Hit a wet spot in the primer when sanding .. help!!
Discussion in '2nd Gen Tundras (2007-2013)' started by digdug, Feb 6, 2017.
  1. Feb 6, 2017 at 12:39 PM
    digdug
    digdug [OP] New Member
    Doug
    2008 Crewmax
    Attn anyone who has experience painting plastic: After I had sprayed my final coat of primer on my grill surround I decided to lightly sand it to take off some high spots prior to applying the base coat. I hit a spot that wasn't completely dry yet (I thought I had checked it well enough to make sure it was dry) and it gummed up on me and looks like crap. I waited for it to dry and started to sand it some more but it just seems to make it worse. Any tips on how to smooth it out and the respray so you can't see it, or am I screwed? It was looking great up until this point, and the area is on the top in a really obvious spot.
    Thanks!
    ~dig
  2. Feb 6, 2017 at 12:57 PM
    NewImprovedRon
    NewImprovedRon Hey! Get off my grass!
    Ron
    Bentonville, AR
    2015 Radiant Red TSS Doublecab 4X4 Off Road
    Deck rail system, Bed divider, door sill protectors, LED reverse light bars, Aries Bull Bar with 28" 180 watt LED light bar, LED step lights, LED bed lights, driver-side grab handle, TRD Rear Sway Bar, BedRug bed mat and tailgate mat, Morimoto Fog Lights, more to come.....
    Any pics available?
  3. Feb 6, 2017 at 1:22 PM
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    Keep sanding/feathering it out or get some lacquer thinner and rags and wipe it all off and start over
    digdug [OP], 040Tundra and joem1cha3l like this.
  4. Feb 6, 2017 at 1:23 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    same as above
  5. Feb 6, 2017 at 1:26 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    what paint was it? Brand & type?
  6. Feb 6, 2017 at 1:34 PM
    digdug
    Doug
    2008 Crewmax
    Here you go!
  7. Feb 6, 2017 at 1:38 PM
    digdug
    Doug
    2008 Crewmax
    I bought adhesion promoter, primer, basecoat, and clear coat all from this company online. It was custom matched to my paint code.
  8. Feb 6, 2017 at 1:39 PM
    digdug
    Doug
    2008 Crewmax
    What grid do you think I should use? Wet or dry? Thanks man, I appreciate the advice.
  9. Feb 6, 2017 at 1:48 PM
    MakMurph
    MakMurph I'm here
    I'd start with 320 wet then finish up with 4-600
    digdug [OP] likes this.
  10. Feb 6, 2017 at 1:50 PM
    tomsinamerica
    Tom
    Wilmington, NC
    yup, let it cure to the point you can wet sand the area and reapply primer.
    once your primer is cured, if your base coat is metallic, i'd go to 600ish grit or maybe one grade coarser, dark metallics are very punishing of fine scratches in the substrate.
  11. Feb 6, 2017 at 2:06 PM
    digdug
    Doug
    2008 Crewmax
    Thanks!
  12. Feb 6, 2017 at 2:06 PM
    digdug
    Doug
    2008 Crewmax
    Thanks man, I appreciate it. Hopefully I can save it.
  13. Feb 6, 2017 at 2:08 PM
    MakMurph
    MakMurph I'm here
    No problem painting is all about patience lol!
  14. Feb 6, 2017 at 2:32 PM
    kicnit
    kicnit New Member
    14 Tundra TRD DC
    De-badged
    Best thing you can do at this point is to take a breath, step back, and let it dry. Don't to rush it. Sand that area back down, and do what others have recommended. It will come out great. Is their Clear Coat 2 stage? Curious, as I've only ever used the Spraymax 2k. Hardens just like a true Autobody job.
    Kyle
  15. Feb 6, 2017 at 5:01 PM
    tomsinamerica
    Tom
    Wilmington, NC
    Yup... painting is all in the prep. I spent over 8 months of evenings and weekends prepping my project car for painting... sand/prime/repeat to get it super straight... then, when it came to painting... it's all done in a matter of hours... somewhat anticlimactic but also an awesome experience
    Take your time getting the primer right, i said above that i'd wetsand... i think you're good either wet or dry... wet is easier to get a contaminants under it which scratch the primer giving you lines in your base... My final coat before sealer was with 400 dry. If you can get a thin foam backing block to sand, that's good... try to not use your fingertips... you may well see that when it has base & clear on it.
    I've not used the system you're using but if the clear is catalysed and has to go on the base within a certain time frame, the most important coat of paint you put down will be the first clear... practice on something first... once you've got everything right including the first coat of clear, any mistakes after that are more simple to fix.
    MakMurph likes this.
