Hotshot Offroad 4th of July Sales // Morimoto, Diode Dynamics, RCI, and more!
Discussion in 'Deals & Group Buys' started by memario1214, Jun 26, 2025.
  1. Jul 1, 2025 at 6:20 PM
    Huh. Where all the FGT deals?
  2. Jul 1, 2025 at 7:36 PM
    Qbert
    Qbert New Member
    Copy, I will let the kids know college is out now.
  3. Jul 1, 2025 at 7:50 PM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    On the Eichbachs Stage 2, does a normal spring compressor work on the springs, or are they larger like on Fox to where you need to use a wall mount?
    Thinking about picking a set up with this deal but don’t want as much lift as 2.75” and want to be able to dial it down some.
  4. Jul 2, 2025 at 7:52 AM
    memario1214
    memario1214 [OP] Hotshot Offroad Staff Member Vendor
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    No problem! My personal favorites over here are still the Diode Dynamics SS3 max in fog pattern. They just have a ton of power, and keep the light down well!
    https://hotshotoffroad.com/products/type-b-ss3-led-fog-light-kit-tundra
    As for ditch lights, it kind of comes down to pricing and use case. Depending on whether you want them to be distance support, or if you plan to aim them to the sides will dictate what I recommend! Here's the ditch brackets, and links to some pods. Let me know which power level you're hunting, and what you hope they'll light up, and we'll go from there!
    https://hotshotoffroad.com/products/low-profile-ditch-light-mounting-brackets-2014-2021-tundra
    *Remember you'll need 2 of the below pods and a wiring harness -
    SS3 Max - https://hotshotoffroad.com/collecti...lights/products/stage-series-ss3-led-pods-max
    SS3 Pro - https://hotshotoffroad.com/collecti...ights/products/stage-series-ss3-led-light-pro
    SS3 Sport - https://hotshotoffroad.com/collecti...hts/products/stage-series-ss3-led-light-sport
    JUSS GONNA SEND IT
    We got em! We are just slow in getting products uploaded! You just tell me what you want, and I'll let you know what we can do. :cool:
    A standard spring compressor will work just fine. Also, I generally tell people that if you lubricate the threads and ring well with WD-40 (or similar) you can bring a coilover down without galling the thread or rounding out the holes that the spanner wrench goes into. I don't share this same stance for trying to go up. I always recommend compressing the spring to go up.
    TRDFerguson[QUOTED] and RobertD like this.
  5. Jul 2, 2025 at 8:34 AM
    Need new suspension. Running Billie 5100s now. Could repeat that or swap for Eibachs.
  6. Jul 2, 2025 at 9:37 AM
    yakeng
    Thanks, I was surprised to see Eibach's video last night and they were adjusting it up without compressing the spring. When I had Fox coilovers, they told me I needed to compress them which I struggled with as I learned quick that the standard spring compressor didn't fit the springs.
    What preload are they sent out with, something around the 2.75" lift or is it lower?
  7. Jul 2, 2025 at 9:48 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    This style of compressor fits over the heavy duty springs our trucks use much better. https://www.amazon.com/dp/B0075CQLV8/
    Fox uses the split collars, right? Those definitely need preload removed before adjusting or you'll skip threads. Solid collars like Icon uses can be spun with tension on them, but like Colton said, there are some caveats there.
    yakeng[QUOTED] likes this.
  8. Jul 2, 2025 at 9:52 AM
    memario1214
    Colton
    Missoula, MT
    They come shipped at ~+2” out of the box. I generally recommend the Eibach kit out of the box, and then about .75” of lift out back to make things look congruent. Generally it’s accomplished by a Coachbuilder +1 shackle.
  9. Jul 2, 2025 at 9:59 AM
    yakeng
    I heard the Coachbuilder +1 doesn't work with my RAS HD, do you know if that is the case? If it doesn't, I'll probably just get the Stage 2, dial it down a bit and try to maintain a bit of rake. I'm not looking for much lift, just around 1.5" or so.
  10. Jul 2, 2025 at 10:34 AM
    memario1214
    Colton
    Missoula, MT
    Can confirm that to be the case. If you have a RAS HD now, you're already getting about .75" of lift, so you're in a good spot anyway! No need for the shackles from a visuals perspective.
    yakeng[QUOTED] and RobertD like this.
  11. Jul 3, 2025 at 8:53 AM
    AND
    AND New Member
    Washington, PNW
    The chart you made is way better but, without looking at the chart, I bet people will assume the DBRTOY2 is made to run with a 2" lift.
