Homemade Hidden winch on my '10 CM
Discussion in '2nd Gen Tundras (2007-2013)' started by geohil, Jan 24, 2021.
  1. Jan 24, 2021 at 4:53 PM
    geohil
    geohil [OP] New Member
    2010 Supercharged Crewmax
    Didn't want to pay the price for a hidden winch setup for a 2nd gen and really there are not many products available, so with a generic winch plate I made my own. That and a little bit of plate steel.
    Before I began
    Materials
    Bash bar is going to be a pain but looks like enough room.
    Mock up with the tray
    24" x6' piece of 3/16 plate steel.
    Well I'm committed now.
    I didn't get a pic but I tied the bash bar back into the winch plate using grade 8 bolts.
    Plate steel bolted to factory 20k tow hooks. Painted it up too.
    All bolted together and winch bolted on. I didn't get a pic of the control box for the winch but there was plenty of room just above the passenger side bash bar mount.
    All back together - my license plate now uses rare earth magnets to hold it on and covers the winch nicely. I did have to cut off 6" of the plastic valance but I think it turned out really good.
    License plate removed. You can see the winch line attached to the drivers side tow hook. I'll probably do a little more trimming around the fairlead but it does not interfere with the winch at all.
    I did add a 300amp breaker inline to the battery just to nix any parasitic drain. Total of the creation was right at $400 including the 13k winch.
    Piki, Black@Blue19, Blang805 and 25 others like this.
  2. Jan 24, 2021 at 5:17 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Nice work!!! :thumbsup:
    Also... noticed you have Patagonia MT’s?
    Almost bought a set. Good, Bad?
  3. Jan 24, 2021 at 5:46 PM
    geohil
    Love the tires. Super quiet on the road and amazing at 18psi off-road. No complaints at all.
    MTRock[QUOTED] likes this.
  4. Jan 24, 2021 at 6:58 PM
    Mixb7
    Mixb7 New Member
    Napa Valley California
    2010 4x4 Tundra Platinum Crew Cab
    Bilsteins all around,110v and 12v in the bed, Rocklights, Dual Batteries, Trailer Brake Controller Mod, Lots of DIY Mods
    This is great to see this. I have a 2010 CM also and I feel the winch bumpers are too much and I like to do the DIY. Are you able to reach the free spool lever without opening the hood? I knew this could be done with one of those winch plates but just didn’t know where to start. Thanks buddy for showing this. I have to finish my dual battery system then I want to try this.
    gosolo likes this.
  5. Jan 24, 2021 at 7:05 PM
    geohil
    Unfortunately you do have to have the hood up to get to the free spool lever. The winch I bought has a fast line speed so I’m planning on just running the winch line out under power.
  6. Jan 24, 2021 at 8:25 PM
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    Awesome job. Looks pretty simple to do compare to my diy. That i welded up.
  7. Jan 24, 2021 at 8:28 PM
    geohil
    Yeah the one I did for my 4Runner I had to weld a bunch. I’ll have to check yours out. I want to replace the rest of the plastic valence with plate and tie it into my skids still.
    MTRock likes this.
  8. Jan 25, 2021 at 9:16 AM
    Civiceg94
    NYC
    I dont have a good picture of it. What i did was made a base plate. So it could be bolted to the chassis and welded a two angles on each end and then welded the winch plate to it. Might sound confusing. Lol
  9. Jan 27, 2021 at 11:42 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Really nice. Certainly gives me a template for my ‘07
  10. Jan 27, 2021 at 3:59 PM
    BigSkyTaco
    BigSkyTaco Successfully Social Distancing since 1998
    Aaron
    W. Glacier, MT
    2011 White DC Tundra TRD
    Great looking install. Like the stealth look...
  11. Nov 20, 2023 at 8:05 AM
    j5offroad
    j5offroad New Member
    Wisconsin
    2010 Tundra SR5 5.7L DC
    Love the look and simplicity of this install. I was wondering how this has held up over the last few years as I would love to do something similar.
    IIonPilgrimg likes this.
  12. Nov 30, 2023 at 5:32 PM
    IIonPilgrimg
    IIonPilgrimg New Member
    2008 Tundra Limited Double Cab 4x4 5.7 6-speed Red Rock
    Also liked!
    I did a Badland 12k very similar on my 1996 Suburban using the tow hook frame bolt holes. Winch plate is in front of the bumper on that.
    The 1/4" flat-plating bounces a bit and wouldn't be strong enough to lift the truck: It wants for triangulation to the core support, which wouldn't be difficult to fab.
  13. Dec 1, 2023 at 3:52 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    pretty cool. how is it bolted to the hooks?
  14. Dec 4, 2023 at 7:23 PM
    IIonPilgrimg
    On the Suburban, the plates are bolted between the hooks and frame. Just use a 1/2" longer bolt. The Tundra, I've yet to go there. But, it looks like he's done exactly the same.
  15. Dec 4, 2023 at 7:27 PM
    OP hasn’t been on for closed to three years
  16. Dec 4, 2023 at 7:33 PM
    IIonPilgrimg
    Right. This is a TTT, 'cause I like the idea.
  17. Dec 11, 2023 at 6:01 AM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Very nice work... Love the ingenuity here. I want to try this with my '10. Nice job man!!
  18. Dec 12, 2023 at 8:35 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    cool story bro
    T-Rex266[QUOTED] likes this.
  19. Dec 12, 2023 at 8:56 PM
    So how is he going to respond?:boink:
    Cpl_Punishment likes this.
  20. Dec 13, 2023 at 4:34 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    How the hell am I supposed to know? Are we supposed to stop asking questions in threads?
  21. Dec 13, 2023 at 6:52 PM
    By clicking on their name. I think you need a Snickers.
    Bob, Cpl_Punishment and AZTundra like this.
  22. Dec 13, 2023 at 10:13 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    ok so every time i reply to a thread i should check the last time the person i am replying to logged on? ok guy
  23. Dec 14, 2023 at 5:53 AM
    If you’re wondering if you’ll get a response, sure? Is your Tampax on tap side up or are you in general butthurt?
  24. Dec 14, 2023 at 9:42 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    ok, bud. keep up the good work.
