How many buy a fifth, really nice tire/wheel for the spare?
Discussion in 'Wheels & Tires' started by Sas, Aug 3, 2018.
  1. Aug 3, 2018 at 3:30 PM
    Sas
    Sas [OP] Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Yep. There's a 1.5" difference between the spare and new setup though so I'll end out replacing it. Might be able to at least keep the rim.
  2. Aug 3, 2018 at 3:33 PM
    Sas
    OKC, OK
    :devil:
    NewImprovedRon likes this.
  3. Aug 3, 2018 at 3:33 PM
    Sas
    OKC, OK
    285/55R20, 20x9, +50 offset
    Looking to go to 305/65R18, 18x9, +18 offset
    jewsNbrews likes this.
  4. Aug 3, 2018 at 3:44 PM
    Sas
    OKC, OK
    I'm using the same site. :)
  5. Aug 3, 2018 at 3:51 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    You bastards keep making me go outside to look under at my spare lol, it's not the same tire as the original 4? ("not for highway use")
    Sas[OP] and NewImprovedRon like this.
  6. Aug 3, 2018 at 4:04 PM
    Sas
    OKC, OK
    Interesting, mine didn't have that stamp on it. Bridgestone Dueller H/T.
  7. Aug 3, 2018 at 4:04 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    I have a 5th spare that I rotate in. I put a sensor in it and everytime I rotate, my light stays on for about 10 miles and goes out.
    Sas[OP] likes this.
  8. Aug 3, 2018 at 4:10 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I’m in no rush but I’m looking for a 5th RW wheels to use as a spare with matching tires.
    Sas[OP] likes this.
  9. Aug 3, 2018 at 4:11 PM
    Sas
    OKC, OK
    Nope. It's gonna get replaced anyhow so I'll look at the other side at that time lol.
  10. Aug 3, 2018 at 4:20 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Just looked under AGAIN, mine's a BD too. Excuse Mich in previous posts, my stocks were originally BD HT's.
    Ok Ron, cut it out! (steps out to drop spare... kidding)
    Priced out an extra NRG 295/70R18 on Method Mesh, would be $700+tx, ouch
    Sas[QUOTED][OP] likes this.
  11. Aug 3, 2018 at 4:21 PM
    Sas
    OKC, OK
    Is that from Mr. Wheel Deal?
  12. Aug 3, 2018 at 4:31 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Didn't really shop around, I'm in Canada so it would be 1010tire and 4x4WheelParts I'm going off of. A used 295/70R18 I'm guessing would probably be $150 installed on my steely.
    Edit: I'd probably get a deal off my buddy who owns a custom rim shop, maybe save $100 if exact 5th.
  13. Aug 3, 2018 at 5:31 PM
    One thing to keep in mind......if your spare is fairly close in height to your good tire on the rear, you can air down one of them to equalize height between the two. Just sayin. It's only temporary till you get home.
    bmcdds, gosolo, JoshuaA and 1 other person like this.
  14. Aug 3, 2018 at 5:39 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Pinay, Black Wolf[QUOTED] and Sas[OP] like this.
  15. Aug 3, 2018 at 5:50 PM
    Dheav
    Dheav New Member
    Las Vegas
    2015 Tundra SR5 Crewmax TRD
    Icon Stage 7 Suspension
    I carry a full size spare that matches my wheel and tire set up.. If you do any hard off roading its a requirement.
    SAGE63, Pinay, Black Wolf and 2 others like this.
  16. Aug 3, 2018 at 6:14 PM
    Sas
    OKC, OK
    What would you consider hard off-roading? What may be hard to me might seem like a Tuesday morning drive to work for you.
  17. Nov 8, 2018 at 6:05 PM
    goffredo
    goffredo Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    Alright, for all of you who do the 5-wheel rotation thing, is there a specific rotation pattern you follow, and how often do you rotate? I do a lot of offroading and have upgraded to larger tires, so I want to include the spare tire in my rotation for reasons mentioned previously in this thread.
    This is interesting about your TPMS light. I wonder if the TPMS system is only monitoring four of the five tires, which I've read is how it works. So that as long as the four tires it's monitoring are within range, and are properly inflated (even if one of them happens to be mounted in the spare tire location), the TPMS system is happy.
    Erichudgins[QUOTED] likes this.
  18. Nov 8, 2018 at 6:15 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Just 1 spare? :anonymous:
    SAGE63 and joonbug like this.
  19. Nov 8, 2018 at 6:17 PM
    #49
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Had this for years, tire finally rotted and needs to be replaced.
    Pinay and 831Tun like this.
  20. Nov 8, 2018 at 7:21 PM
    #50
    Tundra9831
    Tundra9831 New Member
    On a 2018+ with the 4 tire pressure readings on the dash is it best to put a TPMS sensor in the spare if doing a 5 tire rotation? Would the spare TPMS sensor screw up the dash display?
  21. Nov 8, 2018 at 8:07 PM
    #51
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  22. Nov 8, 2018 at 8:31 PM
    #52
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No. The TPMS in the spare won’t affect it because the truck only monitors 4 of them. But if you rotate tires, you’ll have to get it reprogrammed to the 4 tires on the ground. I have 5 TPMS but only 4 are being monitored. I’m not even sure which tire is the one turned off right now but I know it’s one of the 4 on the truck. Not a big deal to me because I air up/down so often I’ll know if I have a slow leak. And when I’m offroad and aired down, the light is on anyways so it won’t tell me if I have a flat anyways. If I knew this when I bought my tires, I wouldn’t have bought the fifth TPMS.
  23. Nov 8, 2018 at 9:26 PM
    #53
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Someone else posted up the picture already for a five tire rotation and as for the TPMS I have five sensors in all of them just to keep the stupid light off. The Tundra TPMS system can only monitor four at a time.
  24. Nov 8, 2018 at 9:44 PM
    #54
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    I bought a 20” Fuel spare rim, from America’s Tire, as they scratched my new rims...
    I noticed it, called them on it and got a killer deal on it the scratched one, $95 bucks for a $320 d rim...
    Now I need the tire
  25. Nov 9, 2018 at 10:08 AM
    #55
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    What Joonbug posted above is the pattern I've always used. Every 5000 miles.
  26. Nov 9, 2018 at 10:20 AM
    #56
    goffredo
    Ok so I have 4,850 miles to go before I have to buy a 18" TRD off road package wheel for the spare, to match the other four! They seem to be hovering right around $200 on Ebay.
    #56
  27. Nov 9, 2018 at 10:20 AM
    #57
    I'd like to, actually I do need to, matching? No, just same size
    Pinay likes this.
  28. Nov 9, 2018 at 11:05 AM
    #58
    goffredo
    Hah yeah, this Tundra is the nice truck. The frankenstein mismatched wheels and 2" of interior dust are on the old 99 Tacoma.
  29. Nov 9, 2018 at 11:10 AM
    #59
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    I’ve always don the same nice tire, then a shitty wheel to put the tire on. That way I can have a full size spare and if I happen to pop one to the point it’s not repairable , I can put that brand new tire on a wheel and buy another to match then use the old “good” tire as a spare....
    You guys follow?
  30. Nov 13, 2018 at 5:15 AM
    #60
    Stig
    Stig New Member
    Except that tire may not be brand new anymore if it has sat under your truck for 5 to 10 years. It will not perform the same as the other 3. Better to use the spare to get where you need to go and buy a new tire for the wheel that went flat.
    Thegr8punkin[QUOTED] likes this.
