How many of you are running replacement steering kits w/ your lift?
Discussion in 'Suspension' started by joem1cha3l, Jul 23, 2017.
  1. Apr 20, 2018 at 12:57 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    2wd and 7" lift = front sway stays to me too.
    joonbug, TheBeast[QUOTED] and Jsena like this.
  2. Apr 20, 2018 at 1:09 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    dcsleeper408 and Jsena like this.
  3. Apr 20, 2018 at 1:52 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    10 mins is a looooong time
    1UPPER, TheBeast, GodlessPro and 3 others like this.
  4. Apr 20, 2018 at 2:05 PM
    Steering kit needed for 6" kit?
    Jsena likes this.
  5. Apr 20, 2018 at 2:06 PM
    Looks like I'm ordering ABS sensor gaurds too
    831Tun and Jsena like this.
  6. Apr 20, 2018 at 2:19 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I just did.. get the mod bug out of me for a little bit.. going to order UCA soon too
    1UPPER and TheBeast like this.
  7. Apr 20, 2018 at 2:51 PM
    Which ones?
    Jsena[QUOTED] likes this.
  8. Apr 20, 2018 at 2:53 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  9. Apr 20, 2018 at 2:54 PM
    Nice!
  10. Apr 20, 2018 at 2:56 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  11. Apr 20, 2018 at 4:42 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    dcsleeper408 likes this.
  12. Apr 20, 2018 at 4:45 PM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Warren is such a show off.
  13. Apr 20, 2018 at 4:46 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Or, more likely prone to extreme exaggeration.
  14. Apr 20, 2018 at 9:45 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    The Long Travel guys have to run extended tie rods to make up the new distance to the spindle. Those are usually included in the LT kit.
    Us Mid Travel guys don't have that issue. Our shafts are shorter, but that just means we try harder.
    I may not hit rock bottom, but I'll scrape the hell out of the sides trying.
  15. Apr 22, 2018 at 8:11 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    Ok so let me see if I can provide some clarity here
    By steering kit do you mean something like the heim tie rods available through coach builder?
    If so here is the skinny on those. They are not needed on street trucks, they do add a level of adjustment ability some may need to get proper alignments and have smoother movement off road and on compared to stock style tie rods. However they are not needed even on 16"+ of travel on long travel trucks. Some of us (myself and others) added the Heim'd tie rods over stock for added strength and less chance of binding.
    But if you ask @osidepunker he runs the piss out of his truck with stock tierods and 0 issues. Toyota has incredible tie rods very strong and work great, there is no need for upgrading.
    Now in referance to the rest of the steering components, a good upgrade is urethane mounts for steering rack, however that is a big job to do, and isnt needed if not doing hard off roading and if the stock ones haven't failed yet.
    So no one should consider upgrading steering components unless a few conditions exist:
    Binding due to odd alignment #'s with some bracket lifts.
    Run out of adjustment due to some odd issue with trucks alignment
    You have $ burning a hole in your pocket to upgrade something else on the truck
    You are smashing you truck hard enough off road you either bend or worry about tie rod strength (I seriously doubt this is happening to anyone)
    this all comes from experience with a few different lifts on these trucks as well as years of wheeling and wrenching. But hey its the internet so dont believe everything you read.
  16. Apr 22, 2018 at 8:16 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    This ^^
    I have logged many seriously hard dirt miles and I have taken lots of hits that I thought would yard sale The Truck. Stock steering is strong enough.
    My rubber rack bushings are getting pretty loose. I have a poly replacement kit sitting in the garage, but doing the work is not easy
  17. Apr 22, 2018 at 8:21 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    I have some too... when its time come over ill help ya.. ive delt with steering crap before I know some tricks
  18. Apr 22, 2018 at 8:32 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Yeah we'll plan a day and do both trucks at the same time. We'll use my garage, it's cleaner than yours lol
  19. Apr 22, 2018 at 8:34 AM
    #49
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Im fixing that
    and hopefully Ill have my shop built by then..
  20. Apr 23, 2018 at 9:19 AM
    #50
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    The tie rod joint is more prone to failure than the actual arm.
    Jsena, dcsleeper408 and papasmurf like this.
  21. Apr 23, 2018 at 9:55 AM
    #51
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I haven't heard of anybody having a steering failure besides the rack going out. Have you?
  22. Apr 23, 2018 at 10:16 AM
    #52
    n2deep
    n2deep Pavement Princess
    Funny the stuff people spend money on that's not needed just because they want to add a mod. I was the first to make ABS shields but i only run them in the rear - the front aren't really needed unless you do lots of dumb stuff.
  23. Apr 23, 2018 at 10:18 AM
    #53
    osidepunker
    Alex
    2013 Tundra DC 4x4
    You need the fronts for snow wheeling or deep mud
  24. Apr 23, 2018 at 10:20 AM
    #54
    n2deep
    who wheels in the snow or deep mud? If your buried to the axle you aren't moving so nothing to hit them. 8yrs and my fronts are still working - not even a mark on them.
  25. Apr 23, 2018 at 10:22 AM
    #55
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Some overland group I used to follow did a cross canada trip. they were on regular roads, but lots of snow and they lost two sensors on two different tundras. I just did all four since I was making them
  26. Apr 23, 2018 at 10:27 AM
    #56
    n2deep
    They need to drive better.
    dcsleeper408 and osidepunker like this.
  27. Apr 23, 2018 at 10:29 AM
    #57
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    You do not need to upgrade the steering kit for a 3-4" lift. I had mine at 3.5" for a while and now back down closer to 3" with no issues to those components.
  28. Apr 23, 2018 at 10:32 AM
    #58
    csuviper
    Broomfield, CO
    I highly recommend the @sdhq_offroad ABS sensor guards. Simple install and good protection for a sensitive expensive device.
    https://www.tundras.com/threads/diy-abs-sensor-guard-install.11252/
  29. Apr 23, 2018 at 10:40 AM
    #59
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Ya I’m going to order that Coach builder Tie rod end.. @Coachbuilder1 told me it gives me more movement than the Stock one.. maybe give me a little better alignment
    papasmurf likes this.
  30. Apr 23, 2018 at 10:45 AM
    #60
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    yes that is all correct...
