Holy Grail of Tundra gas mileage hit
Discussion in 'General Tundra Discussion' started by pamtnman, Oct 3, 2017.
  1. Jan 21, 2019 at 3:21 PM
    #91
    MisterTundra
    MisterTundra New Member
    MGM CM
    Got you beat! This was a 90 mile drive from Stockton,CA to San Francisco.
    Mine is a 5.7.
    pamtnman[OP], Moon Puppy and jeremyd like this.
  2. Jan 21, 2019 at 3:58 PM
    #92
    pamtnman
    pamtnman [OP] New Member
    God's Country
    '17 Tundra TRD CrewMax
    Working through the list
    Don’t forget to reset your mpg before entering urban driving!
    jeremyd likes this.
  3. Jan 21, 2019 at 4:36 PM
    #93
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    AV1qizwCZwqiPd6eyRWOAzRjJWBaKorDMDSVxeAi_dd58a79bee7ccd66798a8b3b2a4fa4139f1da45c.jpg
    No picture it didn't happen....
    Will reset on the return trip. Fuely should show up when I fill up again.
    pamtnman[QUOTED][OP] likes this.
  4. Jan 21, 2019 at 4:45 PM
    #94
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I got 17.1 mpg when I brought my truck home the day I bought it. I have never gotten that mileage again? I get 13.5 to 15.3 mpg pretty much all the time . I changed the exhaust to duals and deleted two converters and installed a k& n pan filter. My truck has the leveling kit and 305/55/20 nitto ridge grapplers tires so I really can't complain.
    pamtnman[OP] likes this.
  5. Jan 21, 2019 at 4:47 PM
    #95
    Danimal
    Danimal New Member
    2008 tundra limited
    I can consistently produce a 18.5 to 19.5 mpg in my 08 limited 5.7 4 wheel drive.
    that is flat strait seal level Florida at 69 MPH.
    Using Michelin LT tires, street tread at 40 psi. No abnormal wear for 50,000 miles, just replaced with the same.
    Handel's like a sports car, tows like a truck.
    Towing the big boat: 8 MPG sucks
    towing the wave runner, sames as not towing
  6. Jan 22, 2019 at 10:00 AM
    #96
    Field Walker
    Field Walker New Member
    Ben
    New Mexico
    2018 SR5
    The 305 knobby tires will definitely wreck your mileage
  7. Jan 22, 2019 at 10:40 AM
    #97
    tenntundra
    Walter
    Tennessee
    My truck had the 305/55/20 on it when I brought it home? Must have gotten a really good deal and they kept the gas mileage? Lol!
  8. Jan 22, 2019 at 10:54 AM
    #98
    Field Walker
    Ben
    New Mexico
    2018 SR5
    I misunderstood. That is strange indeed.
  9. Jan 22, 2019 at 10:59 AM
    #99
    Danimal
    Danimal New Member
    2008 tundra limited
    Your fuel injection system monitors the fuel burned by the o2 sensors. Removing 2 converters would likely change the exhaust flow and temperature. the higher flow and lower temperature in the exhaust would be read by the computer as a cooler engine and cooler ambient temperature. In order to keep the engine running correctly, the fuel is enriched to compensate for a cooler engine. If within tolerance that the check engine light does not activate, the end result would likely be higher fuel consumption and a longer warm-up period at a much higher fuel ratio than required. You may get a little more power if you are within 14 to 1 mixture however if you are too rich, you are likely to burn out or plug the front cats.
  10. Jan 22, 2019 at 2:39 PM
    #100
    tenntundra
    Walter
    Tennessee
    I have only had them removed for 2 months. I have owned the truck for 1 year. I have actually gotten better gas mileage since I removed the 2 converters and installed an x-pipe and dual dirty Deeds exhaust.
  11. Jan 25, 2019 at 7:56 AM
    #101
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    TRD Exhaust, DC 305/55/20s, TRD PRO Shocks, HID's, JOBOX, Bully Dog Tuner, TRD sway bar, Shorty FM Int,
    Well I believe I'm going to jump into 1st place with this victory. This was our last road trip to SWF in the 08' 5.7 CM now keep in mind I did have the flux-capacitor switched on and running at 96.7% efficiency. Only other mod is the rev-tec tornado throttle body spacer. Numbers don't lie..LOL
    Markman and pamtnman[OP] like this.
  12. Jan 25, 2019 at 8:17 AM
    #102
    Thattundradude
    Thattundradude New Member
    Platinum Tundra
    Lifted
    I got 12 mpg over 150 miles mostly highway
  13. Jan 25, 2019 at 8:19 AM
    #103
    pamtnman
    God's Country
    Is coasting downhill and photographing the dashboard allowed in Tennessee ?
