Hikari LED's for my Spyder Headlights
Discussion in 'Lighting' started by captfields_sc, Aug 22, 2017.
  1. Aug 22, 2017 at 7:41 AM
    captfields_sc
    captfields_sc [OP] New Member
    Stephen
    2008 Toyota Tundra Limited
    I'm a newbie when it comes to putting aftermarket stuff on my tundra. Which Hikari LED's do I need to put in my Spyders? Also, are they just plug and play or do I need an adapter of some sort? Thanks for the help.
  2. Aug 22, 2017 at 7:47 AM
    I would go HID in the Spyders. Better throw pattern IMO.
    I went with the plug and play @ToyTec Lifts HID kit.
    Krezz and SouthBoundSteve like this.
  3. Aug 22, 2017 at 9:37 AM
    captfields_sc
    Stephen
    Thanks for the info.
  4. Aug 22, 2017 at 1:09 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    2007 Slate Metallic Double Cab
  5. Aug 22, 2017 at 1:19 PM
    captfields_sc
    Stephen
    My Spyder headlights take H1's so, I assume Hikari makes H1's correct..........
  6. Aug 22, 2017 at 1:24 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    Sorry, didn't notice you had a second gen. I would buy the bulb based off of your requirements, in that case. I can't verify that's what YOU need, but my replacement H11 for the third gen spyders fit with no problems. I've had them for about 5 months now without a single problem. Except that they buzz kind of loudly when the truck is off and I have the lights on. I can't hear it from the drivers seat, but could hear it when I was testing functionality of my LED DRLs that I installed.
  7. Mar 30, 2018 at 5:15 PM
    x7xrespectx7x
    x7xrespectx7x New Member
    2015 Red Tundra TRD
    Hey, when you say you removed the plastic cap on the end, are you referring to the h11 LEDs themselves or the plastic cap on the SPYDER headlights that weatherproofs the LEDs?
  8. Mar 30, 2018 at 7:48 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    By "plastic cap on the end" we mean there is a screw off cap on the bulb itself that unless removed, will not allow you to insert the bulb into the Spyder headlight. (You can see it in the picture in the link you posted. The round protrusion on the tip of the bulb. Those are the same bulbs I am running in my Spyders.)
  9. Mar 30, 2018 at 7:59 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I know this is an old post but is the Toytec kit the same as the VLeds conversion kid?
  10. Mar 30, 2018 at 8:01 PM
    :notsure:
  11. Mar 30, 2018 at 8:02 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I think that's what they were running on their Tundra so that's why I asked
  12. Mar 30, 2018 at 8:03 PM
    His running lights are Vled
  13. Mar 30, 2018 at 9:13 PM
    x7xrespectx7x
    2015 Red Tundra TRD
    Oh alright. Makes sense now man. I want to get the spyders.
    Just to double check, are your spyder headlights like these ones??
  14. Apr 2, 2018 at 12:51 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    Correct. Those are the same ones.
  15. Apr 3, 2018 at 11:36 PM
    x7xrespectx7x
    2015 Red Tundra TRD
    Thank you my friend. I am feeling more confident over time about these.
    As for installation, is it plug n play or do we need to do some wiring for the white bars on them?
    Also, are the white bars essentially DRLs?
  16. Apr 4, 2018 at 3:41 AM
    War Machine
    War Machine SSEM # 5 3MW
    No. They only light up when the headlights are on. I’ve had mine since September, and I’m very happy with them.
