Highest mileage 1st Gen. Thread?
Discussion in '1st Gen Tundras (2000-2006)' started by donaldp83, Feb 28, 2017.
How many miles are on your 1st gen?
  1. 0-99k
    51 vote(s)
    9.0%
  2. 100k-199k
    210 vote(s)
    37.2%
  3. 200k-299k
    199 vote(s)
    35.2%
  4. 300k +
    105 vote(s)
    18.6%
  1. Sep 14, 2019 at 2:34 PM
    #211
    Asap
    Asap New Member
    2001 tundra. 2005 tundra
    Neglect? I've changed the oil a few times!
    I had issues with hot spots on the front rotors, every time I would tow a mini excavator, until I put drilled and slotteds in it.
    FirstGenVol likes this.
  2. Sep 14, 2019 at 3:04 PM
    #212
    Asap
    Asap New Member
    And another thing....I had to put o2 sensors in it and change the starter motor and the left rear wheel bearing. I put I. A spend sensor and a dash cluster and the speedo still does not work.
  3. Sep 14, 2019 at 3:57 PM
    #213
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    That is damn cool! Now you get to keep driving this stallion. Keep it on the road, how does the truck look today?
    3.4Tundra likes this.
  4. Sep 14, 2019 at 4:00 PM
    #214
    georgiey22
    That’s a good looking truck and odometer. We like your plan for the truck. Does your uncle have any other 1st gens he wants to give away?
  5. Sep 14, 2019 at 5:25 PM
    #215
    Asap
    Asap New Member
    With around 600k on my 01 access cab. With tundras, mileage is not an issue under 300k.
    Has anyone ever had a timing belt break?
    And if so. What was the fallout? Bent valves?
    I didn't change mine until about 450k and there was barely even any belt dust in there to speak of. Of course the motor sounded like new with all the other stuff I replaced in the with the belt.
  6. Sep 14, 2019 at 5:27 PM
    #216
    georgiey22
    Well done ASAP! Let’s see that odometer? We will all be praying to the Toyota gods that our Tundras reach this milestone.
    TheBeeGuy, Filthyphil and MS22 like this.
  7. Sep 14, 2019 at 6:42 PM
    #217
    Asap
    Asap New Member
  8. Sep 14, 2019 at 6:45 PM
    #218
    Asap
    Asap New Member
    Towed many a mini-excavator, I've changed the once in 550-600k, never had a transmission problem.
    Filthyphil likes this.
  9. Sep 14, 2019 at 6:46 PM
    #219
    Asap
    Asap New Member
    Trans fluid and filter that is
  10. Sep 14, 2019 at 7:57 PM
    #220
    StrongMerlin
    StrongMerlin New Member
    2000 Tundra SR5
    2000 tundra, I have 261k. I had to replace Transmission at 200k. At this point. ill just replace the engine if that goes, But im sure ill get over 400k before that happens. Bought the truck at 175k.
    revtune and Filthyphil like this.
  11. Sep 14, 2019 at 8:06 PM
    #221
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Welcome. Any idea what caused the transmission failure? Even with 200k it's pretty rare for these trucks. Seen a few over 500k with the original tranny.
  12. Sep 14, 2019 at 8:45 PM
    #222
    StrongMerlin
    2000 Tundra SR5
    the 4th gear went out. I believe the oxygen sensers went bad first, causing a chain reaction.
  13. Sep 17, 2019 at 12:21 PM
    #223
    Tundy47
    Tundy47 New Member
    06 DC 4x4
    06 Double Cab 141k
  14. Sep 18, 2019 at 5:06 PM
    #224
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Broke 162,000 yesterday! I’ve officially put 10,000 miles on it in 2 years :(
  15. Sep 19, 2019 at 12:46 PM
    #225
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    @ 182K no where near highest mileage, bought from original owner @ 113K in 09. Since retiring have not done much except maintenance. That has now changed unfortunately after finding this site :) after visiting many other Toyota sites. Problem is my CC is going to drain my retirement on upcoming mods....LED changeout interior/exterior, still trying to find reason not to pick Kenwood DNX996XR as my Head Unit. Have no records on if previous owner did belts, WP, seals, so that is something I am going to discuss with my Toyota Dealer in coming months. Thanks to those here offering your experiences/knowledge and look forward in doing same !
  16. Oct 3, 2019 at 7:35 AM
    #226
    Indy Tundra
    Indy Tundra New Member
    2000 Tundra SR 5 Access cab
    Leveling kit powertrax locker, 330,000 miles and counting
    2000 Tundra 4wd, 4.7, 330,000 miles and counting! Other than the rusty bed its fantastic. I have looked at moving on to a newer Tundra several times. Every time after the test drive and returning to my 1st gen Tundra, I prefer the feeling of the 1st generation Tundra. Even at 300,000 miles plus, it feels sporty, more nimble and tight. Major repairs to date: 1 coil pack, the starter, tie rod ends (small lift 2" in front 1.5" rear), brake master cylinder, brake booster and timing belt service.