    Yesterday’s crazy warm temperatures here seemed to influence my truck’s gas mileage, putting it back at 17.2 mpg. And when the cold front pushed through and I drove home, mpg was back to 15.4.
    Makes ya wonder what factors really influence mpg
  14. Jan 25, 2019 at 8:20 AM
    #104
    DJFaninTN
    DJFaninTN New Member
    Panama City Beach, FL
    2018 Super White 1794
    69 mph in FL will get your ass run over around here
  15. Jan 25, 2019 at 8:20 AM
    #105
    pamtnman
    God's Country
    That’s super low. Are the tires heavily deflated?
  16. Jan 25, 2019 at 8:47 AM
    #106
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    Totally legal..
    Totally legal!!
  17. Jan 25, 2019 at 9:52 AM
    #107
    Thattundradude
    Platinum Tundra
    Lifted
    No all had 35-38 psi
  18. Jan 25, 2019 at 10:23 AM
    #108
    pamtnman
    God's Country
    Interesting. My experience is raising pressure to 40-41 psi raised mileage from 15 to 18/19 mpg summertime, and from 14 to 15.5-16 mpg wintertime with heavy knobbies
  19. Jan 25, 2019 at 10:31 AM
    #109
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    16.4 has been my best so far.
  20. Jan 25, 2019 at 10:40 AM
    #110
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    I had help from very strong wind, also I stayed between 60-65MPh
  21. Jan 25, 2019 at 1:22 PM
    #111
    Thattundradude
    Platinum Tundra
    Lifted
    I'll try 40 40 psi then. I do have a 6in lift so that could affect it too
  22. Jan 25, 2019 at 1:41 PM
    #112
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    If I get 13.5 I'm happy! Generally I'm hovering around the 12 mark, with 60% of my driving in town and the rest highway.
  23. Jan 25, 2019 at 6:45 PM
    #113
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    I don't believe dashboard calculations. I am going to figure it by hand next week and report back. I'm going to guess 15 ...
  24. Jan 8, 2021 at 8:59 PM
    #114
    Jalbing
    Jalbing New Member
  25. Jan 8, 2021 at 9:22 PM
    #115
    FundraTRD
    FundraTRD New Member
    Seattle
    Snow White
    Same here
  26. Jan 8, 2021 at 10:34 PM
    #116
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Best I've gotten was in 2015 heading East to Oklahoma from San Diego and got about 23-25mpg with a considerable tailwind.. I remember mostly because I did it by hand and I texted my buddy over it, lol.. I think it was mainly through New Mexico..
  27. Jan 9, 2021 at 4:51 AM
    #117
    FundraTRD
    Seattle
    Snow White
    Yea hopefully you drove with your hands.
  28. Jan 9, 2021 at 11:51 AM
    #118
    Gray223
    Gray223 New Member
    2014 Tundra Double Cab Limited
    The biggest factor is your foot by far. How you drive has just about everything to do with it. Also I feel like once you start going faster then 70mph its gonna start dropping. Summer/winter, tires, lifts while be a factor but the biggest one will always be your foot I feel like, especially when there's guys getting like 12....obviously unless you have some serious modifications, hug lift/tires, alot of stop and go.
    I find it best to try to get up to your cruising speed as quick as possible, when reasonable like when you have a good distance before you will have to stop... without really gunning it/making it drop a gear.
    And remember to use the engine as much as possible to slow you down. Alot of people will accelerate up to say 30 or 40 to just put on the brakes a sec later to stop.
    Moon Puppy and Cpl_Punishment like this.
  29. Jan 9, 2021 at 12:09 PM
    #119
    IBeam
    IBeam New Member
    Southeast Texas
    2021 SR5 CM 4x4 Trail Edition, bed-mounted M2
    Stop and go city driving, even with a light foot, gets me between 10 and 12 usually
  30. Jan 9, 2021 at 12:19 PM
    #120
    Gray223
    Gray223 New Member
    Yes I could see heavy traffic stop and go thats possible. I guess I'm not use to leaving in city's like that. Although I do experience some stop and go its not much. Also people leaving there trucks idle is awful on gas milage. Look up engineering explains video on idling....it took 7 seconds to burn the same amount of fuel idling as it does to shut off and start the engine. So in theory if you have to set for more then 7 seconds its worth killing the engine.....although impractical and not good kn the starting its still something to keep in mind.
