How do I snap this trim back?
Discussion in '2.5 Gen Tundras (2014-2021)' started by JohnWhicker, Feb 14, 2024.
  1. Feb 14, 2024 at 12:51 PM
    JohnWhicker
    JohnWhicker [OP] New Member
    As I am mounting my gun around this area I've noticed the center console trim is a bit off. The only work was done around here was when my Katzkin seats were done few weeks back and that's about it. No idea how this happened? I tried pushing it back but won't budge? Maybe a clip is broken or it needs to be reset? I am not good at trims and stuff :) My 5000 miles appointment is coming soon so I let the dealer deal with it?
  2. Feb 14, 2024 at 12:55 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    It's just not seated properly. Remove it completely and then push it down evenly.
    Tripleconpanna likes this.
  3. Feb 14, 2024 at 1:25 PM
    coTony
    Tony
    Montrose, CO
    I would remove the shifter piece and check the screw right there where the 2 pieces of console connect. Something does not look right pushing that one section out
  4. Feb 15, 2024 at 7:59 AM
    JsjTundra2
    JsjTundra2 Long Time Toyota
    Maine
    Interesting.... My 2021 has the exact same gap in the trim. I've been meaning to pull all the trim off and figure it out, but going to wait for warmer weather.
  5. Feb 15, 2024 at 8:13 AM
    JohnWhicker
    I will take it in soon for maintenance when I get 5000 miles and I will ask them to rectify. Will keep you updated. I think the clip missed to go in the right spot.
    JsjTundra2[QUOTED] likes this.
  6. Feb 15, 2024 at 5:30 PM
    White 2.5
    White 2.5 New Member
    Mt P, SC
    2020 White DC
    Should snap back in place, that piece comes off easily. If you had heated/vented inserts installed with the Katzkin’s the installer probably had a simple goof putting it back on.
  7. Feb 15, 2024 at 8:34 PM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Same on my 2020. I tried to fix it for 5 minutes one day and gave up. I think I’d need to break it down some to refit it.
  8. Feb 15, 2024 at 9:37 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  9. Feb 16, 2024 at 3:06 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    My 21 was like that from new. There were reports of this issue prior to me buying it so I used that to my advantage. I showed the dealer and they offered to replace the console, but said the new one will probably be the same, so they gave me one of the add on warranties for free.
    I am known for being OCD about my vehicles and even though I know this is there, it does not does not squeak or draw attention so it does not bother me too much.
    bulldog93 likes this.
  10. Feb 16, 2024 at 5:22 AM
    JohnWhicker
    Now that's interesting. I wonder why that is? I am very OCD and I can't sleep :) But will be nice if I can get this fixed :)
  11. Feb 16, 2024 at 2:23 PM
    coTony
    Tony
    Montrose, CO
    Yes, this is the screw I was talking about, if it is not in right it will pop out like you OP showed in the first post
  12. Feb 18, 2024 at 5:27 PM
    JohnWhicker
  13. Feb 18, 2024 at 5:28 PM
    JohnWhicker
    So that will be a bad install of the screw? I need to open it up and take a look at to I guess?
    coTony[QUOTED] likes this.
  14. Feb 19, 2024 at 3:37 AM
    Bergy24
    Bergy24 New Member
    Curious to know if this works. Please let us know.
  15. Feb 19, 2024 at 8:10 AM
    JohnWhicker
  16. Feb 19, 2024 at 4:23 PM
    coTony
    Tony
    Montrose, CO
    That picture shows how it should be installed. I was identifying which screw I was referring to in an earlier post, sorry for the confusion
