How do I Open tailgate
Discussion in '2.5 Gen Tundras (2014-2021)' started by OldGuy2014, Apr 19, 2023.
  1. Apr 19, 2023 at 11:04 AM
    OldGuy2014
    OldGuy2014 [OP] New Member
    I have a 2014 Tundra and the tailgate will not open. I have used the key to unlock the tailgate but it is stuck and the handle just moves up and down. How can I get the tailgate open?
  2. Apr 19, 2023 at 11:10 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    There are about 8 torx screws along the top half of the inside of the tailgate; remove those and it will expose the internal mechanisms.... just grab the long silver bar w/your hands and move it to the side and the tailgate will pop open. The video below will show you how to open it and also replace the latch; it's an easy fix that's not too pricey!!!
    https://youtu.be/h44b9Vyj8wM
    NewImprovedRon, TRDFerguson and TG705 like this.
  3. Apr 19, 2023 at 11:10 AM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    Try taking the backside of the tailgate off on the opposite side of the latch which will expose the latching mechanism and see if you can see if anything’s broken or not hooked up right when you pull the latch, or try and manually open it once the rear cover is off
    Tripleconpanna likes this.
  4. Apr 19, 2023 at 11:12 AM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    Beat me to it lol
  5. Apr 19, 2023 at 11:14 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Nope.. fool me once...
  6. Apr 19, 2023 at 11:17 AM
    Tripleconpanna
    I'm constantly doing that shit :facepalm:
    but for me, it's usually been answered 2 or 3 times along several posts in the thread, several hours earlier... I just didn't scroll down at all before responding; all good though :thumbsup:
  7. Apr 19, 2023 at 12:20 PM
    OldGuy2014
    Thanks for the suggestion I will give it a try.
  8. Apr 19, 2023 at 1:28 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Odds are the handle is broken, just like mine a few years back. Had to remove the inside panel and pull both rods inward towards the handle. Probably gotta koala it, depending on your height, I'm stumpy so I prepared for the drop.
    NewImprovedRon likes this.
  9. Jun 2, 2023 at 8:53 AM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    I'm having a similar but different problem. My latch lever works...when I pull the handle, both rods pull. It's just that my driver side latch is in the stuck closed position (tail gate is down and can't close).
    Is there a way to release that lock mech? I've pulled off the interior panel and all the mechanics seem to be working. I've attacked with a screwdriver trying to force it open, and I've also PB'd the gears on both locking mechanisms on each side of tailgate.
    Ideas? Ty
  10. Jun 2, 2023 at 10:19 AM
    justfortun
    James
    Boston
    2016 SR5
    Figured it out. The left locking mechanism was in limbo, not all the way up or down. Pushed it down (locked position) then opening it. Works.
