Wheeler's Superbumps highly recommend
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra174x4, Feb 11, 2020.
  1. Feb 11, 2020 at 9:56 AM
    Tundra174x4
    Tundra174x4 [OP] New Member
    Cody
    2017 tundra sr5 trd off-road 4x4
    0EB47959-2793-49D0-8504-DA696AEBCD8A.jpg New Wheeler super bump installed Happy with the results. E024DFA3-5226-4BF7-A7A4-C00FDEDDE73A.jpg
  2. Feb 11, 2020 at 10:28 AM
    timsp8
    NY
    Looks like the Timberen. I put those on mine after 6112s at 1.9" setting just to be safe.
    Tundra174x4[OP] and georgiey22 like this.
  3. Feb 11, 2020 at 3:41 PM
    Overisland
    Overisland New Member
    Tony
    Polson, MT
    2020 Tundra Voodoo Blue Sport
    Nice, I just ordered some for my fronts.
    Tundra174x4[OP] likes this.
  4. Feb 11, 2020 at 3:55 PM
    TheBeast The Beach
    yes they are great ! love mine
  5. Feb 11, 2020 at 4:36 PM
    Tundra174x4
    Cody
    Just hope it doesn’t limit my travel
  6. Feb 11, 2020 at 4:38 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Wheelers states they compress to OE as long as you didn't install a shim, which doesn't look like you did .
    TheBeast and Black Wolf like this.
  7. Feb 11, 2020 at 4:48 PM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Love mine.
  8. Feb 11, 2020 at 5:30 PM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    Newbie question: what do they do? What's the purpose?
    Mattyc likes this.
  9. Feb 11, 2020 at 6:17 PM
    yoshi82, DXO, BTBAKER and 1 other person like this.
  10. Feb 11, 2020 at 7:49 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    That's not really what the superbumps are aimed for... That's what a bump does in general.
    The superbumps allow the bump zone to be larger, being that they are significantly larger. During compression to hit the bump sooner, the compression becomes more progressive. The factory bump, once your in - your in.
    Darkness, Wallygator and TheBeast like this.
  11. Feb 11, 2020 at 7:55 PM
    ctdomain
    ctdomain Expeditioner
    Clint
    2019 Limited Quicksand Tundra
    Suspension: ADS Front C/O's w/adjusters, ADS Piggyback rears, Toytec Shackles, Icon Rebound 17in wheels +25 offset, 35x12.50xr17 Nitto Ridge Grapplers. Miscellaneous: Tech 12 volts remote start, Tyger side steps, Color matched pro grille & bulge, Black handles off of SR5 Tundra
    So question, with aftermarket shocks then is this a requirement to have these installed to avoid blowing a shock? or even without aftermarket shocks, is it still a necessity? I feel like it would shorten the shocks window to dampen the energy from the hit, but I guess I understand it is a fail-safe if there is too much force? @14burrito
  12. Feb 11, 2020 at 8:00 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Answer is really no, you don't need to run these with an aftermarket shock. You don't need to run these with a stock shock.
    Now, can you and will it hurt?
    Yes you can, no it will not hurt.
    Some coilovers need an extended bump.
    5100s for sure come with a bump shim due to coil block height. 6112 I think come with a shim, not 100%. As I just found out, Icon requires a shim if you preload their coilovers past 1.5" of threads showing - again, this would be due to coil block height.
    The shim/spacer Bilstein provides (and Icon would otherwise require) extends the bump stop down "X" amount. Will the superbump help this situation? No, the superbumps compress to the same as OE. Wheelers do sell superbump shims to remedy this issue.
    Hopefully that answers the question
  13. Feb 11, 2020 at 8:08 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I have been running them for a few years now, been very happy
  14. Feb 11, 2020 at 8:17 PM
    TheBeast The Beach
    Wallygator and Black Wolf like this.
  15. Feb 11, 2020 at 10:02 PM
    Tundra174x4
    Cody
    It just makes the bumps and whoops so much better. I feel more confident in my truck.
  16. Feb 12, 2020 at 5:19 AM
    Pitbull410
    Gotcha thanks for the explanation!
    yoshi82 likes this.
  17. Feb 13, 2020 at 1:55 PM
    vanoss101
    vanoss101 New Member
    2015 SR5 Tundra DC
    Would these be a good opinion for someone who tows a trailer with alot of tongue weight but does not want to run airbags?
  18. Feb 13, 2020 at 2:53 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    The timbrens might be a better option or even the sumo springs. Those are rated stiffer, I think the wheelers might be the lightest rated out of the available options.
    Wallygator likes this.
  19. Jul 5, 2020 at 5:52 AM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Their website says these are installed in a different location and the stock bump stops are left in place, is this correct? For the front. It seems most suggest this is a replacement.
    I watched the install video and see that in some applications you leave the stock and add these, in others they’re a direct replacement.
  20. Jul 5, 2020 at 8:50 AM
    wiretwister
    wiretwister Sorta new guy
    NJ
    '22 SR5 CM
    What's the consensus on these vs Durobumps?
    Wallygator and Flyinryank like this.
  21. Oct 22, 2020 at 3:22 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Also curious
  22. Oct 22, 2020 at 5:10 PM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    I bought duro bumps. Not sure it was that different or worth it. I noticed the difference at first because I was trying but now it just feels normal again.
  23. May 19, 2021 at 4:39 AM
    Geodude82
    Geodude82 New Member
    I just installed a front spacer, 3", I assume this wouldn't help as they compress to OEM specs. Just wondering if anyone else used them or others in a spacer application.
  24. May 19, 2021 at 5:01 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    No, I had the same line of thinking you had on my 5th gen 4Runner. It did however soften the bottoming out when towing but ultimately I added airbags. Together they made for an excellent combination. When unloaded and with no air in the bags the Superbumps made for an much better ride on the cratered city streets I use.
  25. May 19, 2021 at 1:09 PM
    2mchfun
    Check out the Roadmaster active suspension, great investment
