How much are your oil changes?
Discussion in '2.5 Gen Tundras (2014-2021)' started by FrostyTundra22, Dec 1, 2022.
  1. Dec 2, 2022 at 6:19 AM
    Kung
    KG, VA
    I got 8 free oil changes when I bought my truck, so....$0.00 thus far. LOL
  2. Dec 2, 2022 at 7:19 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    I do as many services as I can by myself. I have heard too many horror stories from folks that get work done at a dealer/mechanic shop. The money savings is nice, but the piece of mind that it is done right is invaluable.
    I do oil and filter changes every 5k with Toyota filters and Mobil 1, costs less than $50. Recently did both differentials and transfer case with Ravenol fluids from Blauparts, and power steering fluid using Dexron III. Will tackle transmission fluid shortly.
    Tyman and 2mchfun like this.
  3. Dec 2, 2022 at 7:21 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Make sure he doesn't send you a bill for spending time replying to you.
  4. Dec 2, 2022 at 7:34 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Transmission service actually looks not that bad on this vehicle. New gasket and internal filter basket doesn't look expensive. Most other vehicles I've shied away from doing transmission anything at all with, but this one I might do myself. We'll see when I hit the 110k mark, which will be 50k after the last service.
  5. Dec 2, 2022 at 8:01 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    It costs me 45 bucks to do it myself. It's like 110 at one of the quick change places for full synthetic
    2mchfun likes this.
  6. Dec 2, 2022 at 9:27 AM
    2mchfun
    Do yourself a favor and research...only drain and fill, leave the pan alone! You will likely only have broken off pan bolts and a filter that is slightly discolored if you think otherwise. Good on you for making maintenance a priority though!:thumbsup:
  7. Dec 2, 2022 at 9:45 AM
    2mchfun
    $60 here, 5w-30 synthetic Mobil one, a Wix cartridge, a plug seal, and one Modelo. About 30-40 minutes taking my time and enjoying the quiet time away from the norm. I enjoy wrenching, and push my truck pretty hard so I have changed it three times so far and it's at 12k+. Added the Fumoto valve on the last one so now I can stop buying plug seals-no brainer! You guys go ahead and shop your shit and drink some old :censored: coffee!:puke:
  8. Dec 2, 2022 at 10:18 AM
    RickPlatinum2020
    Rick
    Eastern PA
    I have watched many videos about the trans pan bolts breaking off. Last time I was under the truck, the bolts all looked pretty clean; seems like the folks who have had them break talk about visible corrosion on the exposed shank of the bolt that weakened them. I plan on looking them over real good before even trying, then give them a shot of PB blaster for a few minutes. I would really like to clean off the magnets in the pan if I could. If the bolts look crappy, I will just do the flush and fill method.
  9. Dec 2, 2022 at 11:00 AM
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    actually, get under and spray fluid film/surface shield on the bolt heads. Will keep corroding to minimum in the case it needs to be dropped in the future.
    as for 45$ diy oil changes yep,
    Was at a midwest Tuffy repair shop and its 99$ for syn oil change for 5 quart so it’s going to be more expensive for nine. And then you never know really the person who’s doing it and how much experience they have with your make and model.
    2mchfun likes this.
  10. Dec 2, 2022 at 1:31 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Just changed my oil, got everything from Walmart including the Toyota oil filter. $37 x2 Royal Purple 0w20 $8 Toyota oil filter. $82 plus hour of my time.
  11. Dec 2, 2022 at 2:54 PM
    el_conquistador
    el_conquistador New Member
    Kansas City, MO
    2019 Toyota Tundra 1794 Edition
    Just a few
    I bought an oil change package from Hendrick Toyota in Merriam, KS. I have their Lexus dealership do it up north bc it’s closer. High quality setup. Paid about $350-375 for the package for 20,000 miles of service @ 5k. If that makes sense….lol
  12. Dec 2, 2022 at 6:33 PM
    lloydb82
    lloydb82 New Member
    Lloyd
    2021 tundra limited crewmax
    I do my own oil changes with amsoil. Signiture series with the amsoil filter. Used to only cost about 90 dollars but due to inflation its about 130 now. 10k or 1 year. Which ever comes first. Been using amsoil since 2014.
    Tyman and LS3 like this.
  13. Dec 3, 2022 at 7:58 AM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Do my own $46. Using mobil one and toyota filters. And doing tire rotation. And one hour of my time. I like checking the whole truck out and know it's done right. Fastest a dealer ever changed my oil with drive time is 2 hours so 3 hours is normal. So it's a easy choice 1 hour and save 50 bucks or 3 hours of my time and pay dealer 50 bucks more than it costs me.
  14. Dec 3, 2022 at 8:49 AM
    soobaroo
    soobaroo New Member
    Gene
    2019 Tundra SR5
    Paid $103 at my dealer with tire rotation. Usually do my own for about $75 but it’s cold out and I needed the wiring harness recall done also. They do a good job so I wasn’t concerned about them screwing anything up
    el_conquistador likes this.
  15. Dec 3, 2022 at 1:35 PM
    jrquist
    jrquist Canon Shooter
    Carlton, Minnesota
    2020 Tundra Sport Super Bright White
    If you don't have a Fumoto valve you need to get one. The other thing is to take the POS skid plate off in the fall and put it back on in the spring. I switched over to the Pro skid plate just for the fact it makes it so much easier to do an oil change and you don't have to mess with the bolts. By the way I am about 140 miles north of you and plan and doing my own but will try to wait till its kinda warm out before changing.
