Home Theater System...??
Discussion in 'Off-Topic Discussion' started by TTU19, Sep 27, 2018.
  1. Sep 27, 2018 at 9:46 AM
    Tunka
    Tunka New Member
    So cal
    2018 sr5 crwmax
    2.5 leveling kit 30555r20 ko2 fuel assault wheels
    Bose soundtouch 525 75 in samsung custom made ceiling speaker grills
  2. Sep 27, 2018 at 9:48 AM
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I dont think there is room in the A frame portion of the living room, but there is for that wall above the bar. Do you think in wall speakers that high up would be ok?
  3. Sep 27, 2018 at 9:53 AM
    jordanpop1
    jordanpop1 New Member
    Yes. That should be okay. It’s a little high, but for surrounds you’ll be okay. Generally with surrounds you want the tweeter pointed relatively towards you, but it will be okay. Not ideal, but will definitely work
    TTU19[QUOTED][OP] likes this.
  4. Sep 27, 2018 at 9:55 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Cool, may look at going that route to eliminate the stands next to the couch. How far can speaker wire run before it may loose quality? I'm sure I wouldn't need to worry, but just curious. So if I ran it up the wall, around and to the back side.
  5. Sep 27, 2018 at 10:01 AM
    jordanpop1
    It will be fine. Just make sure to use a thicker gauge wire. 12 is good.
    Also make sure you cut the lengths for the surrounds the same length. For instance, if the left surround is a 40 foot run but the right surround is a 50 foot run. Then cut the left for a 50 foot run.
    Match the surrounds on wire length and match the front 3 on the same wire length.
  6. Sep 27, 2018 at 11:01 AM
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    Isn't that what channel delay is for?
  7. Sep 27, 2018 at 11:04 AM
    crochetjohn
    crochetjohn New Member
    2015 Inferno TRD Pro
    Ya'll making me sad. All my theater equipment is in a storage unit since I sold my house.
  8. Sep 27, 2018 at 11:32 AM
    jordanpop1
    It’s always best to use as little internal processing as possible. It’s also rare that there would be a delay. Same size wires is always best practice. In theory it’s best to have all 5 or 7 or 9 hence and so forth same length, but that’s usually not feasible
    d0zer[QUOTED] likes this.
  9. Sep 27, 2018 at 12:23 PM
    d0zer
    2017 MGM Platinum
    Makes sense! Thanks!
  10. Sep 28, 2018 at 8:53 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    i'll need to get some pics up...i have just shy of a 200" screen in my basement. in wall polk front side and rear stage 2 18's in mini marty and marty cubes. set up for sports/second family room. can seat around 20 comfortably. i did a bunch of the work myself and i am very proud of the results. part of a bigger basement finishing project...workout room, full bath with custom shower, bedroom etc.
  11. Sep 28, 2018 at 8:57 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
  12. Sep 28, 2018 at 8:59 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
  13. Sep 28, 2018 at 9:01 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
