Hondos Garage 2.0 Mount with AJT Vent Rings
Discussion in '2.5 Gen Tundras (2014-2021)' started by CorpsTundra, Jan 5, 2023.
  1. Jan 5, 2023 at 2:27 PM
    CorpsTundra
    CorpsTundra [OP] New Member
    Michigan
    2021 Tundra CrewMax SR5-TRD OR - Cement
    Has anyone trimmed their AJT design vent rings to work with the Hondos Garage 2.0 phone mount?
    I searched and found folks saying that the mount will not work unless the ring is trimmed, but nothing about actually making it work.
    I also need a single black AJT vent ring or a cheap set, so if anyone has one please let me know.
  2. Jan 6, 2023 at 11:00 AM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    Can confirm it will NOT work without trimming, etc. I was going to try and source a longer bolt instead of trimming but it's a wierd one and I just returned it.
    CorpsTundra[OP] likes this.
  3. Jan 6, 2023 at 11:49 AM
    CorpsTundra
    Michigan
    Needing longer machine screws was my initial thought, but I can’t recall what the inside of the vent looked like prior to the trim ring being installed and was unsure whether the inside lip of the ring prevented the mount from securing. I’ll see if I can find the screws and report back for others.
    Thank you.
  4. Jan 6, 2023 at 11:54 AM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    My fault - I just realized I picked up the OffRoam one. Same design I believe but they switched to 1 single bolt for the vent tension.
    If you had longer screws it should theoretically work. The lip on the inside that the mount bites onto is very small however. That's why I gave up. Everyone touted how solid the mount was and I just wasn't impressed for the price.
  5. Jan 6, 2023 at 12:28 PM
    CorpsTundra
    Michigan
    I have the Hondos Garage mount on my Tundra and previously on my Tacoma. Never had them loosen, but didn’t have any major impacts either. For the price though, I agree with you.
  6. Jan 6, 2023 at 4:22 PM
    CorpsTundra
    Michigan
    Interesting, multiple others say that the Offroam does not work with AJT trim rings.
    Since the Offroam installs the same as the Hondo, I am wondering if the Offroam screws are longer?
    The Hondo Garage screws for the clamping mechanism are 4-40 x 1/2”. If the Offroam cap screws are longer than 1/2”, that could explain your success.
    HulkSmurf14 likes this.
  7. Jan 6, 2023 at 6:08 PM
    Coloradonative75
    Coloradonative75 New Member
    Dave
    Aurora Colorado
    2020 4x4 limited
    Are-z series topper, bedrug,
    I have the Offroam and AJT trim rings. Thet will NOT work together, I had to trim the AJT ring where the mount fits. Screw is not long enough to work with the rings
  8. Jan 7, 2023 at 3:07 PM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Can you Please post a picture when you get chance?
    CorpsTundra[OP] and Rc23 like this.
  9. Jan 9, 2023 at 10:19 AM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    ^This
    I just wasn't sure whether I REALLY wanted the mount and didn't commit to trimming mine.
  10. Jan 10, 2023 at 7:52 AM
    Coloradonative75
    Dave
    Aurora Colorado
    2020 4x4 limited
    Picture of AJT ring trimmed and mount .
    CorpsTundra[OP], Rc23 and Bergy24 like this.
  11. Jan 10, 2023 at 10:55 AM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    That looks good. I just KNEW if I did it I'd end up changing my mind.
