How many of you have the TRD Cold Air Intake?
Discussion in 'Performance and Tuning' started by toyobama, Jun 14, 2018.
  1. Jun 17, 2018 at 1:03 PM
    Areith762
    Areith762 Go Avs!!!
    39.944182, -104.760113
    2017 Blazing Blue 5.7L CM SR5 4X4
    DAP Tune, Katskin interior leather, ESP rear under seat storage, door sill protector, door edge protector, TRD Pro shift knob, heated seats, all weather Tundra floor mats, driver side a-frame handle, Tundra trucks center console emblem, clear bra protection, Bushwacker fender flares, paint match front bumper caps, paint match rear bumper caps, paint match mirror caps, ProComp 3/1 lift, 20" Fuel wheels, 33-11.50/R20 Falcon tires, black TRD Pro badge's, black Tundra tailgate badge insert, TRD Pro headlights, Recon smoked tail lights, Recon smoked 3rd brake light, Roll N Lock tonneau cover, Line-X bed liner, Tundra bed mat, Cobra led remote alarm/remote start, N-fab tube steps, factory match window tint, TRD Pro grille -paint matched, paint matched hood bulge, TRD dual exhaust, Black out exhaust tips, led interior lights, led plate lights, Spyder smoked fog lights, TRD Cold Air Intake
    I have the TRD CAI. Its pretty much $300 for a lid that says TRD with a washable filter.
    Black Wolf likes this.
  2. Jun 17, 2018 at 1:19 PM
    Rica25
    Ricardo
    Tulare
    On the bypass.....do I hook up one line that goes from radiator to the block and the other line that come from tb back to its self so that way there is something there and not 2 empty open lines on throttle body?
  3. Jun 17, 2018 at 1:44 PM
    Rica25
    Ricardo
    Tulare
    Does this look right?
  4. Jun 17, 2018 at 9:06 PM
    Rica25
    Ricardo
    Tulare
    Best mod yet is going back to stock intake and TRD drop in filter......Throttle body coolant by pass with TRD air flow accelerator much better throttle response and feels quicker
    Brian3UR likes this.
  5. Jun 17, 2018 at 9:48 PM
    ZPMAN
    Minnesota
    This is not bypassed but will have to investigate when i get home. This TB is turned °180 for the SC.20180618_004108.jpg
    nk1794 and 15whtrd like this.
  6. Jun 17, 2018 at 10:03 PM
    ZPMAN
    Minnesota
    This air box and filter will get you about 550 HP
    :crapstorm:
    Ericliciousness and nk1794 like this.
  7. Jun 20, 2018 at 8:23 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    You want two open lines on the throttle body. The lines leading to brittle body are connected together
  8. Jun 23, 2018 at 7:22 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Found a YouTube vid on the mod. Configuration of my hoses are slightly different than vid but pretty simple. Will do tomorrow.
  9. Jun 25, 2018 at 2:21 PM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Donesky. Pic to follow. I have 2 questions for you guys about the bypass. It appears that the bypass connects to the thermostat housing. What I'm wondering is, does the thermostat shut off the flow to the throttle body once it reaches operating temperature? If it does there is no need for this mod. Second, the bypass hose is touching the throttle body electronic actuator. I'm wondering if this will add temperature to that electrical component which could be bad.20180625_154342.jpg
    nk1794 likes this.
  10. Jun 25, 2018 at 3:07 PM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I spoke to the tundra technician at my dealership today regarding the bypass. First, he said that he is fairly certain that the ambient temperature in the engine bay during our hot summers here in Texas will likely exceed 220 to 250 degrees. And if that's the case then the hot coolant at a 190 degrees would actually provide some cooling to the throttle body in that environment. What do you guys think?
