How does front headlight marker bulb come out for replacement?
Discussion in '1st Gen Tundras (2000-2006)' started by Openbaffle, Jul 19, 2019.
  1. Jul 19, 2019 at 8:46 AM
    Openbaffle
    Openbaffle [OP] New Member
    2006 Phantom Gray Tundra X-SP DC
  2. Jul 19, 2019 at 9:04 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Can you see wires going into the headlight housing at that location? Unfamiliar with 1st gens, but the wires should be entering the bulb base which should have "handle" to turn the base one quarter turn or less to remove.
    Not trying to be a pain, but how did you learn the bulb number, from the owner manual? The reason I ask is that bulb is more likely the DRL/turn/park light bulb than side marker. Side marker will be located outboard where it is visible from the side.
    If you're installing LEDs to brighten your turn signals, you will probably need resistors to replace the resistance in the incandescent filament.
    hammeron likes this.
  3. Jul 19, 2019 at 9:24 AM
    Openbaffle
    The 168 was the bulb that was recommended by someone else on the forum. I guess they aren't side markers, really, they just are amber lights that turn on with the DRL and with the automatic look. I'd just look the look to be consistent. I am using the Diode Dynamics really, which obviates the need for resistors. I'll let you know if I can do a half turn...
    JohnLakeman likes this.
  4. Jul 19, 2019 at 10:02 AM
    Casper421
    In the woods
    06 DC
    You don’t have to remove the housing. There’s a plastic extension “tube” that holds the bulb and locks into the back of the housing. Look around and you’ll find it, it’s easier on the passenger side. If you’re still having issues, I can snap a pic at lunch.
    Found a pic that should help:
  5. Jul 19, 2019 at 10:52 AM
    JohnLakeman
    Nice pic. :thumbsup:
    @Openbaffle : Trust, but verify...the bulb number. ;)
  6. Jul 19, 2019 at 5:59 PM
    Openbaffle
    Nice! Thanks y'all. Will verify tomorrow when the bulbs come.
  7. Jul 19, 2019 at 7:00 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    since your going led test the bulb before you put the socket back in... they have to have the positive and negative on the right side.
  8. Jul 20, 2019 at 10:50 AM
    Openbaffle
    Got them in today. Thanks for the information. I had to unbolt the coolant reserve tank on the driver side to get at the bulb extension. But easy replacement once I got them out. The bulbs linked above were the correct fit.
    JohnLakeman and Casper421 like this.
