How do I get constant 12 volt power from trailer wiring?
Discussion in '2.5 Gen Tundras (2014-2021)' started by RobinElectronics, May 14, 2018.
  1. May 14, 2018 at 6:36 AM
    RobinElectronics
    RobinElectronics [OP] New Member
    Hey everyone,
    I am noticing that on the 2018 Tundra, there is no constant 12 volt power in the 7 pin trailer wiring. I am talking about the factory installed wiring package. Can anyone guide me on how to get an idea on how to get constant 12 volt power from the 7 pin trailer wiring when the truck is off?
    Thanks,
    David
  2. May 14, 2018 at 9:43 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I have a 2014 that has 12 volts on pin 7 when the ignition is on. Did you try it with the ignition on?
    The reason I ask is because I don't think it's wired the other way.
  3. May 14, 2018 at 10:31 AM
    Wintyfresh
    Wintyfresh New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    I think you'd need to run a new (fused) wire from the battery.
    NewImprovedRon likes this.
  4. May 14, 2018 at 4:11 PM
    TTund16
    TTund16 New Member
    I think pin #4?? is auxiliary 12v ... but the ignition must be on from what I have read here. I haven't tested it myself.
  5. Oct 25, 2020 at 12:55 PM
    Don308
    Don308 New Member
    Don
    Stock 2017 Tundra 4x4 access cab
    None
    I too have been wanting this. A friend of mine has a Dodge 3/4 ton and his is wired hot all the time yet others are not. I’m told the reason is for safety. If you leave your rv trailer attached it can and will drain your truck battery and can leave you stranded. It would be nice if you could add a jumper in the fuse block to make it hot all the time.
  6. Oct 25, 2020 at 1:35 PM
    biebs96
    PA
    Following.
    Id like to know as well.
  7. Oct 25, 2020 at 1:54 PM
    jrquist
    jrquist Canon Shooter
    Carlton, Minnesota
    2020 Tundra Sport Super Bright White
    Here is what is on every pin. You would need to run a separate wire to have a constant hot.
  8. Oct 25, 2020 at 5:47 PM
    TTund16
    TTund16 New Member
    Wonder how many amps you can draw from pin 4.
  9. Oct 26, 2020 at 11:08 AM
    Levinger79
    Levinger79 New Member
    Knoxville TN
    2016 White Tundra Platinum
    There is no constant hot on that 7 pin plug. I had to run a new fused wire back from the battery to power my bed lights.
    Shredking likes this.
  10. Oct 26, 2020 at 11:23 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    ^^^ This^^^^
  11. Oct 26, 2020 at 4:58 PM
    Redpill
    Redpill New Member
    2015 Tundra DC Limited 4x4
    Leveling kit, airbags on rear axle, led light bar with cattle pusher.
    Mine has constant 12v, it charges my dump trailer battery as I run down the road. I believe it comes from pin #4.
  12. Oct 26, 2020 at 5:02 PM
    I believe that it only has power when the engine is running not while off.
  13. Oct 26, 2020 at 5:21 PM
    Redpill
    Redpill New Member
    Yes sir, I should have said it has constant 12v while key is in the on position.
  14. Oct 26, 2020 at 5:24 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Are you not worried about running your battery dead? :notsure:
  15. Apr 13, 2022 at 2:35 PM
    Conflicted
    Conflicted New Member
    Buffalo-ish, New York
    2019 Crewmax SR5 TRD Off Road
    I keep it really clean!
    I am looking to install bed lights also. What size fuse did you use for your line?
    TTund16 likes this.
  16. Apr 13, 2022 at 2:49 PM
    TTund16
    TTund16 New Member
    You guys know how many amps can pin #4 supply? and pin #7 if you know.
  17. Apr 13, 2022 at 8:35 PM
    :notsure:
