tech would be this articulate?
    I never sit and watch as I feel the tech would think I’m bird digging them. I guess I just assume they are doing everything.
  19. Dec 1, 2019 at 5:30 AM
    Trooper2
    JR
    I always watch and ask questions. It is "My" service that is being paid for......
  20. Dec 1, 2019 at 5:41 AM
    grannynancy
    Nancy
    Upstate SC
    2007 DC TRD 4WD
    THIS^^ and I get a printout report on all of the findings and any corrective actions. I have a zoned system as well and they check all that. My main filter is a monster HEPA filter that you have to go into the attic to install once a year, too. That is part of the service (replacing it; I have to buy the filter)
  21. Dec 1, 2019 at 6:07 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Once a year
  22. Dec 1, 2019 at 6:13 AM
    There are several reputable service outfits here in Denver Metro and competition is fierce keeping prices low. Check Tom Martino's referral list for your area. Service specials all the time.
    BTBAKER[QUOTED][OP] likes this.
  23. Dec 1, 2019 at 6:16 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I have my NG heater checked yearly.
  24. Dec 1, 2019 at 6:20 AM
    CMat
    CMat New Member
    Craig
    Lebanon Maine
    2014 Tundra Limited
    personal plow, tool box,
    You really should do it every year. Especially cleaning the ducting and fuel valves. And replacing the filter. It will run smoother, last longer, burn cleaner, and just be a lot more efficient.
    I do my own. it’s easy enough to do and it’s cheap. I typically Budget $75 a year on parts. Vacuum and brush off the burners. Takes me a couple hours. Just be careful. There are pieces in there you can’t touch. YouTube it!
    If you live in an area that gets weather I strongly recommend you know how your furnace operates. These things always seem to break down on Saturday morning just before you get 15” of snow.
    And I find the best way to understand how something works is to do your homework first and then clean it.
  25. Dec 1, 2019 at 6:27 AM
    cnoyes72
    cnoyes72 New Member
    CT
    2018 Tundra SR5 DoubleCab 4x4
    Driver-side assist handle, extang trifect 2.0 tonneau cover
    Oil burner, every year.
  26. Dec 1, 2019 at 7:19 AM
    Lightning_Lad
    Lightning_Lad New Member
    Tom
    Orange CA
    2017 Silver Sky Platinum Pro
    Line x Bed liner Trifold Tonneau cover TRD PRO Dual exhaust TRD PRO sway bar TRD PRO air intake TRD PRO suspension TRD PRO LED 2019 Headlight conversion TRD 2020 Wireless charging tray TRD shift knob TRD PRO Grille TRD red anodized dust caps (+25 hp per wheel) Matt black mirror caps and door handles Tesla style Headunit KTJO 4x4 tail gate pop n lock upgrade Driver side grab handle Viper Remote start Viper alarm system 18” Method NV’s 33.5” Toyo R/T ESP Long box underseat storage 3M ceramic tint
    Speaking as an commercial HVAC/R journeyman, the residential side of the trade is chock full of idiots and sales techs whose sole mission is to sell.
    At least here in SoCal anyways...
    Here’s my take on residential maintenance;
    1) Get your systems checked out at twice a year.
    2) Ignore anyone doing inspections for less than $150. They are sales driven with little to no technical knowledge.
    3) To do a good tune up physically takes 2 hours.Checking operations, checking ductwork (fuk attics) cleaning the heat exchanger and AC coils then doing a CO and combustion analysis takes time, skill and expensive equipment.
    4) Clean up your house/attic/garage before they come out. Too many fat, lazy, extreme hoarders expect trash clean up and haul away as part of the service. Just to access equipment.
  27. Dec 1, 2019 at 7:25 AM
    19TundraPlatinum
    Maryland
    4 inch filter is the way to go. I put one in when I just recently did my change out at my house. A5CABC86-6FF5-4C96-B4A0-A3D41F742AAB.jpg
  28. Dec 1, 2019 at 7:28 AM
    19TundraPlatinum
    Maryland
    Love the hoarder part. It was awesome when the pictures on the paperwork from the salesman would show a complete disaster and they would note that “they told the customer to have it cleaned up”. Sell new flues and line set and the basement is literally packed to the ceiling with sh!t. Good point if you want your tech to do a good job cleaning up the area is a huge help. If it’s a disaster he’s gonna be in and out as fast as possible.
  29. Dec 1, 2019 at 7:35 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    We have two AC units, one for downstairs & one upstairs (both outside on the side of the house) We have a NG furnace in the attic no one has been near since we bought the 5 year old house in 2008. They are both Carriers, the larger one's compressor failed in 2012 inside the 10 year warranty and Carrier paid for the parts, we paid about 500 labor. Both have had the resistors replaced twice, about 70 bucks each time (I know it's a 7.00 part but I'm not comfortable doing it myself).
    We ran the furnace for the first time this year yesterday.
    Guess I need to have it looked at.
  30. Dec 1, 2019 at 8:07 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Got a new furnace 6 years ago. Get it maintained every year, as it was a requirement for warranty for first 5 years. It’s one of the 97.5 efficiency ones. We have a 5 inch carbon filter, works great. Replace once a year. They come out tomorrow for the maintenance.
