Horrible MPG on my 24
Discussion in '3rd Gen Tundras (2022+)' started by MontanaEric, Nov 6, 2024.
  1. Nov 16, 2024 at 8:41 PM
    #61
    Frank_TRD23
    Frank_TRD23 New Member
    Farmers Branch , Texas
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    If I am doing the correct math at 350 miles at full tank, I'm at maybe 13.5. I've even made a 600 mile round trip with eco turned on and still didn't change. If I had a bigger tank I wouldn't be a whine but about the MPG.
  2. Nov 17, 2024 at 4:04 AM
    #62
    msubullyfan
    msubullyfan New Member
    Robert
    2024 Tundra i-FORCE MAX 1794 Edition
    Maybe I’m not understanding your response, but the difference between stock tire circumference and your 37” tires is over 15%. So, if your ODO says you traveled 350 miles on a tank of fuel, you actually traveled 403. The truck is correctly recording your fuel consumption but incorrectly calculating the miles traveled, so it’s giving an incorrectly low fuel economy reading.
  3. Nov 17, 2024 at 4:15 AM
    #63
    Frank_TRD23
    So, even the till empty is not a correct reading? How could I get an actual till empty reading?
  4. Nov 17, 2024 at 7:33 AM
    #64
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    The DTE and Range are given calculated for you based on your typical usage. These are all part of the GOM system (Guess O Meter) and that term doesn't exist by the way.
    It won't take into account the changes to tire size or road conditions or head winds.
    Just a good "guess" to give you an idea of how far you could travel!
    PermaFrostTRD likes this.
  5. Nov 18, 2024 at 3:12 AM
    #65
    msubullyfan
    Robert
    ‘you can’t, but since your odometer, speed, and DTE are all off by the same percentage, they will count down to E at the same rate.
  6. Nov 18, 2024 at 6:51 AM
    #66
    Breathing Borla
    AZ
    Im confused, you're complaining about the MPG rolling on 37s?
    like the other fella stated, your tires are almost 5" bigger diameter than stock, your ODO and everything else is way off now
  7. Nov 18, 2024 at 6:58 AM
    #67
    Tom976
    Tom976 New Member
    Tom
    Stop and go traffic is NOT a trucks friend. (well at least mine)
    Highway mileage is MUCH nicer.
  8. Nov 18, 2024 at 7:28 AM
    #68
    Frank_TRD23
    Heck yeah, I was just shocked that it's that low of MPGs.
  9. Nov 18, 2024 at 7:44 AM
    #69
    Breathing Borla
    AZ
    O man, are you new to trucks?
    not trying to be a jerk at all, so please don't take it that way. I'll try to help you understand, your actually getting pretty good MPG for what you have
    1) you can't just use the dash DTE or ODO to hand calc your MPG like you can stock, your tires are almost 5" bigger in diameter than stock, so when it says you drove a mile, you actually went further so it looks like your getting less.
    2) you added a SHITLOAD of rotating mass at each corner and I bet those 37"s weight what 90 lbs? Stock is 38 lbs. This KILLS MPG big time , 3-5+ MPG depending on driving conditions and driving style. Not sure what you did for wheels, that could be even more depending what you got if not stock.
    3) you also, raised your truck and that impacts aerodynamics which also reduces MPG
    There are online calculators to help and see what your actually getting due to the changes to the tire size, its better than what you are seeing, but that is not going to to help with all that size,weight, etc,
    you have to pay to play if you want to roll 37"s, and if thats what you want, just forget about MPGs, wanting that plus 37" isnt going to happen no matter what you drive.
    ScottieBones, kirkb and Tunrod like this.
  10. Nov 18, 2024 at 12:55 PM
    #70
    Frank_TRD23
    no worries my but stays hurt. 20" on 37s. I'm just probably use to having company trucks and not looking at fuel usage or working close to home. Now it's a pickup >personal/work.
    JPAutotech likes this.
  11. Nov 23, 2024 at 1:43 PM
    #71
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    I have about 1900 miles on my 24 Limited CM TRD Off-Road. According to the mpg gauge I get about 16 to 17 mpg with short drives to work. Temperatures were about 40ish Fahrenheit. Last Thursday it dropped into the 30’s and the wind was blowing like crazy. I didn’t warm up the truck, started it and drove. I noticed the RPM was a lot higher and the fake engine noise was louder lol. I also noticed when the engine warmed up the fake engine noise was still roaring and the turbo meter was showing high on psi. Apparently this truck isn’t very aerodynamic and doesn’t like driving in the wind. I got about 11 mpg. Later that day and the following next days the temp was higher and no wind. Mpg went back up to 16
  12. Nov 23, 2024 at 1:50 PM
    #72
    Breathing Borla
    AZ
    Winter blend also boys, it’s awful for mpg
    22whatwedo, Raven67 and PermaFrostTRD like this.
