highway vibration
Discussion in '2.5 Gen Tundras (2014-2021)' started by gues, Sep 26, 2019.
  1. Sep 26, 2019 at 3:10 PM
    gues
    gues [OP] New Member
    Hi, I just picked up a certified pre-owned 2018 Platinum with 12,00 miles from a Toyota dealership w/2" lift, 35"x12.5"x20" tires, and TRD dual exhaust which gives the truck a nice throaty sound. All work was done at the dealership. Loving the truck, but I notice the truck shutters front-to back (as opposed to up and down) in sync with the sound of the engine rpms when I'm giving it throttle. It's not the tires as I had the dealership re-balance them (and the vibration disappears when I left off the throttle). Is this because of the TRD exhaust? Gets annoying for any highway drive longer than 20 minutes. Should I be looking at putting the stock exhaust back on?
  2. Sep 26, 2019 at 4:49 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Sounds more like drive line, look and see if the drive shaft has a drop kit on it.
  3. Sep 27, 2019 at 7:09 AM
    gues
    If it doesn't have a drop kit, they should put one in?
  4. Sep 27, 2019 at 7:13 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    you can do the carrier bearing drop in your driveway in 15 minutes.
  5. Sep 27, 2019 at 7:23 AM
    15whtrd
    15whtrd Mr. Blonde
    It should only need a driveline spacer if the rear is lifted. I have 2 inch lift in front and about 1 inch in the rear with shackles. My shackles came with three-quarter inch carrier bearing spacers.
  6. Sep 27, 2019 at 7:50 AM
    Trikerider
    Trikerider New Member
    2015 Limited CM
    I've noticed this on my certified preowned 2015 with 84000 miles, sitting stock with oem size tires, same cyclical vibration when going up incline disappears as soon as I let off the gas. I also have an occasional clunk when shifting from reverse to drive which I'm thinking might be related. Had it at the dealer but they did not investigate but got the dealer run around. Going to have to figure out on my own, greased ujoints every 5k miles since I've had it, changed all driveline fluids. The clunk sounds like it is transfer case to driveshaft area to carrier bearing. I can push the driveshaft maybe a 1/4" of tight play in carrier bearing, but read on here where other have no problems and that some play is normal.
  7. Sep 27, 2019 at 8:04 AM
    gues
    Thank you all for your helpful support. I'll be taking it back to the dealer on Monday to get it resolved. I'll keep you posted.
  8. Sep 27, 2019 at 8:10 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Get some photos for us to oogle over!
  9. Sep 28, 2019 at 4:24 PM
    gues
    ......as requested.......
  10. Sep 28, 2019 at 5:38 PM
    HulkSmurf14
    2014 Tundra Limited
    Excellent looking truck...no wonder you're happy!
  11. Sep 30, 2019 at 9:18 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Beautiful truck. You picked the best color. Welcome. Hope you get your drive line issue sorted out. I have a 3" front 2" rear lift on mine with no carrier bearing shim. I don't have any issues with drive line shake.
  12. Oct 9, 2019 at 7:07 AM
    Trikerider
    2015 Limited CM
    Any resolution from the dealer?
  13. Oct 9, 2019 at 8:44 AM
    gues
    Dealer says the highway vibration is so minimal especially considering the lift kit, large tires. It does not currently have the carrier bearing drop kit. I have ordered a kit and will be installing on the weekend (weather dependent)
  14. Oct 9, 2019 at 1:52 PM
    sundance
    sundance New Member
    Crewmaxs tend to do this.