  17. Oct 3, 2019 at 7:55 AM
    #227
    trailbikerider
    trailbikerider New Member
    Blake
    Kalamazoo, MI
    2006 Tundra DC SR5
    Not even close to being high mileage, but thought I'd share. Here is my 2006 DC with 116,000 miles. Purchased last August in Arizona with 103,000 miles.
    [​IMG]Untitled by Blake Nichols, on Flickr
    georgiey22 and speedtre like this.
  18. Dec 4, 2019 at 8:58 AM
    #228
    cammiller
    cammiller IG: cameron.a.mi
    Cameron
    Sulphur, Louisiana
    2004 Toyota Tundra Limited Phantom Grey Pearl
    Kicker speakers, Pioneer AVH-2550NEX Head Unit, DynaMat, LED Dash Conversion
    Mine broke last week at 234,061 miles and no damage at all. 2004 double cab limited 4.7l 4x2.
    Also, I am the 7th owner of the truck.
    georgiey22 and Filthyphil like this.
  19. Dec 17, 2019 at 12:11 AM
    #229
    chrifishtopher
    chrifishtopher New Member
    Huntington Beach, CA
    04 Tundra DC 4WD
    224k on a 2004 DC 4wd. Need to replace valve cover due to small leak soon but still runs perfectly. Also a crack in the radiator (I'm in Southern California)
    georgiey22, bmf4069 and Filthyphil like this.
  20. Dec 17, 2019 at 11:20 PM
    #230
    2000Strong
    2000Strong Just a dude and his truck
    Benjamin
    Washington
    2000 Maroon Tundra, AC, Premium Audio, SR5 4.7
    All LED Interior lights, New Headlights, Break Controler, LineX Bedliner.
    Sorry for the super late reply but this is the truck and I last week. Paints a bit faded but other than that I’m nearing 184k and no problems at all!
  21. Dec 17, 2019 at 11:22 PM
    #231
    2000Strong
    Benjamin
    Washington
    I was getting hard shifts for a while and decided to run clean fluid through it till it came out clean and it fixed the problem, it was like black oil coming out at first I bet it’s never even been done before till now.
  22. Dec 18, 2019 at 4:50 PM
    #232
    staypuft
    staypuft New Member
    PA
    04 DC
    Just saw this on IG... not sure if it’s legit but guy says it’s original drivetrain.
  23. Dec 18, 2019 at 6:38 PM
    #233
    Filthyphil
    Phil
    That is crazy I would love to hear the story about that truck
  24. Dec 18, 2019 at 8:38 PM
    #234
    georgiey22
    I’m a fan. Congrats pal. Rack up those miles.
  25. Dec 18, 2019 at 8:39 PM
    #235
    georgiey22
    It looks like it has 2,000,000 miles on it. :turtleride:
  26. Dec 18, 2019 at 8:58 PM
    #236
    2000Strong
    Benjamin
    Washington
    I just graduated high school a few months back and really wanna find a job where I drive a lot. I love being behind the wheel currently I’m in college but in all honesty it’s not really my thing.
  27. Dec 19, 2019 at 9:43 PM
    #237
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You shouldn't feel forced to go to college. A lot of us on this site are in skilled trades. Good professions are out there that don't require a degree. Or ask @Professional Hand Model how to get into hand modeling.
  28. Dec 19, 2019 at 11:01 PM
    #238
    2000Strong
    Benjamin
    Washington
    I got forced into it by my dad because “you won’t like cars if you’re working on them” but like literally every time I get free time I’m doing something with cars. I thought about being a auto body tech or try and start a tuning shop after the right schooling. I have a friend that’s a welder and apparently the pay is killer and it’s fun according to him.
  29. Dec 20, 2019 at 5:23 AM
    #239
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I hate to derail this thread anymore but BFM makes some really good points. I went to college and majored in Logistics from a top program. Now I'm 31, bored to death, and trying to figure out what I want to do next. While I still believe there is some value in that piece of paper, a bachelors is not what it used to be. It's going to be even tougher for your generation. Also, if you're going to end up with a mountain of student load debt I would encourage you to reconsider this plan immediately. I have friends that are going to be paying off student loads well into their 30's. This really delays financial progress.
    Pick something you know you can enjoy, and make a good living at. I wanted to be a park ranger but can't live off $28K/year. A lot of my friends that learned a trade are making more money than me. Some jobs that are currently in high demand:
    • Diesel Mechanics
    • Forklift mechanics-my company is so desperate they are offering sign on bonuses
    • Electricians. You can get a union job making 6 figures as an electrician for the government
    • Plumbers
    • Welders
    • Airline Mechanics
    • Pilots-massive up front costs here but can make a ton of money
    The only caution here is that many of these jobs are hard on your body. You'll have to find a way to balance that so you're not crippled by the time your 50.
    Again, sorry to derail. I just wish someone would have told me at 19 that I should consider a trade.
  30. Dec 20, 2019 at 5:51 AM
    #240
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    I sold this guy last week. Had it since it was new and did WAY too much to it. It had 259,760 when I sold it to the new owner. It was a fantastic truck that never let me down.
    speedtre, classiccat, bmf4069 and 2 others like this.
