Hood Flex/rattle
Discussion in '1st Gen Tundras (2000-2006)' started by Animus313, Apr 24, 2018.
  1. Apr 24, 2018 at 9:24 PM
    Animus313
    Animus313 [OP] New Member
    Newer Tundra owner here. 06 Double cab limited. My hood starts flexing/rattling when getting up to 45-freeway speeds. I've adjusted the rubber stops on the sides to contact correctly with the hood closed. Almost looks like it happens due to the thinness of the metal used on the hood. Just curios if anyone has experienced this or what the did to fix it. Slightly annoying on the freeway.
  2. Apr 25, 2018 at 5:45 PM
    az chip
    az chip New Member
    Craig
    Arizona
    2003 Tundra TRD
    I have that on mine. The upper latch is loose which I think is causing my issue. Might want to check the snug on the upper latch.
    15whtrd likes this.
