Horn honks continuously
Discussion in '1st Gen Tundras (2000-2006)' started by Aapodaca, Mar 4, 2020.
  1. Mar 4, 2020 at 4:30 PM
    Aapodaca
    Aapodaca [OP] New Member
    Anthony
    2006 Tundra double cab SR5
    Thank you in advance for your time and advice. My 2006 tundra horn won’t stop honking. I was driving and was stopping at a red light normally; I didn’t slam on my brakes; and my horn just started to go off. I removed the relay from the fuse box under the hood just to get it to stop. I waited a day and slightly banged on my steering wheel thinking it was stuck and I then tried to reinstall the Relay but as soon and it makes contact with the relay socket it still continues to honk. If anyone can help with anything into it will be greatly appreciated.
  2. Mar 4, 2020 at 5:38 PM
    speedtre
    speedtre New Member
    Inland Northwest
    This happened to me in a1998 Montero...it was the mechanism in the horn pad that stops the horn contacts from touching and setting the horn off disintegrating and not doing it's job.
  3. Mar 4, 2020 at 5:40 PM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Your DC might be similar to my 2004 DC and while I wouldn't 100% expect the Horn relay to stuck in energized state or welded contacts, you could eliminate that as a problem. There are 2 other identical relays to my Horn relay. Perhaps you could check the same on your 06 and temporarily check if it's the relay. Do you have access to a VOM ?
    Darkness likes this.
  4. Mar 4, 2020 at 5:42 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Hit it harder you’ve got to hit it (him) harder!!! (What About Bob)!!!! Sorry it just came to mind!! I wore my Winnipesaukee shirt today!!:)
    035VZFE, gosolo and Bob_Wiley like this.
  5. Mar 4, 2020 at 5:51 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Jump higher, maybe with your knee more!
    035VZFE and Black@Blue19[QUOTED] like this.
  6. Mar 4, 2020 at 5:58 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    Like BubbaW suggests. Switch the horn relay with one of the identical ones. I'd be willing to bet that the horn relay is stuck.
  7. Mar 4, 2020 at 6:25 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    In the meantime unplug your horns in the front and wire a test light instead to troubleshoot.
    Your neighbors well appreciate it.
  8. Mar 4, 2020 at 10:00 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  9. Aug 22, 2020 at 2:52 PM
    blkhawk661
    blkhawk661 New Member
    M
    2006 SR5 Double Cab Tundra, ~195k
    Any update to this thread? I have same year tundra and same problem. Only difference is my door locks aren't working right. Need to use key to enter vehicle, then can use buttons to unlock and lock. Its an aftermarket security/autostart which has been installed for over 10 years, and i had it in an '06 access cab tundra for 3 years prior... I mistakenly went to thread artsr2002 referenced, only to hand my mechanic a fuse assembly for the second gen tundras.
  10. Aug 23, 2020 at 5:41 PM
    shifty` A means to an end, but the ends don't seem to meet
    You know, I read elsewhere on here where someone had a leak in the cowl or driver's side firewall area and it was dripping right into one of the bulkheads and causing all kinds of crazy problems due to corrosion. Could it be something like that?
    May be worthwhile trying the relay swap mentioned above to rule out a bad/faulty relay.
    Or maybe your truck thinks you're really horny? :p
    bmf4069 likes this.
  11. Aug 24, 2020 at 7:41 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If the relay doesn't solve it, it could be the clockspring (I think Toyota calls them spiral cables) in the steering wheel has shorted and tripping the horn.
  12. Aug 28, 2020 at 7:17 PM
    skeeter1949
    skeeter1949 New Member
    Cecil
    2014 TSS 4WD
    TRD Exhaust, K&N Filter
    I would bet on the clock spring.
  13. Aug 29, 2020 at 12:16 PM
    blkhawk661
    M
    Thanks all for your help. Had to share a big development.
    Mechanic and his electrical guy have covid19 like symptoms and have been unable to work on it. So i picked up my driveable but not honk-able truck, since i still need to get around. First ride after getting it home had image below.
    After instinctually yelling "red alert, shields up!" i had the presence of mind to stop in my driveway and take a video.
    GIF is pretty blurry, but reading left to right, the blinking LEDs are ABS (orange), cruise (green), and tire monitoring (orange)
    Vehicle was actually in drive, cruise was not on, tires were not visibly low.
    Starting to think this is similar to the second gen tundra issue where the guy had the fuse assembly go. Locks are also still being temperamental and not working with aftermarket clicker.
    Would a clock spring or relay explain all this?
