How big is yours? Measure up!
Discussion in '1st Gen Tundras (2000-2006)' started by Darkness, May 15, 2019.
  1. Feb 25, 2022 at 12:40 PM
    #121
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    How are you liking those tires?
  2. Apr 18, 2022 at 8:02 PM
    #122
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    2004 DC 4WD
    Toytec Aluma 2.0s, Camburg UCA, Bilstein 5160, 285/70/17
    Sitting mostly level
    LF: 22.5”
    RF: 22.5”
    LR: 22”
    RR: 22”
  3. Jun 6, 2022 at 6:02 AM
    #123
    Paladin
    Paladin New Member
    Andy
    Arizona
    06 Tundra DC & 13 4Runner Trail
    Dealer installed revtech spacers here
  4. Aug 3, 2022 at 8:18 PM
    #124
    shill2002
    shill2002 New Member
    Beige 2002 Toyota Tundra
    Toytec alumna series 2.0 shocks Freedom off-road upper control arms Custom retrofits Custom grille 10” rf sub and amp
    Currently sitting at 27” front and 26.5” rear on 315/17/r17’s. Custom spring pack in the rear with rcd front lift.
    BluegrapeVr6 and bmf4069 like this.
  5. Sep 5, 2022 at 3:20 PM
    #125
    bulltrout
    bulltrout New Member
    06 Tundra 4wd AC V8 TRD
    2811CB80-DCD0-4DAF-AA27-C809D926151C.jpg 955219C0-4343-439A-9BF0-202DD8906ACD.jpg
    Stock size tires. 5100 Bilstein shocks on 4 corners, set at lowest adjustment with Old Man Emu 2884 coil springs up front. Diff drop kit, no after market UCAs. Just over 100 miles on this suspension setup so coil springs could settle some.
    Before: Driver front 20 3/4" Psgr front 20 7/8" Driver rear 22 1/4" Psgr rear 21 3/4"
    After: Driver front 22 3/8" Psgr front 22 3/4" Driver rear 22 1/4" Psgr rear 22 1/4"
  6. Sep 26, 2022 at 12:50 PM
    #126
    bulltrout
    With new tires, 275/70r17, Nokian Outpost ATBDDFBCC6-4A07-47BC-8F46-2C1458C7915B.jpg
    MD0811 and bmf4069 like this.
  7. Dec 6, 2022 at 5:41 PM
    #127
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Lowered the front a hair.
    LF 20 1/8"
    RF 20"
    Rear: both 21 1/4"
    3/4 tank.
    BluegrapeVr6 likes this.
  8. Apr 6, 2023 at 8:55 PM
    #128
    805Tundra
    Ben
    Central Coast
    Update: running Archive Garage MD leaf springs
    Front: 22.5”
    Rear: 24”
  9. Apr 7, 2023 at 4:11 AM
    #129
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    So you got 2" of lift in the rear with the new leaf packs? Truck looks great!
  10. Apr 7, 2023 at 10:24 AM
    #130
    805Tundra
    Ben
    Central Coast
    Thanks! Yep, 2" lift above stock height with about 250-300lbs in the rear. My stock springs were starting to sit at 21-21.5" hub to fender so the lift felt bigger than 2"
  11. Apr 8, 2023 at 5:09 PM
    #131
    Tundratimetb
    Tundratimetb New Member
    "06 Tundra AC TRD w/ RCD
  12. Jul 15, 2023 at 3:20 PM
    #132
    MD0811
    MD0811 New Member
    2006 Tundra DC V8/4WD
    Bilstein 6112f/5160r w/700lb springs, wheelers AAL w/3° shim JBA UCA, Solo LCA Nokian Outpost AT 275/85R16 Brute Force Front Bumper w/Smittybilt 9500
    2006 DoubleCab
    Front 22in
    Bilstein 6112 on highest recommended (I believe 8 driver, 6 passenger) with 3/8 spacer each side, 700lb springs, solo LCA, JBA UCA, BFF bumper with xrc 9.5 (not installed yet added 80lb dumbell when I measured)
    Rear 23in
    Bilstein 5160s with stock leafs (worn but not enough to replace just yet, wheelers AAL, overload left in, 3° axle shim, snugtop canopy.
    Tires 285/75R16 on stock wheels with 1.25in spacer front and 1in rear.
    No rubbing, stock mudflaps, barely trimmed liners (to fit BFF bumper) no rubbing with stock bumper either, even when offroad.
    Edited for pictures.
    digitalferg, 805Tundra and bmf4069 like this.
  13. Sep 4, 2023 at 2:22 PM
    #133
    Throwing out some numbers (had to edit - reversed my P/D rear measurements)
    Before suspension mods (gas ~1/4 tank):
    Front D: 20.5"
    Front P: 20.75
    Rear D: 21.75
    Rear P: 21.5
    After SPC UCA, Toytec Aluma Boss 2.0 coilovers, Suspension Maxx extended links, 5100s in rear:
    Fresh off the jacks (gas ~3/4 tank)
    Front D: 23.25"
    Front P: 23.5
    Rear D: 21.625
    Rear P: 21.5
    After shakedown (gas ~3/4 tank)
    Front D: 22.5"
    Front P: 22.75
    Rear D: 21.625
    Rear P: 21.5
    As it sits now, pre-alignment, 7-8 miles into shakedown, no touching coilovers, old tires and wheels installed.
    Weagle, bmf4069, 16CMTXED and 2 others like this.
  14. Sep 4, 2023 at 2:24 PM
    #134
    So the front is an inch lower after the lift?
