How big is my gas tank?!
Discussion in 'General Tundra Discussion' started by rfk757, May 27, 2018.
  1. Jun 11, 2019 at 4:10 PM
    kcaustin66
    kcaustin66 New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
  2. Aug 6, 2019 at 12:44 PM
    izzieford
    izzieford New Member
    Izzie
    2019 Tundra
    If you have the SR5 Upgrade which takes away your bench seat and gives you the center shifter and console, then have the bigger 38 gallon tank. If you have the bench seat with your shifter behind the steering wheel, then your tank is the smaller one.
  3. Aug 7, 2019 at 8:17 AM
    Rbear
    Rbear New Member
    Rob
    2013 4.6 4x4 Tundra
    4-inch Fab tech lift Fuel Revolver wheels Toyo 35 ATs Bush Wacker fender flares AFE super stock filter kit Aluminess front bumper
    They only make two tanks
    26 gallons the one I have but not for long because it sucks to only be able to go 286 miles for me to be at total empty.
    38 gallon tank which you should have.
    Your fuel tank computer doesn’t calculate the reserve you have left.
    If you really just have to know carry a 5 gallon Jerry can and run your truck completely out of fuel. That will give you an actual drive to empty test. Just don’t run out on a busy road or highway, which can be very dangerous
  4. Oct 6, 2019 at 4:40 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Toyota Canada lists the CrewMax for us Metric users as:
    Fuel Capacity litres (gal.)
    144 (38)
    I filled ours today from almost empty, less than 10km left and put it 120 litres (32 gal) That means the reserve is approx 25 litres (6 gal).
    Seems to fall in line with the other observation for you gallon guys.
  5. Feb 3, 2022 at 2:05 PM
    Uph_muddyboots
    Uph_muddyboots New Member
    Will
    2016 Black Toyota tundra
    Ah, the hell with all that I'm just gonna install an L tank and fuel hose in the bed and call it good. Not necessarily a 100 gal but at least a 50. Had one in my f250 years ago, made road trips alot less hassle at 11 mpg my tundra is gett about 300 per fill up so the extra 400 lbs isn't going to make much difference to me in the long run.
  6. Jun 2, 2022 at 6:46 AM
    bonir01
    bonir01 New Member
    Ruben
    2020 Tundra TRDSport
    The most I've been able to fill up to is 27, but i really have never let it get close to or below the E line, i did get the upgraded tank according to the dealership.upload_2022-6-2_9-46-31.jpg