  12. Jul 3, 2025 at 12:07 PM
    memario1214
    Colton
    Missoula, MT
    Got it! I'll go back to the drawing board and toss in some more details to clear that up. It is a little "muddy" right there.
    RobertD and AND[QUOTED] like this.
  13. Jul 3, 2025 at 12:09 PM
    memario1214
    Colton
    Missoula, MT
    DIRT KING - 10% Off today through Monday (7/7)!
    Ball Joint UCAs - HERE
    2.5 Front Coilovers - HERE
    2.5 Rear Shocks - HERE
    Performance LCAs - HERE
    Everything DK - HERE
    TRDFerguson and RobertD like this.
  14. Jul 3, 2025 at 12:18 PM
    PM sent on ball joint question
  15. Jul 6, 2025 at 2:35 PM
    yakeng
    Got my order yesterday, thanks @memario1214 , gotta find a free weekend to get this installed now
    memario1214[OP] likes this.
  16. Jul 6, 2025 at 2:36 PM
    SC SR5
    SC SR5 New Member
    2014 SR5 CM, 2025 Lifted Platinum
    RC coilovers/level shocks , 2014 Factory lift on the 2025 Platinum
    Any bilstien on sale?
  17. Jul 6, 2025 at 3:05 PM
    memario1214
    Colton
    Missoula, MT
    Heck yeah! Happy things are showing already!
    They were, and just unfortunately came off of a sale. Whatcha after?
    RobertD likes this.
  18. Jul 6, 2025 at 7:08 PM
    Qbert
    Qbert New Member
  19. Jul 6, 2025 at 8:33 PM
    #49
    memario1214
    Colton
    Missoula, MT
    Sure did! I was away over the weekend though. I just fired back over a reply!
    RobertD likes this.
  20. Jul 7, 2025 at 5:25 AM
    #50
    SC SR5
    SC SR5 New Member
    5160 rears, coachbuilder shackles
  21. Jul 7, 2025 at 7:42 AM
    #51
    memario1214
    Colton
    Missoula, MT
    I'll fire you over a PM :thumbsup:
    RobertD likes this.
  22. Jul 7, 2025 at 7:43 AM
    #52
    memario1214
    Colton
    Missoula, MT
    FINAL DAY FOR EIBACH AND DIRT KING
    Diode and Form end tomorrow!
    RobertD likes this.
  23. Jul 8, 2025 at 11:30 AM
    #53
    memario1214
    Colton
    Missoula, MT
    Diode Dynamics and Form Lighting sales end tonight!
    RobertD likes this.
  24. Jul 8, 2025 at 8:05 PM
    #54
    Qbert
    Qbert New Member
    Shout out to @memario1214, I worked with him to place an order last night and he called me today to confirm it. I called him back while he. Was driving home and he answered the phone and confirmed everything over the phone. ABOVE and BEYOND customer service!
  25. Jul 8, 2025 at 8:12 PM
    #55
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I know it is about to be over, but while scrolling FB, this popped up..... Had to scroll back to confirm it was indeed HotShot....haha
  26. Jul 8, 2025 at 9:31 PM
    #56
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Real life recording of Colton on the hotlines
    memario1214[OP] and RobertD like this.
  27. Jul 9, 2025 at 8:29 AM
    #57
    memario1214
    Colton
    Missoula, MT
    We make sure to take a peek at every order to see if anything comes across as funky. Thanks for the support! :fistbump:
    We've definitely never felt the yield from Facebook/Insta "ads", but we try them every once in a while just to see if we get lucky someday! :rofl:
    Accurate
    RobertD and TRDFerguson[QUOTED] like this.
  28. Jul 9, 2025 at 8:31 AM
    #58
    memario1214
    Colton
    Missoula, MT
    Morimoto, Icon, Fox, RCI, and CaliRaised are still going strong for a couple more days! Time is running out.
    RobertD and TRDFerguson like this.
  29. Jul 9, 2025 at 8:32 AM
    #59
    Ghost Rider
    Ian
    Cypress, Texas
    I guess it worked? I don't do Insta as much for coupon code for pet food....But FB looks like it works... though, kinda late...
  30. Jul 9, 2025 at 8:42 AM
    #60
    memario1214
    Colton
    Missoula, MT
    It technically only "works" if you buy something! :anonymous: It's nice to know that it got a touch of reach though! :bananadance:
    RobertD likes this.
