Home theatre subwoofer issues- help!
Discussion in 'Off-Topic Discussion' started by newguy, Dec 26, 2019.
  1. Dec 26, 2019 at 1:00 PM
    newguy
    newguy [OP] New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    Looking for help from the community of smart people (this forum).
    I’ve been having issues with my in-home stereo system subwoofer.
    About 4 months ago, my two-year old Definitive sub (higherish-end consumer brand) began to have a constant low rumble. It’s doesn't start until a signal/sound is sent from the stereo and when I unplug or turn off, there’s a pop almost like a static discharge.
    Its connected to my stereo via an RCA cable.
    It seems like more of an electrical issue rather than a blown speaker since it’s constant even when the volume from the amp is turned all the way down. But again, it doesn’t start until there is signal going to the speaker. Once it starts, it won’t go away until I unplug or turn the subs power off.
    I’m not too interested in getting a new sub as this thing wasn’t cheap and it’s fairly new.
    Thank you in advance for any help!!!
  2. Dec 26, 2019 at 1:08 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    I'm not sure if this is your issue but a couple months ago my sub was making a hum noise even though no bass was coming out of it, so I decided to take it apart and clean all of the dust bunnies out of it. After putting it back together and testing no more humming :notsure:.
    newguy[OP] likes this.
  3. Dec 26, 2019 at 1:18 PM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    Have you tried a using a different out from the receiver?
    I’ve had a sub channel go bad on a receiver before and it started sending a dirty signal that led to an electric hum.
    Since the sub is relatively new, it may be worth diagnosing the signal?
    Kerch71 likes this.
  4. Dec 26, 2019 at 2:15 PM
    newguy
    Thank you. I will give that a try!!
    I think there is only one sub-out signal but I will double check that. Thank you.
    RangerBP[QUOTED] likes this.
  5. Dec 26, 2019 at 2:37 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Might be worth trying a new gold plated RCA cable. Or, try using electrical connector oxidation cleaning spray on the jacks. Sorry, the brand name escapes me but they have it at Best Buy. Sometimes oxidation is enough to affect the ground and cause humming and popping. The fact that it's constant makes me think it's the connectors or the cord itself.
    newguy[OP] and RangerBP like this.
  6. Dec 26, 2019 at 4:52 PM
    newguy
    It’s Best Buy’s/magnolia’s “high end” brand. I’ll give that a try.
  7. Dec 26, 2019 at 5:12 PM
    NR-J
    NR-J New Member
    Justin
    2015 white tundra
    Contact Definitive and tell them exactly what it’s doing. They shipped me a new amp for my super cube 1 after describing a very similar issue. I don’t remember what I paid for the new amp but it wasn’t bad.
  8. Dec 26, 2019 at 5:18 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    It will be the amp board in the sub... the hum is a classic sign of that component failing.
    Go with a Sunfire sub if you can't get it serviced.
  9. Dec 26, 2019 at 5:35 PM
    Tosa
    Tosa New Member
    2014 Platinum Crewmax
    It could be a ground loop problem, which is a difference in ground potential between the receiver and the subwoofer amplifier. The rca cable carries the current and can create a hum. Check for a good ground on the circuit with receiver and the circuit with subwoofer, or better yet plug them into same good grounded outlet and see if it goes away.
  10. Dec 26, 2019 at 5:57 PM
    Tosa
    Tosa New Member
    When the subwoofer is humming you could also try unplugging the rca and see if the humming stops, if it does this could indicate you may ground issue. Or it might just be a sign of a failing amp as well. For a relatively inexpensive replacement...if you go down this route I highly recommend BIC Acoustech Pl-200 II, retails less then $300 and has very impressive bass.
  11. Dec 26, 2019 at 8:44 PM
    newguy
    If I unplug the RCA, the hum doesn’t go away. Makes me think it’s the sub.
    I’ll try calling Definitive in the morning and see if I get anywhere.
    If I don’t get anywhere, I’ll try some of what has been suggested above.
    saybng and RangerBP like this.
  12. Dec 27, 2019 at 7:09 PM
    newguy
    Called Definitive, they said the amp in the sub has gone bad. Unfortunately, I don’t think I purchased it from an authorized retailer so the warranty is void.
    I purchased it on Amazon from “the audio video guy” or something. Definitive is reviewing the “case” and will let me know.
  13. Dec 27, 2019 at 7:34 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    There are a ton of good subs for not s lot of coin. SVS, velodyne and mirage all come to mind. If you want some help let me know. The used market is your friend......happy to give some advice as I have installed dozens of home theaters on a wide range of budgets.
    KMG and newguy[OP] like this.
  14. Dec 27, 2019 at 8:13 PM
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    Definite Technology should be able to take care of you. I use a lot of their speakers throughout my home. Very happy the way they sound. If DT doesn’t fix it, see if they will give you a list of venders who will.
  15. Dec 27, 2019 at 8:39 PM
    RangerBP
    Bummer. Fingers crossed they come through for you.
  16. Dec 27, 2019 at 9:15 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I am interested to see what the outcome is on this. Good luck.
  17. Jan 31, 2020 at 10:27 PM
    newguy
    Other than the fact that I had to reach out to Definitive to follow up, I am very happy with the outcome.
    The seller I bought the speaker from originally was not an “authorized retailer” for Definitive so technically, I was SOL. If he was, they would have sent me a brand now speaker.
    BUT, when I called them today to check in, they apologized profusely for not calling me back with an update.
    And now, because of their mistake in not contacting me, they are sending me a new amp for the speaker, free of charge.
    I love companies who take care of their consumers. Definitive is 5 star in my book.
    Thank you all for your input on other speakers. I was about to make another purchase but good thing I didn’t.
  18. Jan 31, 2020 at 10:30 PM
    newguy
    that’s exactly what it was.
  19. Feb 1, 2020 at 5:29 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    :thumbsup:
    saybng likes this.
  20. Feb 1, 2020 at 5:40 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Sounds like a capacitor going bad. Don't use it anymore and look for dampness around the caps in the power supply, get the size of them and replace them.
