How do you get rid of snow in your drivway.
Discussion in 'Off-Topic Discussion' started by ZPMAN, Dec 21, 2017.
  1. Dec 22, 2017 at 5:20 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
  2. Dec 22, 2017 at 6:23 AM
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    Use to use this then I sold it. That was dumb. Now I’m back to the walk behind ariens 30”
    ZPMAN[OP], Casper3 and Prostar 190 like this.
  3. Dec 22, 2017 at 7:27 AM
    ZPMAN
    ZPMAN [OP] 2nd place is the 1st looser
    Minnesota
    Have you tried ice studs? I put 20 - 30 ea in the front tires.
    Look at this on eBay http://www.ebay.com/itm/290808361259
  4. Dec 22, 2017 at 7:43 AM
    Slayer
    Slayer Member
    Slayer
    Ha... years ago
    I had this POS 2 wheel drive work van.. I pulled down this long drive to work on a home I was building .. it snowed all day
    when it came time to go home for the day, I could not crest the hill of that drive.
    being the creative scrounge that I am... I looked around the job & found a box of sheet-metal screws the furnace installer had laying by the furnace..
    I zipped them into my rear wheels with my screw gun... carefully drove home then pulled them out. didn't loose one of them:thumbsup:
  5. Dec 22, 2017 at 8:05 AM
    ZPMAN
    Minnesota
    Wore my helper out.
    Slayer, JC303, slide187 and 1 other person like this.
  6. Dec 22, 2017 at 9:07 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    8 hp Poulan Pro snowblower. My neighbor is a douche and since we're moving in two weeks, I've been taking every opportunity to tip the chute straight up and send all of my snow over his fence and into his yard :D
    Slayer and Prostar 190 like this.
  7. Dec 22, 2017 at 9:09 AM
    :rofl::rofl:
  8. Dec 22, 2017 at 9:27 AM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    Would a quad with plow be enough for a 750ft driveway that has a hill? Or would I need a bigger gun?
    Prostar 190 likes this.
  9. Dec 22, 2017 at 9:28 AM
    15whtrd
    15whtrd Mr. Blonde
    I’d like to see the same video but with paddle tires! Looks really fun either way.
    ZPMAN[QUOTED][OP] likes this.
  10. Dec 22, 2017 at 10:09 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    It would probably work but there are better tools. IMO a truck plow isn't worth the money unless you're using it to plow for money. My next bigger purchase is a cabbed tractor and front mount blower, more expensive but should last the rest of my life.
  11. Dec 22, 2017 at 11:17 AM
    I plowed mine with a compact utility tractor put a 550 lb box Scraper on the back for extra traction.
    I have a hydraulic snow blade and front end loader I use the blade most of the time.
  12. Dec 22, 2017 at 11:49 AM
    ZPMAN
    Minnesota
    Depends on how much snow you get and how wide the driveway is. I sprinkle a few studs in the front and put another notch in the plow so it has a bettor angle. I also got rid of the cable and use nylon now, pain in the ass fixing cable. Put a spring pack in to avoid over lifting the plow after to many beers.
  13. Dec 22, 2017 at 12:08 PM
    slide187
    slide187 New Member
    Boston, MA
    2015 Silver Sky Metallic DC Limited Tundra
    Console Cavern Organizer Mod, Driver's Forward Assist Handle Tonno Pro Hardfold, Body Colored Door Handles, Body Colored Mirror Caps, MBRP Stainless XP Series Dual Exhaust, OEM Bed Extender
  14. Dec 22, 2017 at 12:17 PM
    slide187
    slide187 New Member
    Boston, MA
    Also depends on if you can plow downhill and leave the snow at that end, and back uphill with no snowload. My 800 Outlander handled a ton of snow, way more than i thought it'd be able to before i started using it for that, but when you get a good windrow in front of the blade, the uphills get tuffer, and that quad weighed about 8-hundo.
  15. Dec 22, 2017 at 12:36 PM
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    Since we can get a bunch of snow from an "Albequeque Low" in Monument, Colorado I have a very nice Husqavarna. (I don't mind shoveling but my two herniated disks don't appreciate it much!)
  16. Dec 22, 2017 at 1:19 PM
    Sunnier
    Sunny
    San Diego, CA
    Wait for the sun to melt it 30 seconds later. :notsure:
    slide187 and Prostar 190 like this.
  17. Dec 22, 2017 at 1:24 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    yes
  18. Dec 22, 2017 at 1:26 PM
    Diverguy
    Diverguy Breathes under water
    Leon
    PA, USA
    2018 Tundra Limited TRD Offroad-Inferno
    Windows tinted, window visors. Bedrug, led bedlights, Nfab nerf step bars, Lund toneau cover, Evo One remote start, BAMufflers 8"
  19. Dec 22, 2017 at 1:57 PM
    #49
    Pudge
    CT
    2015 Blue Ribbon Platinum
    If it's an inch or 2 I'll use my backpack leaf blower or shovel. Deep snow I use my Ariens 28 deluxe SHO. Heated grips are nice and the super high output will blow snow from my sidewalk, across the street and into the neighbors lawn. Excuse the messy basement.
    ZPMAN[OP] and gosolo like this.