  15. Sep 4, 2023 at 2:45 PM
    #135
    Not unless I reversed some numbers. You talking about 1s, 2nd, or 3rd set?
    Things settled out about 1/2-3/4" between getting it off the jacks (2nd set of numbers) and driving around all over the bumpy ass streets of ATL (3rd set of numbers).
  16. Sep 4, 2023 at 2:49 PM
    #136
    I must have read that wrong. Swore it said 23.5 for your starting front drivers. Makes more sense looking at it again. Apparently….
  17. Sep 4, 2023 at 3:00 PM
    #137
    I had a typo but I fixed it about 10 seconds after posting and seeing I copy/pasted some numbers wrong. I think you saw it pre-edit, Quick Draw McGraw!
  18. Sep 4, 2023 at 5:44 PM
    #138
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Did you get a level and attempt to adjust the SPCs camber? What did you set the caster to?
    https://youtu.be/v1RXnk7b2Bs?si=gJ65NbGG2M37j59b
  19. Sep 4, 2023 at 6:00 PM
    #139
    I haven't touched anything other than using the slot on the UCA to get the camber to a more-neutral position. It could be I lack understanding, but given I'm not touching the stock TRE/LBJ/cams in any way, and the UBJ having a fixed fwd/bwd position, I can't really do anything except adjust camber. My whole goal was to get it driveable so I can run it up to a shop I know that's well versed in custom alignments with the install I chose, same shop is installing tires, balancing, reprogramming TPMS and I'll have them once-over everything for an extra hour of labor because I don't have experienced eyes where I am otherwise to sorta doublecheck my work, since this is ultimately my DD. It's the only thing that sucks about living in the city. Nobody around me seems to be mechanically-familiar, and the ones that are primarily geek out on rat rods, hot rods, or ricemobiles.
  20. Sep 4, 2023 at 6:50 PM
    #140
    DJenerated
    Dija
    The Lone Star State
    You can do caster by way of the ubj too. I assume it's set to neutral all around then. That's a good starting point. When you get bigger tires you may want to adjust the caster forward to help em fit. That's what I love most about SPCs
  21. Sep 4, 2023 at 7:09 PM
    #141
    Oh sorry, I forgot you can clock the UBJ.
    I followed SPC's instructions, clocked the UBJ to "D". But instead of sliding the UBJ to center, if you were to mark the UCA slot with a "1" at the farthest-from-spring point, and a "4" at the closest-to-spring point of the slot, then equally spaced numbers 2 and 3 in between, I landed on roughly a 2 on the passenger side, and a solid 2.75 on the driver's side to get me in a ballpark alignment with the new setup.
    I'll let the guys at the shop with their fancy machines manage the fine-tuning.
    I saw Josh over at 1st Gen Offroad called out setting to "A" in his video, and sliding the UBJ all the way to what I would call the "1" position (as close to tire as possible), but I didn't want to go there.
  22. Sep 4, 2023 at 7:39 PM
    #142
    DJenerated
    Dija
    The Lone Star State
    I just followed the video I posted and used a level to get in dead center and set my caster all but one notch forward to clear my 295's.
    The alignment guys told me I almost nailed it. They didn't need to do much adjusting. Felt good.
    shifty`[QUOTED] likes this.
  23. Sep 24, 2023 at 5:44 PM
    #143
    Update: Got rid of the Icon AAL + overload setup. It was squeaking like hell where the AAL clamp's rivet was digging into the overload.
    Installed ATS heavy duty springs (p/n: 90-221HD), which set me back a whopping $500 shipped, and I landed me in @805Tundra's ballpark.
    Driver front: 23
    Pass front: 22-¾
    Driver rear: 24-¼
    Passenger rear: 24
    MD0811, dirtnsmores, Weagle and 5 others like this.
  24. Sep 24, 2023 at 5:46 PM
    #144
    Oh, and I think if I'd have been on level ground and taken my pic more on-center, you'd see the rake. I'm sitting at ~1" rake when measured on level ground.
    My current ground-to-fender measurements after the new tires and new leaf packs:
    Driver front: 38.5"
    Driver rear: 39.75"
    Pass front: 38.5"
    Pass rear: 39.5"​
    bmf4069 and KNABORES like this.
  25. Sep 24, 2023 at 6:32 PM
    #145
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Does it ride any better with new leaf packs? I've never seen gaps like that between springs. It sure does look good though.
  26. Sep 24, 2023 at 7:05 PM
    #146
    It's weird, it's less harsh than the OEM + AAL w/overload, but it also feels like it springs back faster after bumps/dips. Closest thing we have to washboards where I am are the sections of road where busses stop to sit with hot tires, which creates series of divots in the asphalt, and it seemed to do really well with those on the half dozen spots I hit with them. It responded really well on the bricked roads I hit and with potholes. I'll loop back with you after I've had more time with it.
  27. Sep 24, 2023 at 7:07 PM
    #147
    Measure up and send pics then.
    bmf4069 likes this.
  28. Sep 29, 2023 at 5:02 PM
    #148
    MR9160
    MR9160 New Member
    2021 TRD OFF-ROAD
    5100’s up front to level, 285/70/17 Nitto Terra Grapplers with SpiderTraxx 1.25 front spacer
  29. Sep 29, 2023 at 5:03 PM
    #149
    You forgot to post your measurements ;)
  30. Sep 30, 2023 at 8:02 AM
    #150
    MR9160
    MR9160 New Member
    2021 TRD OFF-ROAD
    Can you please explain what you mean by measurements? Distance between tire and fender?
