Homemade sliding drawer, need suggestion on lock
Discussion in 'Recovery & Gear' started by chrisf111, Aug 2, 2022.
  1. Aug 2, 2022 at 12:33 PM
    chrisf111
    chrisf111 [OP] New Member
    I got this half bed width slide out second hand. Refurbed it a little and bolted straight to the truck bed. Has been working great to hold a fully loaded yeti (200ish lbs). Pictures below.
    I need suggestions on a good locking mechanism to prevent it from sliding during travel. The way it was built allows it to drop down on itself when pushed all the way in, so the metal on metal contact holds a lot of the movement but I need something more.
    The barrel latch pictured is already starting to deform. I added it last week and it already has a lot of play in it from being jostled around.
    Any suggestions on a latch for this application.
    NewImprovedRon likes this.
  2. Aug 2, 2022 at 1:17 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    What about a heavy duty clasp type latch like is used on the tailgate tire swing outs?
  3. Aug 6, 2022 at 8:19 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    ...Or a couple rubber straps like your yeti probably has?
  4. Aug 6, 2022 at 9:11 PM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
  5. Aug 6, 2022 at 9:54 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    Figure out a way to attach a linch pin for both sides and youll be good to go.
  6. Aug 9, 2022 at 4:30 PM
    Uncledan
    Uncledan New Member
    Spring pins with a roller on each side would work as well. I like the cabinet latch idea.
  7. Aug 9, 2022 at 4:32 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  8. Aug 9, 2022 at 7:41 PM
    COTundie
    Trey
    Pretty things
  9. Aug 10, 2022 at 6:30 AM
    chrisf111
    Something like this? Might work, but I haven't been able to find one in the right dimensions yet.
    I actually had this thought too but figuring out the mounting system for either end would be a pain, also I think they're a little big for the spot.
    I am going to check these out further, looks like best case scenario if it can handle heavy duty applications. There will be several hundred pounds of force working on it during acceleration and especially when climbing hills.
    I was starting to go down this route, something similar to how cargoslide systems work, then I could even have multiple locking points if I needed to extend on a slope without it retracting.
    Pretty sure this would fall apart day on at that the rivet.
    Thanks for all the help guys. For now the barrel latch has still be holding, but if/when it fails I have some good ideas to work with.
  10. Aug 10, 2022 at 8:33 AM
    MadMaxCanon
  11. Nov 4, 2022 at 6:59 AM
    Agboohans
    Agboohans New Member
    Black 2003 Tundra AC SR5 4.7L V8 2WD w/topper shell
    RideRite Air Bags, upgraded sound system
    Are you still rockin the barrel latches? If not, what’d you end up going with?
  12. Nov 4, 2022 at 6:59 AM
    chrisf111
    The barrel latch has held up so far so I haven't changed it out.