  13. Nov 23, 2024 at 4:36 PM
    #73
    CrayCray
    CrayCray New Member
    WA State
    2024 Platinum 6.5
    What’s the formula? I put 285/65 R20s on a few weeks ago and am getting high 12 MPGs.
  14. Nov 23, 2024 at 4:40 PM
    #74
    CrayCray
    CrayCray New Member
    WA State
    2024 Platinum 6.5
    What is winter blend, anyway? Why would the gas quality go down based on the season?
  15. Nov 23, 2024 at 4:41 PM
    #75
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    Forget the tires. Fill tank. Note mileage on a GPS unit. Drive at least half a tankful. Fill up, and calculate consumption from the GPS recorded mileage.
  16. Nov 23, 2024 at 4:53 PM
    #76
    Midnight Rider
    Midnight Rider None of the above.
    Dave
    Wright City MO
    2023 Platinum Crewmax 4x4
    Cup grips & a 2 decals.
  17. Nov 23, 2024 at 4:53 PM
    #77
    Midnight Rider
    Dave
    Wright City MO
    CrayCray[QUOTED] likes this.
  18. Nov 23, 2024 at 6:10 PM
    #78
    Bigbadpoppa
    Bigbadpoppa New Member
    TRD PRO hybrid 2024
    13 MPG on 285/65/18 (city only)
    11 MPG on 295/70/18 (city only)
    I don't have a lead foot at all, and the girl is still thirsty. Conservative driver.
  19. Nov 24, 2024 at 1:52 PM
    #79
    msubullyfan
    Robert
    The only "formula" is just the ratio of the circumference of the tires. The factory size was 265/60R20, which is 102.1". The 285/65R20 is 108.6". It's a 6.5% difference, so the number of miles driven on the measured fuel is actually 6.5% too low. So, since fuel economy is miles/gallon, just multiply the result by 1.065, so if you were getting 12.8, it's really 13.6.
    I'm surprised you're that low. I have 295/65R20, and corrected for size I'm getting 17.1 with my 35" tires.
    Raven67 and CrayCray[QUOTED] like this.
  20. Nov 24, 2024 at 1:54 PM
    #80
    Breathing Borla
    AZ
    width and weight count too
  21. Nov 24, 2024 at 2:48 PM
    #81
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    I get between 12 mpg and 22 depending on my drive. Basically anything that gets the turbos going tanks the mileage.
  22. Nov 24, 2024 at 3:54 PM
    #82
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    I think he was just talking about mpg correction. That would only be diameter. Width would count a little for wind resistance, and weight only for stop and go, or rather just go...
  23. Nov 24, 2024 at 4:27 PM
    #83
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    Yep, that would be the other big red light I would like to see on my dashboard, besides friction brake actuation. Hitting the brakes to actuate charging is not too bad - actually as the Prius hypermilers say though, to maximize your mpg "stay out of the battery". Charging and discharging the battery is only about 50% efficient.
    Tundrastruck91 likes this.
  24. Nov 24, 2024 at 7:39 PM
    #84
    msubullyfan
    Robert
    Not for the purposes of correcting the dash mileage reading. It’s literally miles traveled divided by gallons of gas consumed. The gallons measurement is correct; the miles traveled is based on the computer counting wheel revolutions and converting it to miles traveled based on the factory tire size. When you upsize the tires, one revolution of a tire covers more distance than the computer gives credit for. And the ratio it’s off is the ratio between the new tire diameter (or circumference — they’re rationed the same) and the old tire diameter.
    Raven67 and steveh like this.
  25. Nov 24, 2024 at 8:07 PM
    #85
    CrayCray
    CrayCray New Member
    WA State
    2024 Platinum 6.5
    I live up a mountain, and there are a lot of hills around my house as well. You would think the downhills would even out the up hills. But it doesn’t seem to work out that way. I’m getting 12 to 13 indicated mpgs with these tires.
    Toyota1234 likes this.
  26. Nov 24, 2024 at 8:18 PM
    #86
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    It’s the same way with running, bicycling, or pushing your dirtbike after it runs out of gas.
    steveh likes this.
  27. Nov 25, 2024 at 5:21 AM
    #87
    Breathing Borla
    AZ
    ya correct, I was talking about actual mpg , sorry for the confusion
  28. Nov 25, 2024 at 6:56 AM
    #88
    DIYReid
    DIYReid New Member
    KC
    2024 Ice Cap Tundra Limited
    There are far too many factors to calculate what's going on with your MPG.
  29. Apr 9, 2025 at 2:19 PM
    #89
    Njlynch
    Njlynch New Member
    Nathan
    2024 Tundra Limited
    Stock 24 Tundra limited here. I'm only seeing 14 mpg 15 if I keep it under 70mph. deff not what I was expecting . my old 2015 Ford F150 3.5 echo was getting 20mpg.
  30. Apr 9, 2025 at 4:50 PM
    #90
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    I'm pretty much at 19 at 70, level no wind. 24 Limited Hybrid.
