Hooking up break controller
Discussion in 'Towing & Hauling' started by Lns_tundra, May 14, 2017.
  1. May 14, 2017 at 8:59 AM
    Lns_tundra
    Lns_tundra [OP] New Member
    I have a pilot break controller I took out of my old Dodge Ram and want to put it in my tundra. I have the pigtail that came with my truck but there's more wires on the pigtail then on the BC
    Can anyone help me with identify which wires go where . Or where I can get a adapter to plug directly into my truck
    Break controller wires
    Pigtail wires
  2. May 14, 2017 at 9:02 AM
    You will most likely have to purchase a wiring harness adapter. They are cheap.
  3. May 14, 2017 at 9:05 AM
    Also, the plug in is by the foot brake. White plug.
    Lns_tundra[OP] likes this.
  4. May 14, 2017 at 9:35 AM
    Lns_tundra
    I
    looked on Amazon and eBay and couldn't find one
  5. May 14, 2017 at 10:19 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    Try eTrailer.com. Doesn't look like the sell the Reese brake controller but they sell adapters.
  6. May 14, 2017 at 11:17 AM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    If that white plug have exposed wires at the other end you need to find the wire schematic for the bc and the truck..that does not seen like it is the right plug
  7. May 14, 2017 at 2:21 PM
    Frkypunk
    Frkypunk "If a man is to be a street sweeper"
    2010 Tundra limited...2015 highlander limited
    One of the wires doesn't get used. I spliced mine to the pigtail that they give you in the glove compartment....works fine. I had to google which wire goes to which. I will see if I can find the one I used.
  8. May 14, 2017 at 2:35 PM
    Frkypunk
  9. May 14, 2017 at 7:40 PM
    Lns_tundra
    ColoradoTJ likes this.