  14. Aug 29, 2020 at 1:10 PM
    Professional Hand Model
    Hand Protectors
    Not sure about your dash set up which is different than mine in the 2002 AC. Are your volts low? Can’t read the numbers.
  15. Aug 29, 2020 at 1:11 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I know this bumper sticker won't fix your problem but it may be a temporary solution.
    Glock 40, 2manytoys, Tundra2 and 5 others like this.
  16. Aug 29, 2020 at 1:15 PM
    Hand Protectors
    You are #1 in my book.
    Tundra2, bmf4069 and FrenchToasty like this.
  17. Aug 29, 2020 at 1:58 PM
    blkhawk661
    M
    Volts are right near middle (little less than 14V) as meter is from 9 to 19. Battery was replaced about 1.5-2 years ago. I don't think that is the culprit since it starts just fine.
    EDIT: mistakenly thought middle was 12 and dial range was from 9 to 15.
  18. Sep 2, 2020 at 1:25 PM
    @blkhawk661 I am suspicious you may have something that leaked into your firewall bulkhead or some corrossion. I'm having deja-vu as I type this, I swear I mentioned it before but ... yeah, that looks a little whack.
    Looks about where mine was when I posted the odd video of my fluctuations here.
    That was from this thread over here where talks of voltagables has randomly occurred.
  19. Sep 9, 2020 at 1:04 PM
    blkhawk661
    M
    Update: bought a clock spring ($34) and a relay ($13) online.. mechanic charged me $200 to replace both (fair price?) and now horn, autostart, doors, and alarm all work. ABS and tire sensor are no longer flashing, but cruise light is flashing. Cruise functions fine even if light is flashing regardless of what it is set to. Mechanic said it might take a while for it to reset, and let him know if it continues. Whatever... i'll update if it doesn't go away
    I wanted to share this since I could not find any similar incident on any of the four tundra forums i visited and i won't be the last person to have this issue. I had asked the front clerk to get the mechanic to see if only the relay or only the clock spring would do the trick. That was either lost in translation, or both parts were required as i would have preferred to return a part if possible.
  20. Sep 9, 2020 at 1:25 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Wow only $34 for a clock spring? Seems cheap but I've never priced one for a Tundra.
  21. Sep 9, 2020 at 1:52 PM
    blkhawk661
    M
    parts geek
  22. Sep 9, 2020 at 1:53 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Probably not OEM, right?
  23. Sep 9, 2020 at 2:04 PM
    blkhawk661
    M
    not OEM. Brand name was "replacement" which i've seen on several sites. If they can't figure out how to make a commonly replaced part after 15-20 years of the truck hitting the streets.... well, they wont be in business long. Not that i think my '06 tundra will last me another 14 years and 200k miles anyway.
  24. Sep 9, 2020 at 2:19 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    There are few, if any, parts I'd buy aftermarket these days. Most are made in china and don't last or don't fit right or break during installation. If I was going to get rid of something quick, I might consider it.
  25. Sep 10, 2020 at 11:26 AM
    bmf4069
    bmf4069 Something something Miller Lite
    Beau
    TX
    02 AC sr5 4wd v8
    I agree. That's an EXTREMELY low price. And if properly maintained, that truck will last way longer than the next 14 years/200k miles.
  26. Dec 13, 2020 at 8:53 PM
    Hevy767
    Hevy767 New Member
    2011 Tundra
    Good evening,
    I have a 2011 tundra, the horns quit! Then a couple of days later the horns starting blowing for no apparent reason. I had to disconnect the horns.
    I had checked the horn fuse when they quit, I have also checked (where the horn relay should be in the fuse box, under the hood.) There is no horn relay. Could it be located somewhere else? Any help would be appreciated with this problem.
    Thanks,
  27. Dec 14, 2020 at 12:28 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Many moons ago I had a 67 chevy pickup that had same problem. Leak was right above fuse block. It was a nightmare. One day it died on me, and I ended up installing inline fuses on every circuit just so I could get home.
  28. Dec 14, 2020 at 6:13 AM
    2000 Limited TRD AC 4X4 Thunder Grey 272k miles. 2019 Limited TRD CM 4x4 - SOLD
    This thread is in regards to a first gen Tundy issue. Original OP fixed it with a new clock spring in the steering column. Your truck is 2nd gen and may have an entirely different issue. Try reposting in the 2nd and 3rd gen forum to get more relevant info. I expect a shooing when you've been discovered here....
  29. Dec 14, 2020 at 6:18 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    shoo, shoo!
