Homelink on '17 Tundra issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by tinyt1553, Dec 14, 2017.
  1. Dec 14, 2017 at 7:44 AM
    tinyt1553
    tinyt1553 [OP] New Member
    Tom
    Cypress, TX
    2017 1794 CM - Magnetic Gray
    Exterior: POP & Lock Power Tailgate lock BakFlip MX4 Tonneau Cover Rhino Bed Liner Swapped OEM Halogen Fogs with Formula-J87 LED 6000k bulbs Rough Country 60" Tailgate LED lightbar 6" rubber stub antenna Interior: Front Emblem Camera with anytime backup cam, Crux Vimty-05 for Vehicle in Motion Override Center console wireless charging Verizon Hotspot in center console Chromecast to OEM head-unit display ESP Rear Seat 3 Compartment Storage 5% Ceramic tint on rear window and rear doors 18% Ceramic tint on front doors Weathertech rear seat cover (try to take Hank (boxer/pointer mix) with me everywhere I can) In The Works: Upgrade to 2018 OEM LED Headlights VLEDs throughout the rear (turns, brakes, highmount 3rd brake and cargo) GRT Lighting LED's to replace all interior bulbs Future Wishlist: Swap OEM Head-unit with Kenwood DNX994S and use iDataLink Maestro RR to integrate OEM backup cam, OEM USBs, OEM Aux input, etc AMP-Research Power Sidesteps Train (air) horn
    Forgive me if this has been posted already, I did search the site and couldn't find anything related to homelink other than programming issues, which mine isn't.
    Is Anyone every have issues with their home link garage door openers suddenly not working unless you are basically right under the door opener?
    I have a chamberlain garage door opener, for the last 6 months, no issues with the homelink buttons on my rear-view when opening and closing the door. The past week or so, it frequently will not open, unless I use one of the Chamberlain remotes, or the universal remote in our Wrangler. When I back into the garage, and the door opener is right above me, it works great, but if I'm outside trying to open the door from the Tundra, forget it.....
    I have cleared the codes and completely reprogrammed the Homelink, having the same issues with it with my Craftsman opener for my other garage door as well, which leads me to believe it's a homelink issue and not an opener issue.
    Any advice would help.
  2. Dec 14, 2017 at 8:46 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    It sounds like the Homelink to me since it has the same issues with two different openers. Are the garage door openers fairly new? I had compatibility issues with newer Homelink units and older garage door openers. I had two 16 year old Sears Craftsman openers that would not work with my 2014 Silverado unless I was directly in front of the door. Well, one opener failed and after it was replaced with a new Liftmaster, I could hit the button from a block away and it opened without an issue. Replaced the other opener and all is fine.
  3. Dec 15, 2017 at 5:04 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    in 2014 I believe the software changed with Homelink. The older openers needed a part in the garage for them to work with newer vehicles. I had the reverse issue with an 2012 tacoma and a new Chamberlin opener, and had to upgrade my mirror to work the new door.
  4. Dec 15, 2017 at 7:54 AM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    I have to firmly press my buttons directing pressure to the top part of the button.
  5. Dec 15, 2017 at 3:15 PM
    tinyt1553
    Tom
    Cypress, TX
    It worked fine with both openers until about 2 weeks ago, now it. Only works from inside the garage
  6. Dec 15, 2017 at 7:31 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    That's why I think it is the Homelink module itself
  7. Dec 15, 2017 at 8:30 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    No issues here, I simply tap the button and it has a pretty decent range, well before I get to the driveway. My wife’s Lexus, on the other hand, is ridiculous. You have to push it just right and hold it for at least a second or two
  8. Dec 15, 2017 at 9:13 PM
    JTX Tundra
    JTX Tundra New Member
    About 4 weeks ago my homelink started acting up with the Chamberlain garage door. However the remotes that came with it work perfectly.
    I reprogrammed everything and no difference. I keep the Chamberlain remote in the console now. No clue what happened.
  9. Dec 15, 2017 at 9:16 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    It does sound like a homelink issue, warranty, hopefully? Did you try the dealer?
  10. Jan 1, 2018 at 8:37 AM
    tinyt1553
    Tom
    Cypress, TX
    So I gave one more go of reprogramming it. This time I did the normal point the remote at the homelink, but then also did the smart learn button on each opener (followed instructions in the manual for rolling codes), haven't had an issue since. Guess ya gotta RTFM (read the f*..... Manual)
    ChucklesToy likes this.