    FrostyTundra22[OP] likes this.
  16. Dec 3, 2022 at 2:29 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I’ll echo around $45 I do myself
    Costco 0-20
    Toyota oem filter
    takes about 20 mins
    I do the whole fam throughout the year
    Highlander is way easier than tundra or 4Runner
    the Tesla….. well… it mocks me.
    FrostyTundra22[OP] and Buckaroo like this.
  17. Dec 3, 2022 at 10:12 PM
    FrostyTundra22
    FrostyTundra22 [OP] No longer new member
    2020 Toyota Tundra 1794 Crewmax
    Nice! Since I just did my oil, I won’t need to do it for a while but would like to do my own transfer case and transmission fluids.
    it’s been cold these days, so will probably need to wait a while.
    i believe that in order to do the transmission fluids, I will need to drop the Miller Cat shields which I do not look forward to doing.
    nobodyintexas likes this.
  18. Dec 4, 2022 at 3:48 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    start with rear diff fluid. it's easy.
    Rocko9999 and WILLINH like this.
  19. Dec 4, 2022 at 4:08 AM
    #49
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Do my own oil changes with a Toyota filter. But just had a shop I trust change it they charge $80 and the use Mobil 1.
  20. Dec 4, 2022 at 4:57 AM
    #50
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Excellent video it was posted elsewhere recently but can't find the thread. Recommend watching more from him, expert w/ Toyota. I'll list my major takeaways that I've integrated into my PM for my '21.
    Oil & Filter: 5k miles or 6mo. (5w-30 Amsoil OE) *Personal preference.
    Transmission Fluid: 60k or 6yrs. (OME)
    Coolant: 50k or 5yrs. (OME)
    Differential & Transfer Case: 30k (OME or Aftermarket)
    Power Steering Fluid (Aftermarket Fluid)
    Spark Plugs: 120k (OME)
    https://www.youtube.com/watch?v=TevK-u3vkx4&t=1004s
  21. Dec 5, 2022 at 2:14 PM
    #51
    BuilderBee
    BuilderBee New Member
    Southern California
    2017 Tundra Double Cab TRD SR5
    BakFlip MX4 Tonneau Cover Stubby Antenna Husky Floor Liners
    My dealer has a deal for 3 oil changes with tire rotations for 150.00.
  22. Dec 6, 2022 at 4:54 AM
    #52
    Raupps
    Raupps New Member
    ryan
    Broomfield, CO
    21 SR5
    Stuff and thangs
    Mountain states Toyota in Colorado wanted to charge 160 with a tire rotation. After I laughed at that we agreed to 4 oil changes with tire rotations for 220. I have 4 years to use them.
  23. Dec 7, 2022 at 11:05 AM
    #53
    PJR202
    PJR202 New Member
    ok, where in the hell are you all buying Mobil 1 and an OEM filter for less than 50 bucks??
  24. Dec 7, 2022 at 11:11 AM
    #54
    AsThe_SkyFalls
    AsThe_SkyFalls New Member
    2020 Black Tundra TRD Pro
    Mine does the same deal for $165 so about $55 per oil change
    BuilderBee[QUOTED] likes this.
  25. Dec 7, 2022 at 11:21 AM
    #55
    Adamace1
    Adamace1 New Member
    None....
    My Toyota dealer charges less than 6 bucks for oil filter with tax. And Costco just had 6 quart packs of mobil one on sale for 26.99. I bought 30 quarts to stock up. So I should be doing my next 3 oil changes in the 45$ range
    Walmart my me used to sell 5 quart jugs of mobil one for 22.99 but now they are 29.99. But with tax and filter your still below 60 bucks. O by the way I love costco.
    Rocko9999 and MadMaxCanon like this.
  26. Dec 7, 2022 at 11:57 AM
    #56
    MadMaxCanon
    You can get toyota filters from dealers for less than 5 bucks if you look, and alot of them come with a free shipping code too. And yes, costco is amazing. I too bought the max allowable amount when they had the oil sale. Did that twice lol.
    You can also find mobil 1 75w-90 for 10 bucks a quart or less if you look at bulk. I bought 12 on Amazon for 110 bucks a few months back. I am set for a few years lol
  27. Dec 7, 2022 at 3:56 PM
    #57
    Adamace1
    Adamace1 New Member
    None....
    Yea I was just responding to the guy asking how are people finding the oil and filters for 50 bucks. I am fine paying almost 6 bucks for filters from my dealer. I will take all my business their until they do me wrong. I didn't know you could get the deal more than one. I tried on xbox cash cards and they cut me off in store and online once I hit the limit. And they couldn't tell me if it was a lifetime limit or what limit it was?
  28. Dec 7, 2022 at 6:11 PM
    #58
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    Dealer charged me $100 for the 1st oil change. I requested it before the toyotacare required change. I'll let them deal with it until toyotacare is up, then I'll take over like everything else.
  29. Dec 7, 2022 at 6:22 PM
    #59
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    DIY $78 Toyota oil/filter from Amazon. Used to be $64 for a long time, but prices went up in summer.
  30. Dec 7, 2022 at 7:14 PM
    #60
    PJR202
    PJR202 New Member
    Wow. Closest place to me that sells Mobil 1 is 36.99 for 5 qts, and 10 for the filter. To drive to the nearest dealer (charges 90 for the oil change) and back costs me $15 in gas. It's amost as far to drive to Walmart.
