How does this drive in the snow?
Discussion in '2.5 Gen Tundras (2014-2021)' started by SweetTeeBag, Oct 15, 2021.
  1. Oct 15, 2021 at 6:33 AM
    SweetTeeBag
    SweetTeeBag [OP] New Member
    Western New York
    2018 Inferno Crewmax Limited
    I drive 45 min one way to work everyday. I used to have a 2016 Silverado with the auto option and always left that on during the wintertime and no issues. Now have a 2018 Tundra Limited Crewmax. Live in the Buffalo NY area. I can just pop into 4 HI any time and I'm good to go? Will it drive like a dream?
    GT87 likes this.
  2. Oct 15, 2021 at 6:38 AM
    Pine Tree State
    Pine Tree State New Member
    2021 SR5 TRD Sport CM
    Well, 4 hi is a lot different than 4 auto. 4 Hi you need to think about what you are doing. If its dry pavement, turn it off, otherwise you will bind up on corners. If its slushy, you can usually use 4 hi but I still turn it off when I enter a parking lot and know I will be doing a tight turn into a space. You have to be very aware of pavement conditions when deciding to use 4wd.
    My rule of thumb is any time there is white stuff on the road I am in 4wd. When I know I am going to park, I turn it off before hand. The 4wd system also tends to have trouble if you are parked still and then try to turn off 4wd, so sometimes you might have to stay in gear and drive or reverse to get it to turn off while its blinking.
    I recommend fully reading the manual that goes over this and the operation of 4wd.
  3. Oct 15, 2021 at 6:39 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    No. It won't make tight corners without grinding. I use mine on straight always and no sharp turns.
    2wd most of the time for me in the snow capital of Canada where we have winter 6months of the year.
    Good snow tires or snowflake rated tires are a good idea.
    Or what @Pine Tree State posted above.
  4. Oct 15, 2021 at 6:52 AM
    WhyW8
    WhyW8 “It’s ALWAYS Loaded”
    HB
    Sunny AZ
    2017 Super White SR5 CM
    Level Kit, DiamonBack Tonneau, Step Boards, Alpine Amp, Cerwin Vega powered Sub
    The tundra should drive quite well in the snow
    30 plus years in Alaska - drove in 4 wd maybe 20% of the time. If it was good and cold and the roads were plowed I used 2wd -- if fresh snow, roadways not plowed yet or freezing rain I used 4wd as needed. Good tires and good old commonsense go miles.
    oh, by the way: never once did driving in 4wd ever helped me slow down or stop!
  5. Oct 15, 2021 at 7:02 AM
    Pinski
    Pinski New Member
    Mark
    Western New York
    2018 SR5 TRD Crew
    Volant (Corsa) cat back,tint
    Hey neighbor, good tires along with 2-300lbs in the bed and you will be fine. People laugh but that little bit of extra weight really helps!
  6. Oct 15, 2021 at 7:06 AM
    joe_from_iowa
    joe_from_iowa New Member
    Iowa
    2021 Tundra Double Cab SX
    Peeled off the SX stickers from the bed sides. Tyger running boards. A.R.E. DCU topper
    Stomp and steer!
    WhyW8 and SweetTeeBag[OP] like this.
  7. Oct 15, 2021 at 7:07 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Correct tires will make it drive like a dream.
    I'll drift sideways in 4wd with my stock Bridgestone's because they're half tread and not designed for snow.
    SweetTeeBag[OP] likes this.
  8. Oct 15, 2021 at 7:09 AM
    SweetTeeBag
    Western New York
    Yeah I have some Goodyear Wrangler Duratrac on her with about 25K on them. Just had it at the dealer and they said they looked great still.
    Jaypown[QUOTED] likes this.
  9. Oct 15, 2021 at 7:11 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    Howdy neighbor! I'm near Rochester NY and have been through 3 winters in a Tundra. I drive about 30 mins one way to work and never once had an issue, not even a close call. If the snow is coming down or if its really wet/slushy I'll put it in 4Hi (sometimes). Other than that I just pimp along in 2wd. I've never had a vehicle that does better in the snow than the Tundra. Just keep good tires on it and drive smart and you'll be just fine.
  10. Oct 15, 2021 at 7:18 AM
    joe_from_iowa
    Iowa
    I just bought my '21 Tundy in April. Mine's an SR5 XS so it has pretty much street tires on it. We'll see how it does. My previous truck, an '01 Tacoma, had some nice off-road / snow tires on it and they performed great.
  11. Oct 15, 2021 at 7:20 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I lived in upstate NY for five years driving a 2011 Taco 4x4. Sometimes I would keep it in 4hi for days. Drove fine with some good tires and never had a problem.
  12. Oct 15, 2021 at 7:29 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    The stock ones are horrible in the snow. I had a '14 Tacoma with Toyo Open County AT's on it. Not the greatest tire but decent. Performed way better than these stock tundra tires.
  13. Oct 15, 2021 at 8:58 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I’ve had my 18 Tundra for one major snow and ice event which was several days long. Very lucky for me, I had just had snow rated 33” Coopers mounted.
    I came from a Camry, which had me slithering home and peeing my pants for 11 years of Oregon winters when there was snow or ice.
    The Tundra did well. I had a blast, and never slipped. I chewed over the 3 foot snow walls built up by the plows, easily managed deep icy ruts, and used 4WD for climbing and descending steep hills. I manage a healthcare center, and wound up being a main source of transportation for frontline workers who live all over the Portland and surrounding area for 3 days.
    I often feel like the guys who live in the NE US and Canada have developed an additional lobe on their brain to compensate for long periods of driving in snow and ice.
    No comparison for the PNW, where we see sporadic major weather events and don’t really have enough time to acclimate and evolve.
    But the Tundra made it seem easy, almost like a video game. I think you’ll love it if you have good tires.
  14. Oct 15, 2021 at 9:05 AM
    panicman
    Eric
    Forgot to mention: I also have a Diamondback cover and always throw two 75-pound sleeves of sand in the bed when freezing weather starts.
  15. Oct 15, 2021 at 11:01 AM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Put it in 4HI and send it. Dry pavement isn’t really an issue unless you’re trying to make a tight turn into a parking lot or something.
