High oil pressure on gauge
Discussion in '1st Gen Tundras (2000-2006)' started by Doutakcash67, Jul 9, 2019.
  1. Jul 9, 2019 at 3:59 PM
    Doutakcash67
    Doutakcash67 [OP] New Member
    What would cause my oil pressure gauge to spike? Engine has plenty of oil. First Gen 06
  2. Jul 9, 2019 at 4:02 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    spike how far and when? under throttle, coasting?
  3. Jul 9, 2019 at 4:04 PM
    Doutakcash67
    As in pegged way past the H. All the time
  4. Jul 9, 2019 at 4:06 PM
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    Faulty sensor?
    Filthyphil, bmf4069 and 15whtrd like this.
  5. Jul 9, 2019 at 4:09 PM
    15whtrd
    15whtrd Mr. Blonde
    Clogged oil filter or faulty sensor?
  6. Jul 9, 2019 at 4:19 PM
    Aerindel
    Aerindel New Member
    Montana
    Oil filter should have a relief valve in it so even if clogged pressure should not increase. Faulty sensor or gauge is the most likely.
  7. Jul 9, 2019 at 4:19 PM
    Doutakcash67
    I’m thinking faulty sensor just not sure. With the ignition off it’s past high. Started out of the blue.
  8. Jul 9, 2019 at 8:47 PM
    Aerindel
    Aerindel New Member
    Montana
    That sounds like an electrical problem in the dash wiring system. A missing ground wire on any of the gauges will cause them to peg out like that. Same thing happened to my coolant gauge once when I had a loose connection in the dash harness.