  11. Jun 25, 2018 at 5:00 PM
    ZPMAN
    Minnesota
    I decided to run Red Line in my Tundra to help prevent preignition (non yet) with the new Supercharger. I have used it in all my moto-X bikes and it really made a difference preventing preignition. 20180607_210058.jpg
  12. Jun 26, 2018 at 4:12 PM
    Brian3UR
    Brian3UR New Member
    2013 Silver Sky DC 4x4
    Drop in K/N filter with TRD airflow accelerator BullyDog GT Tuner 2.5" Suspension leveling kit TRD rear sway bar Line-X bedliner Charcoal Filter (in air box) delete Deleted screen in throttle body gasket Coolant to throttle body bypass LED lighting inside bed and under hood Center console from 2007 Tundra with LED light for cup holder Small amplifier and subwoofer to enhance factory radio BAMuffler TRD Dual Replacement system (on order) LED headlights, fog lights, brake, tail and interior lights Side mirror glass with turn signal indicators (from Platinum model)
    I had the TRD intake on my Tundra and thought it was fine until I installed a BullyDog tuner. After the install, the engine would seriously cut out at about 4,000 RPM and really lose power. I chased this for some time and Keith Carty advised me to put the stock air box back on it. I was skeptical but tried it (with a drop in K&N filter) and was amazed when the problem went away. Anybody want to buy a gently used TRD intake??
    Parrothead_DFW likes this.
  13. Jun 26, 2018 at 4:15 PM
    Brian3UR
    Brian3UR New Member
    I still think anything adding heat to the throttle body is a bad idea. Yes, the under hood temp may be as he says but the intake air is coming from outside the engine compartment through an opening in the RH inner fender.
  14. Jun 26, 2018 at 5:35 PM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    The technician also stated that the flow of coolant is severely restricted to that passage whenever the thermostat opens up. So essentially you're only flowing hot coolant until the engine warms up and then almost none after. I reversed the bypass today. I'm only out 4 hose clamps and short piece of hose.
  15. Jun 27, 2018 at 3:35 PM
    Brian3UR
    Brian3UR New Member
    Interesting, the next time I have a 5.7 apart, I'll pay particular attention to the setup near the thermostat. I'm not sure how the thermostat opening would shut off the passage as it's located where the coolant actually goes back into the engine but this merits further investigation, lol. Thanks for the input.
  16. Jun 27, 2018 at 3:41 PM
    Brian3UR
    Brian3UR New Member
    Even if the passage is shut off whenever the thermostat is open, hot coolant will still circulate through the TB because once open, the thermostat does not stay that way. The t-stat opens and closes as you're driving depending on the demands of the cooling system. As for the bypass hose touching the electric actuator, wire tie it to the secondary air tubes and it won't be an issue.
  17. Jun 27, 2018 at 6:23 PM
    Nick T
    Nick T New Member
    Nick
    Brian3UR ,
    Please share your secret on how to get coolant on a fully warmed engine to go below 180° long enough for a thermostat to begin closing. I would drop a 160° thermostat in with your coolant secrets so i do not have to worry about pre detonation.
    Thank you
  18. Jul 1, 2018 at 4:42 PM
    Brian3UR
    Brian3UR New Member
    I'm not sure I understand your question completely. In my experience you do not want the engine coolant temp below the factory specification. Lower coolant temperatures cause the engine to consume more fuel (not fully warmed up) and will likely set a Check Engine Light trouble code. Also from my reading, lower coolant temperature accelerates cylinder bore wear and contributes to oil contamination. Cooler is not always better and (within reason) a hotter engine is a more efficient engine.
  19. Jul 1, 2018 at 6:56 PM
    #49
    Nick T
    Nick T New Member
    Nick
    How are you cooling your engine under 180° so your thermostat begins to close per the above quote ?
  20. Jul 2, 2018 at 11:42 PM
    #50
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
  21. Jul 4, 2018 at 2:48 PM
    #51
    Brian3UR
    Brian3UR New Member
    I am not cooling the engine to below 180 deg nor am I trying to do so. I simply eliminated the throttle body from the system by installing a bypass connecting the supply and return passages for the throttle body. I cut a throttle body up to verify that there is no "hocus pocus" going on in there. It is simply a 90 deg passage through the throttle body which I feel is detrimental to intake air temp (at least in the summer).
